Old 12-05-2012, 05:55 PM   #113
DSPographer
DSPographer's Avatar
Drives: '13 BRZ Lmtd
Originally Posted by xcelir8brz View Post
Just spend twenty dollars and buy a new antenna and mount on dash. All of your issues go away. Search my solution.
Why do that when the TSB is installed for you for free? My BRZ Nav now tracks my position perfectly.
DSPographer is offline   Reply With Quote
Old 12-06-2012, 07:42 PM   #114
xcelir8brz
Drives: 2013 BRZ Limited
Because my VIN was outside range.
xcelir8brz is offline   Reply With Quote
Old 06-07-2016, 01:36 AM   #115
archmcarch
Drives: Subaru BRZ
For those of you having trouble with their navigation systems they may want to try a simple reset of the system before bringing the car into Subaru.
In the TSB link below are some instructions to try
http://www.ft86club.com/forums/showthread.php?t=20659
Goto the section where it says to remove the backup fuse and yank that sucker out for about 5 minutes. You don't have to disconnect the battery cables, just wait 5 minutes slide the fuse back and turn the ignition on. This should re initialize the navigation system.
I was having trouble not seeing any satellites and the system constantly searching for a gps signal and never finding one. Also when I would look at my map it showed me being in Quebec Canada when I live in Boston
archmcarch is offline   Reply With Quote
The Following User Says Thank You to archmcarch For This Useful Post:
davesrave (01-05-2020)
Old 06-07-2016, 11:08 PM   #116
archmcarch
Drives: Subaru BRZ
It's TSB 15-158-12
And this is the fuse
Old 01-05-2020, 09:42 PM   #117
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Big thanks to archmcarch! His post may be over 4 years old, but his suggestion worked like a charm for me today. My GPS Nav has worked fine since 2012, until it flaked out recently. Now back working.
davesrave is offline   Reply With Quote
"Car geek" credited with finding child killer. 1660 Off-Topic Lounge [WARNING: NO POLITICS] 3 08-04-2011 05:11 AM
