Old 12-05-2012, 10:28 AM   #15
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
I have the voltex on mine, i have it set pretty much flat so i am getting some downforce just not as much as i could do if i angle it down more. Through turn 1 @ harris hill where you are going full throttle i really felt a difference in how planted the car feels now, it just gives me much more stability and confidence. My last two mods were going from track pads, fluid, and lines to the AP Sprint kit with race pads and the voltex wing. This helped me shave my time from a 1:31.3 to a 1:29.8 i think the mods in conjunction worked very well. Dont know if the downforce of the stock wing will be the same, but i would like to share my experience that i had while adding rear aero.
You can see the angle in this pic:
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
86ft.lb (09-21-2016)
Old 12-05-2012, 12:02 PM   #16
gmookher
to really benefit the wing, I think you need more angle, but then there s line where you just create drag and slow yourself down too...not sure what you saw was wing driven,
I think you just drove 1.5 seconds better, and braked later for sure.
Interesting feedback just the same.
Old 12-05-2012, 02:57 PM   #17
track_warrior
Track Junkie
Interesting thing was that a part of the track was coned off so i was letting off a bit, i think without the cones i should shave a couple more tenths. The way the wing is shaped it still creates some downforce because of how the rear is angled upward. I did the pressure washer test and this confirmed it, the water flow from the roof like would hit the wing and angle back up again a bit which means it is creating some downforce. I did feel the car a bit more stable as well through the high speed corner sections and this inspired more confidence and i could drive faster through there. It might be psychological confidence but i could have sworn it felt more planted than before.
Here is another angle of the wing
Old 12-05-2012, 05:08 PM   #18
CSG Mike
CSG Mike's Avatar
Assuming the car is being driven at close to the limit, a wing is only good if the aero is balanced front and rear. You can increase the angle of the wing (angle of attack) to increase downforce, to a degree, at the cost of more drag. Too much angle, and you'll stall out the wing, and only generate drag with no downforce. If you have too much rear downforce, you'll take away grip from the front tires (lever action over [roughly]the rear axle), and not be going *as fast* as an ideally aero balanced car. However, most drivers prefer a slightly pushy car, as it is MUCH easier to drive, and more consistent lap to lap.
We can keep going into this subject deeper and deeper if you'd like.
Old 12-05-2012, 11:23 PM   #19
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I bet that wing counter acts some of the high spring rate. What suspension are you running?
jdzumwalt is offline   Reply With Quote
Old 12-05-2012, 11:27 PM   #20
track_warrior
Track Junkie
KW V3'S , love them so far.
Old 12-05-2012, 11:27 PM   #21
jdzumwalt
Motor Sports slut
I like that wing, but I would want it about 1/3 the height my customer would shit themselves if I should up with that.
I'm thiking something more along the line of this
Old 12-05-2012, 11:28 PM   #22
jdzumwalt
Motor Sports slut
are you on the stock setup? with the 7 in the rear ans 6 in the front?
Old 12-05-2012, 11:29 PM   #23
track_warrior
Track Junkie
Yup, im still on the stock spring rates. I havent found a reason to play with them yet. COTA in february will be the test though.
Old 12-05-2012, 11:59 PM   #24
jdzumwalt
Motor Sports slut
If you dont mind what are you running for the Dampener adjustments?
Old 12-06-2012, 12:13 AM   #25
track_warrior
Track Junkie
Bump is set at what they come from kw i think its 3 all around, Rebound is 4 clicks from full soft on the front and 2 clicks from full hard on rear. -2.5 Camber front and -2 rear
Old 12-06-2012, 12:58 AM   #26
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Sounds aggressive for the camber. Anybody got the OEM specs laying around? Your whiteout looks great BTW.
soros151 is offline   Reply With Quote
The Following User Says Thank You to soros151 For This Useful Post:
track_warrior (12-06-2012)
Old 12-07-2012, 10:08 AM   #27
jdzumwalt
Motor Sports slut
That camber is dead on for hard cornering.
The Following User Says Thank You to jdzumwalt For This Useful Post:
soros151 (12-07-2012)
Old 12-07-2012, 10:45 AM   #28
hal0n
Drives: 2013 WR Blue BRZ
to be clear, a wing must exist out in the laminar flow region. a spoiler like you have shown functions differently. wings don't necessarily create turbulent flow resulting in parasitic drag like a spoiler. so wings wont work correctly unless they are tall. im not an aero eng tho (im a mech eng). so i could be wrong
hal0n is offline   Reply With Quote
Red Toyota 86 with factory aero kit and spoiler wing DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 112 02-04-2014 12:16 AM
WING or NO WING? Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 35 04-05-2013 12:54 PM
I'S Factory Rear Wing Jade 86 Cosmetic Modification (Interior/Exterior/Lighting) 4 08-08-2012 03:02 AM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
