Old 11-16-2012, 10:26 AM   #1
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Factory Wing
I'm not sure if this is the right area for this but move it if it's not.
I'm thinking my car needs a rear wing at 100+ it starts to feel a little unsettling. I was thinking the stock BRZ wing would give me the needed down force.
Watcha think?
jdzumwalt is offline   Reply With Quote
Old 11-16-2012, 10:42 AM   #2
whaap
whaap's Avatar
I think from the looks of its angle it would give you additional down force. Whether too much or not enough, I don't know.
whaap is offline   Reply With Quote
Old 11-16-2012, 11:08 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Watcha think?
the stock STi wing on a wrx doesn't become functional until 117, so not sure if the brz wing will do much before that. Maybe look into the gurney flap as well if you want oem.
Old 11-17-2012, 12:27 AM   #4
jdzumwalt
Motor Sports slut
I'm looking for something clean.
But functional
Old 11-17-2012, 01:43 AM   #5
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Hmmm... I've been up to 115 on a long straight at one of the road courses here in Texas... And I felt the car was pretty stable. Maybe it's just me, but I don't think this car really needs the wing...
You can try it and let us know any difference, if you'd like...
Texas BRZ is offline   Reply With Quote
Old 11-17-2012, 01:45 AM   #6
#87
I usually post drunk
#87's Avatar
Supposedly it reduces drag .01 while increasing downforce (unspecified amount).
I got one because I like the look and its cool it is functional.
#87 is offline   Reply With Quote
Old 11-17-2012, 07:08 AM   #7
Ninjin
Ninjin's Avatar
Drives: SWP BRZ 6MT
Does the rear or the front feel unsettled? If the front is loosing grip at high speed (a fairly common situation), then a rear wing would probably make it worse, since it could potentially reduce front end grip by pushing down on the rear (there's a lever effect). If you want really functional aero, it's important to keep downforce balanced at both ends of the car. Thankfully, a front splitter doesn't have to match the rear wing in size to produce equal downforce, so a more modest splitter may be enough.
To second what @finch1750 said, the JDM gurney flap will probably be important if you want the OEM wing to produce meaningful amounts of downforce.
Old 11-17-2012, 07:43 AM   #8
_F-R-S_
Drives: 13 whiteout scion frs
Feels rock solid at 122 without wing.
_F-R-S_ is offline   Reply With Quote
Old 11-17-2012, 07:51 AM   #9
jdzumwalt
Motor Sports slut
This sounds like I may need to adjust my suspension. I will add a click into rebound to try and settle the car.
Old 11-17-2012, 09:44 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
how much rake do you have and have you done an alignment?
Old 11-17-2012, 10:15 AM   #11
CharlieChaos
Drives: FRS
115-120+ no issues
_____________________________________________
http://genometuning.com
http://www.BlackHandGaming.com
CharlieChaos is offline   Reply With Quote
Old 11-25-2012, 09:01 PM   #12
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
I always thought a rear wing should be used to increase high speed cornering grip in conjunction with a front splitter or dive planes to maintain the aero balance.
Wouldn't just having a rear wing make your car tight in a high speed corner? (I'm assuming it is already balanced from the factory)
AlexTheGreek is offline   Reply With Quote
Old 12-05-2012, 10:09 AM   #13
jdzumwalt
Motor Sports slut
On this the front feels very planted but the rear tends to want to skip around. I'm adding a front strut tower bar to try and induce some understeer.
Old 12-05-2012, 10:27 AM   #14
diirk
diirk's Avatar
Drives: 4Runner
I also haven't noticed any issues at about 120 at Willow Springs. It does sounds like it may be suspension related. You might also try playing with your tire pressure front/rear a little. Maybe add a couple of PSI to the front or drop the rear a couple of PSI.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Red Toyota 86 with factory aero kit and spoiler wing DIG1992 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 112 02-04-2014 12:16 AM
WING or NO WING? Billy2224 Cosmetic Modification (Interior/Exterior/Lighting) 35 04-05-2013 12:54 PM
I'S Factory Rear Wing Jade 86 Cosmetic Modification (Interior/Exterior/Lighting) 4 08-08-2012 03:02 AM
Swap: factory 16s for factory 17s Sydney MZ21 Australia Classifieds 10 07-29-2012 10:46 PM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
