Old 12-04-2012, 11:12 PM   #57
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Originally Posted by Concept-Three-LED's View Post
Is it a simple push of a button to switch from e85 to 91?
Well, it's a simple "pull of the cruise control lever," if that's what you mean.
vubaru is offline   Reply With Quote
The Following User Says Thank You to vubaru For This Useful Post:
Vicious LED (12-04-2012)
Old 12-04-2012, 11:12 PM   #58
chutrain
chutrain's Avatar
Drives: WRB BRZ
Many of the Subaru guys have been running for years and I haven't heard ill effects of the fuel system breaking down. Some recommend running a few tanks of normal gasoline from time to time.
If you are already comparing price and mileage, not sure you want to switch to E85 fulltime. I believe someone was saying they were getting high teens. If fuel costs and limitation of stations are a concern, not worth the effort in my opinion.
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 12-04-2012, 11:15 PM   #59
Vicious LED
Drives: Scion FR-S Asphalt
Yeah, I had heard as long as you're not letting the E85 sit idle in the tanks/lines for extended periods of time it shouldn't be too much to worry about...but I've also heard the extremes of "it will destroy everything."
E85 is plentiful here in Vegas, and the price is usually about 40 cents cheaper per gallon. Fuel pricing isn't a huge concern for me, in the end it appears it will run a tad more expensive over time but the gains make it worth it.
Thanks for your input!
Vicious LED is offline   Reply With Quote
Old 12-05-2012, 01:18 AM   #60
vubaru
Now with Boost!
vubaru's Avatar
I've run E-85 in Subarus and other cars, in mixes and in near-pure form. As I've said in other posts, running a mixed 93/E-85 blend skewed towards 93 showed gains for multiple 2.5 RS owners on NASIOC, including myself, with no ill effects. Ran it on and off and changed tanks with pure 93 every few fill-ups.
I checked that fuel system myself after running 5-10k of the ethanol blend (with alternating 93 fill ups) after another 15k total miles, and I'll be damned if that fuel filter didn't show normal wear. No sign of E-85, period. Couldn't even tell it was there.
Some folks say, "Wait, we have a high pressure fuel system and E-85 can harm it." Well, maybe over time. Pulling our fuel system after running E-85 showed no ill effects according to Visconti, but I'm not sure of the mileage.
The problem is, we all run some percentage of ethanol in our cars, right now. How much ethanol would be too much if the fuel system is already designed to tolerate say, 10%?
I've been trying to get my gas low enough for E-85 for a long time. Shooting for this weekend.
...And now my FA20club flash is done!
Yruyur (12-05-2012)
Old 12-05-2012, 07:48 AM   #61
Captain Insano
With the cruise control map switching, how do you know which map you are on as you switch through the options if you have say 4 map options?
Captain Insano is offline   Reply With Quote
Old 12-05-2012, 08:04 AM   #62
FA20Club.com
Drives: 2013 White Out FR-S
Originally Posted by 2forme View Post
The problem is more along the lines of cold start in an actual cold environment. AZ isn't a cold environment :-p.
Below 50 degrees causes issues.
The lowest temp ive had a customer start his car in was few weeks ago in the 38-45 degree weather. No startup issues. He even posted a video i linked to in another thread.
FA20Club.com is offline   Reply With Quote
Old 12-05-2012, 08:13 AM   #63
Foobar
SLO NO MO
Foobar's Avatar
Your tachometer switches from 1K to 4K depending on which map you've triggered. Once you've selected it, it goes back to displaying current RPM.
The Following User Says Thank You to Foobar For This Useful Post:
Captain Insano (12-05-2012)
Old 12-05-2012, 08:18 AM   #64
Captain Insano
Awesome, thank you sir.
Old 12-05-2012, 08:29 AM   #65
2forme
We had 15-20 degree lows last week .
I haven't run e85 for a little while now. I don't like it's water absorption properties in cold weather and they run different blends for winter up here.
Old 12-05-2012, 08:29 AM   #66
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
42 this morning and fired up like pump gas
Old 12-05-2012, 08:51 AM   #67
Yruyur
Yruyur's Avatar
Cold Start - 52 here and gave a tiny tap of gas and seemed like pump gas. Very very happy
Sent from my flux capacitor using Taptalk
Old 12-05-2012, 08:59 AM   #68
2forme
I wish my "cold" starts were 52....
Old 12-05-2012, 09:58 AM   #69
Frostyman
Drives: 2013 Raven FRS
normally I have no cold start issues, but today it was in the 60s, and still didn't start first crank. Second crank did it. I'm gonna take some logs and send them in after I get car back from the dyno this evening.
Frostyman is offline   Reply With Quote
Old 12-05-2012, 12:15 PM   #70
xjohnx
Grip>Slip
xjohnx's Avatar
for cold start logs, you're going to want to let the car sit at least 4 hours, (preferably overnight) so that the fluid temps come down completely.
Also, make sure the o2 sensor has preheated before you begin your logging/startup attempts. You can do this by turning your ignition to the on position (without actually attempting to start the motor). Let it sit like this for 10-15 minutes. This will allow the o2 to preheat and provide accurate readings for the log.
APEX-i SMART Throttle Controller - preliminary test. Moto-P Engine, Exhaust, Transmission 33 05-24-2015 07:01 PM
REVIEW: FA20Club Tune, AFE Intake, and Perrin Pulley draggin_az Engine, Exhaust, Transmission 21 04-29-2013 04:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
FA20CLUB.com E85 Goodness FA20Club.com Engine, Exhaust, Transmission 45 11-13-2012 01:05 PM
Tunehouse BRZ Tuning program preliminary details Hachiroku Engine, Exhaust, Transmission 42 06-25-2012 07:40 PM
