#29 | |
Drives: 4Runner
diirk
waiting on a Neptune Premium MT |
| The Following User Says Thank You to diirk For This Useful Post: | Texas BRZ (12-04-2012) |
#30 | |
Imperfect
Drives: 2025 C8 Z06s and more!
If you're a Novice or an Intermediate, I think the stock pads will last at least 1-2 (two-day) HPDE events, and I'm trying to be on the safe side by stating this guesstimate (since I tried this out myself, and the front pads lasted about 3 events for me). If you're a Novice and very hesitant on pushing your car (like when I was when I first started HPDE events 2-3 years ago), then the stock pads may even last you 4-5 events... I wouldn't go in expecting that though. Try it out, BUT I strongly advise that you bring along a back-up set of front brake pads with you for each event. Even if it means purchasing a back-up set of the same OEM pads, do it... Although it's a wise idea to go with a higher-performance pad in the first place (and as back-up). Good luck, and play it safe & smart... Always be prepared.
#31 |
Drives: frs
#32 |
Drives: 4Runner
I ran stock pads on the big track at Willow Springs for two days (200 miles on the track). No issues whatsoever. The only reason I swapped to new pads was because I got them for free. Now the OEM's are backups.
diirk
#33 | |
My gash wasn't that bad but the last thing I want to worry about on the track is a sidewall blow out. |
#34 | |
Outside of WSIR, every novice I've coached has managed to start fading their OEM pads by the end of the day. OEM fluid seems to be able to withstand the heat that the OEM pads generate before they fade. |
#35 | |
Drives: 4Runner
I can't dispute that. Just throwing it out there for info.
diirk
#36 |
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I run Stoptech upgraded pads, Pilot sports tires and Motul fluids for brakes trans and rear end.
Brakes are holding up great. I have 5000+ miles and tow track days on this setup. I've been running the Roval. So lots of High speed to 30 mph type of slowing down. My tires look really good. I used to dirve an evo 8 and the stock tire wore out way faster with just street driving. I'm guessing at this rate the tires should last about 25k with the track days thrown in the mix. These tires a a really good street tire I almost feel guilty running them out there on the course my guess is you could get 40k out of a set if I didn't do the track days. The Michelin Pilot sports make the Nittos Neo GEN feel like ICE. It is possible if I had a stickier set of tires my brakes would get a little more hammered as of now I feel Like I'm limited in braking based on the rubber. I'm planing on a R compound setup and brake upgrade at the same time. Gregg |
#37 | |
Drives: 4Runner
diirk
#38 |
#39 |
Drives: Cobalt
thanks for all the information everyone!!!
Still undecided...also looking at a z06... But of course... tires/brakes/gas = more |
#41 |
slide to unlock
Drives: 2013 FR-S Raven Black
Had a blast reading everything! To the op: Like what alot of people stated, car is neutral, stock. Even if the back end starts giving, it is easy to catch/correct. My only complain is the throttle sensitivity for MY liking (i had a b16 swapped ef civic but given it has a cable throttle). Also, the clutch is a little high for me (there is a diy for it to be adjusted). Lastly, the shifter feel is very good but IMHO the s2000/mx5 feels a tad better in this department
#42 | |
Drives: Cobalt
Can't be as bad as BMW, worst electronic throttle evar I can say my cobalt, is excellent for both elec thorttle and steering well until the steering fails lol |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | Tracking / Autocross / HPDE / Drifting | 0 | 08-14-2012 06:46 PM |
| Element Tuning Track Tested and Track Proven FRS Video | Element Tuning | Tracking / Autocross / HPDE / Drifting | 47 | 07-17-2012 04:12 PM |
| $110 Track day at Willow Springs- Big Track -May5 in SoCal | Louie | Southern California | 3 | 05-04-2012 01:05 AM |
| $110 Track day at Willow Springs- Big Track -March24 in SoCal | Louie | Southern California | 1 | 03-10-2012 01:31 AM |
