Old 12-03-2012, 11:14 PM   #15
gmookher
car is so much more fun once you loose the prius rubber
Old 12-03-2012, 11:37 PM   #16
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Can you guys comment on consumables & reliability (as of now)?
iLuveKetchup is offline   Reply With Quote
Old 12-04-2012, 03:25 AM   #17
CSG Mike
CSG Mike's Avatar
Brakes last longer than on the s2k; you can use a "lower" compound and get away with it, without ducts.
Reliability... well... we already went through an engine.
Old 12-04-2012, 05:18 AM   #18
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
^this!
And for the op, this car is a blast at the track! Here's my experience... http://www.ft86club.com/forums/showthread.php?t=18110
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 12-04-2012, 07:28 AM   #19
robispec
Drives: Black frs project
come on out to the exestream speed event 14/15th at streets of willowsprings! we can all have some more of this kind of fun...
robispec is offline   Reply With Quote
Old 12-04-2012, 09:10 AM   #20
diirk
diirk's Avatar
Drives: 4Runner
^^^ That would be a long drive for the OP, but worth the time. Make a SoCal vacation of it and enjoy yourself.
As for the original topic, yes, the BRZ/FRS makes a great track car. Completely stock it's an excellent platform to learn on and as you get better, you can do small upgrades to the car to keep it on par with your skill level. It's very neutral and tunable to fit your specific driving style. If you like hanging out the rear end, then the car will do oit. If you want to stick like a slot car, the car will do it. So far I'm very impressed with the car and the only thing holding it back from better lap times is the driver....
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 12-04-2012, 09:52 AM   #21
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
I feel my FR-S goes through brake pads faster than the MX-5 I owned previously (MX-5 weighed 300 lbs less, maybe that's one of the reasons)... But it's the complete opposite with the tires. I'm surprised that I still have reasonable life left on the 'Prius tires' that come on the FR-S... As I keep an eye on my tires after each session, the tires are not as punished as one might expect, despite me pushing the tires at the limit consistently.
Reliability:
I'm approaching 10k miles, and 6 two-day HPDE events... The FR-S has given me zero issues, and that's the truth. No engine overheating, no limp mode hiccups, etc... Nothing, and I hope it continues this way.
I place a lot of importance on reliability because of how my previously owned vehicles tested out through my track experience. My RX-8 R3's engine went out in about the first 10k miles (car was bought new and I maintained the oil level as required). The car also went into a limp mode phase (twice) during one of my track sessions... Several months before the engine outage took place.
On the MX-5, the catalytic converter(s) gave up on me twice within the first 6k miles.
So when I compare, my FR-S is holding up well, so far...
Texas BRZ is offline   Reply With Quote
Old 12-04-2012, 10:07 AM   #22
G Speed
Drives: Cobalt
Originally Posted by blkwrxwag View Post
I put four 17x8 wheels with 245 in the back - no problem.
Bigger would not be an issue. Stack them behind the front seats
Perfect
Originally Posted by Texas FR-S View Post
Performs brilliantly... Even if you're not the fastest guy out on the track (that's not suppose to be the goal anyway, I suppose), this car delivers a lot of fun and connection with the driver.
I believe it's more of a momentum car, and it doesn't feel like it lacks performance.
As I've advanced with my experience and skill level at the track (and as I drive the limit more and more), I feel the OEM tires can start holding one back. After getting full use of the OEM tires (or knowing when you're ready), it's a good idea to start the search for higher-performing tires... This car and its chassis deserve better tires as you start advancing, that's for sure.
I feel this car has a more torquey engine compared to what I was used to (RX-8 and MX-5). Power is not disappointing, in my opinion...
Brake fluid and pads will need to be upgraded... And as I was taught before, you will have to keep an eye on the rotors.
No need to upgrade all at once, and it's good to take it one step at a time... Or as needed.
As @blkwrxwag mentioned, I don't think you'll have any issue with fitting your specific size of wheels / tires.
See that's my problem... My car right now is 3000lbs.. so about 200ish lbs heavier than the FR-S.. but is 280whp/320tq
perfect
don't thread jack! I'm jokking good question
Originally Posted by twincamRob View Post
^this!
thanks
Well........
2,530 mi, 37 hours ....
If I had a truck/enclosed trailer sure LOL
driver mod, always needs modding lol
Reliability:
I place a lot of importance on reliability because of how my previously owned vehicles tested out through my track experience. My RX-8 R3's engine went out in about the first 10k miles (car was bought new and I maintained the oil level as required). The engine went into a limp mode phase (twice) during one of my track sessions... Several months before the engine outage took place.
glad to hear.. I assuming why peoples tires are holding up is because of the higher treadware...but I bet as well as they work for you know.. going to a sticker compond or better compond in general.. will make a world of a difference...
I would probably learn the car on those tires though
G Speed is offline   Reply With Quote
Old 12-04-2012, 10:29 AM   #23
diirk
diirk's Avatar
Drives: 4Runner
I would suggest running the stock tires for the first few times too. If nothing else it gives you a good baseline for future modifications.
diirk
Old 12-04-2012, 10:48 AM   #24
Texas BRZ
Imperfect
Texas BRZ's Avatar
Then you may likely miss some of that power...
For me however, the real excitement and challenge is in how I can preserve as much momentum as possible... And then maintaining and building upon that speed through the course, consistently. In this regard, the car has solid power for my desire. That's possibly why I happen to be satisfied with the power output. And actually, the REAL speed is in this car's chassis and overall balance, I feel.
Yup... And I'm extremely excited to see how the car does on ZI/II Star Spec's... I'm hoping for a mind-blowing difference, but I better keep my expectations low, hehe.
Old 12-04-2012, 01:26 PM   #25
donutfilling
donutfilling's Avatar
Drives: frs
How would you guys say the stock brake-pads hold up on track? fine for 20 min sessions in HPDE?
donutfilling is offline   Reply With Quote
Old 12-04-2012, 01:29 PM   #26
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
which track? how hard are you driving?
the world is not black and white
Old 12-04-2012, 01:33 PM   #27
G Speed
Drives: Cobalt
of course
of course.. with a lighter car/slightly underpowered IMHO if you don't maintain momentum..your screwed lol
Car is 2700-2800lbs, you should be fine on stock pads, not like you will be getting up to 200kph.. needing to scrub off 100
Old 12-04-2012, 01:45 PM   #28
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
If the stock tires are not as bad as everyone is saying then i say buying a few sets of those will be cheap on these forums since everyone is selling them for $500 a set or less. I guess it would make more sense to learn the car with cheaper summer tires then spend the money on expensive summers.
I want to run with the stock tires but one of them has a chunk missing from the sidewall from a stupid curb. I know it wont pass tech.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs Tracking / Autocross / HPDE / Drifting 0 08-14-2012 06:46 PM
Element Tuning Track Tested and Track Proven FRS Video Element Tuning Tracking / Autocross / HPDE / Drifting 47 07-17-2012 04:12 PM
$110 Track day at Willow Springs- Big Track -May5 in SoCal Louie Southern California 3 05-04-2012 01:05 AM
$110 Track day at Willow Springs- Big Track -March24 in SoCal Louie Southern California 1 03-10-2012 01:31 AM
