Old 11-30-2012, 11:13 PM   #29
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I think this is what the doctor ordered should help with the over steer issue too.
jdzumwalt is offline   Reply With Quote
Old 12-01-2012, 12:45 AM   #30
gmookher
theres really no need to preload...
Old 12-02-2012, 01:10 PM   #31
jdzumwalt
Motor Sports slut
Pre loading seems like a bad idea.
Old 12-02-2012, 01:30 PM   #32
jdzumwalt
Motor Sports slut
Does anybody have a comparison of the dampeners VS the KW.
Old 12-03-2012, 11:09 AM   #33
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
question time
i am not an engineer and my understanding of physics is limited to a certain degree of mcgyverism
but my understanding is that sidewall deflection happens on two axis and while your bolts may do more than enough laterally can you reasure us with some tech-talk that the independent vertical loads are not a concern for the small hardware? i'm thinking of the torquing forces on such a small area.
i've attached a crude diagram to explain my thoughts, which could be entirely incorrect but i'm open to education
Old 12-03-2012, 11:26 AM   #34
GC86
Drives: Ft86
Originally Posted by 7thgear View Post
question time
Simple answer. The design, material and dimensions chosen are laterally rigid, but not vertically rigid.
That is the reason why the bar looks like it does.
I notice you specifically chose the phrase "small hardware". Thank you for pointing out that modern metallurgy can produce an incredibly strong bolt in a small size.
In fact, the size of the fastener used for the connecting rods in a built WRX motor is also 3/8 inch, and is good for over 400hp at 7500 rpm. This means an acceleration of zero to full stress 125 times PER SECOND. And they don't break either.
GC86 is offline   Reply With Quote
Old 12-03-2012, 11:28 AM   #35
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by GC86 View Post
Simple answer. The material and dimensions chosen are laterally rigid, but not vertically rigid.
and this isn't a concern in the intended application?
which i guess it wouldn't be because the vertical deflection must be minimal... but still i'm just curious
Old 12-03-2012, 12:42 PM   #36
GC86
Drives: Ft86
Yes it is a -mild- concern, which is why it (vertical movement) was taken into account during the design phase.
Old 02-01-2013, 01:08 PM   #37
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Wow, Adam--these Plates are works of art... Can't wait to get them on. Nicely done!!!
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to GTB/ZR-1 For This Useful Post:
Surok (02-02-2013), whataboutbob (02-02-2013)
Old 02-02-2013, 12:37 AM   #38
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
^^^ looks awesome! I went with the pewter also but I have been out of town so I haven't even been able to open them yet to see how they look I will get to see the whole setup in all it's glory on superbowl Sunday when I get to come home and rip into the package like a fat kid and a box of twinkies.
AZFA20 is offline   Reply With Quote
Old 02-02-2013, 01:21 AM   #39
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
Ok i am ordering KW clubsport coilovers, and dont want to spend the extra 1k on the camber plates, do you guys make a rear solid top mount too?
Surok is offline   Reply With Quote
Old 02-02-2013, 07:52 AM   #40
GTB/ZR-1
GTB/ZR-1's Avatar
I LOL'd!!!
Old 02-10-2013, 07:56 PM   #41
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
How much does the full setup weight? & and how does that compare to stock?
I am currently on your website and I would like some of the options explained for me if you could.
Little background of how I drive my car so you can help make the right recommendations- I daily drive my car I also drive a mountain pass at least twice a week avg speed on this pass is 80km/h (50mph). Track day about 2 times a year.
The Koni springs - Sport, Race, Double Adjustable & Custom...
Which one do I chose? & Why?
Desired Spring rates... I thought that would've been determined by which springs i chose... so you have A. Touring, B. Aggressive, C. Race & Custom.
Love the colour options but I feel I want my whole system pewter... is that possible?
Is there Rear Top Mounts?
What would shipping by to Australia?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
The Following User Says Thank You to DriftEightSix For This Useful Post:
RJasonKlein (04-12-2015)
Old 02-10-2013, 08:15 PM   #42
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Are the camber plates compatible with the Racecomp Engineering Tarmac Coilovers?
JDKane527 is offline   Reply With Quote
Ground Control faq/video/picture/ideas thread GC86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 57 03-29-2014 10:54 AM
Ground Control for 86/FRS/BRZ phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-14-2012 07:56 PM
Considering the Ground Control Setup dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 11-14-2012 01:05 PM
Ground Control needs your Help GC_Adam Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 11-13-2012 05:08 PM
Ground Control is working on some stuff for us :) D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-24-2012 06:21 PM
