Old 11-29-2012, 10:41 AM   #15
wbradley
Sarcastic SOB
wbradley's Avatar
Originally Posted by wparsons View Post
Does the relay alone disable the usual DRL's, or was that another step?
The switchback lights act as running lights in white when the running/headlights are on, and they will blink in amber when your four ways or turn signals are activated. They only work when the proper 7440 socket is present, as is the case on the front turn signals on the FR-S.
The electronic flasher relay is installed in the place of a thermal type to prevent the hyperflash caused by using LEDs in the place of incandescent lamps. It is a cleaner and simpler fix than installing 2 big honking load resistors in circuit with the lights.
OP-You could have done a cleaner install of the relay simply by removing then replacing, but no biggie.
wparsons- We probably live near each other, and you are welcome to check out my lighting/mods any time. I am curious still if you will find my HID's unacceptable. Maybe you can install the proper projectors for me too
Old 11-30-2012, 06:12 PM   #16
n8
n8's Avatar
Drives: 2013 FR-S Whiteout
Thanks sirhc for the write-up! I just installed mine today. The install really was pretty simple. The only observation I had was that the area where the stock relay sits is pretty tight and you have to give it a good solid tug (after unclipping the top portion) to get it out.
30% F 15% R Llumar ceramic | JDM clear side markers
| Meng Motorsports HID 6k kit, LEDs | TSI LED switchbacks
Planned: VG Antenna | Red wrapped tails |
Red BPS Short Shifter | waiting for a turbo/supercharger
n8 is offline   Reply With Quote
Old 12-02-2012, 02:20 AM   #17
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Hows the fitment of these bulbs? Electrical tape required?
Chen is offline   Reply With Quote
Old 12-02-2012, 05:19 AM   #18
Joesuede
Drives: Argento FR-S
Send a message via AIM to Joesuede
where to buy? =)
Joesuede is offline   Reply With Quote
Old 12-02-2012, 07:28 AM   #19
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Everything will be plug n play. No tape needed.
Originally Posted by Joesuede View Post
where to buy? =)
We'll be offering these shortly. He was our tester to be sure everything fit and worked as normal.
JWMotoring is offline   Reply With Quote
Old 12-02-2012, 02:25 PM   #20
Chen
Regional Moderator
Chen's Avatar
how many LEDS per bulb?
Old 12-02-2012, 09:10 PM   #21
Squishy86
Squishy86's Avatar
Drives: Your Car
I think when a company comes one with ones that are more of a 5000k or 4300k I'll get them. *hint hint*
Squishy86 is offline   Reply With Quote
Old 12-02-2012, 10:08 PM   #22
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
When i put the LED flasher relay in my tC to prevent hyperflash it made it so when you hit the unlock on the clicker the lights wouldn't flash. Any problems like that here?
Trashed675 is offline   Reply With Quote
Old 12-02-2012, 11:24 PM   #23
sirhc
sirhc's Avatar
Drives: fr-s
No not at all everything works as it should
sirhc is offline   Reply With Quote
Old 12-03-2012, 12:02 AM   #24
Mo707
Mo707's Avatar
The relay is a b**** to take out. Just a heads up! and don't forget to disconnect the battery before doing so!
Mo707 is offline   Reply With Quote
Old 12-03-2012, 06:30 PM   #25
JWMotoring
JWMotoring's Avatar
Drives: FR-S baby!
Which color is everyone interested in? I was thinking of going with white at first. Maybe the switchbacks and amber is a maybe as well.
Old 12-03-2012, 11:07 PM   #26
sirhc
sirhc's Avatar
Drives: fr-s
This is why I left the stock relay in its place, I unfortunately have a tendency to break those clips so used the open part in the back of the relay to run a ziptie through
Old 12-04-2012, 10:06 PM   #27
sirhc
sirhc's Avatar
Drives: fr-s
fixed my write up and I apologize for what ever reason I was under the impression that the relay was only for the switchbacks. This relay is for any of the LED's and keeps your blinkers from hyperflashing
chris
Old 12-05-2012, 01:56 AM   #28
chris's fr-s
@theexquisite86
chris's fr-s's Avatar
Drives: 2013 Firestorm FR-S
Offer switchbacks I'll buy now
chris's fr-s is offline   Reply With Quote
Are Switchback Turn Signals Legal? i_4got CANADA 7 11-03-2012 05:47 PM
Custom turn signals? benlevy3 Cosmetic Modification (Interior/Exterior/Lighting) 2 11-01-2012 03:23 PM
Need help with LED turn signals. Khalis Cosmetic Modification (Interior/Exterior/Lighting) 8 08-11-2012 11:23 PM
Amber Turn signals to yellow? deedz Cosmetic Modification (Interior/Exterior/Lighting) 1 08-01-2012 02:44 AM
Simple One: Clear Turn Signals Spaceywilly Cosmetic Modification (Interior/Exterior/Lighting) 37 07-26-2012 02:03 AM
