View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 11-30-2012, 02:10 PM   #1135
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
My car just started first chirping at 3000 miles, only shell v power used
shu5892001 is offline   Reply With Quote
Old 11-30-2012, 02:49 PM   #1136
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Supermassive View Post
I got mine done and within 1000 miles the chirping was back...and now it's louder than it was before. I can actually hear it with my windows up.
Same here. I had it replaced, and on my drive to work that day it was chirping again, only this time louder than before.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 11-30-2012, 03:04 PM   #1137
dsgerbc
Drives: BRZ(sold), STI
Now this is interesting. Shell V power in Ontario is ethanol-free. Which means ethanol only speeds up the development of crickets, and is not the primary reason for the noise.
Old 11-30-2012, 03:40 PM   #1138
shu5892001
Ontario's FT86
Yep, only V power used from day 1, chirping just started after 3000 miles. Chirping started after a hard drive and went away on next start up, but it's happening more often, although not very loud
Old 11-30-2012, 03:45 PM   #1139
frsvr4
Drives: '13 FRS
How many miles did it have?
500+ I believe.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
Old 12-01-2012, 09:30 PM   #1140
archaeauto
Drives: BRZ, 1968 Chevrolet Impala Coupe
I haven't noticed chirping on my BRZ at all. It's got just over 500 miles on it right now.
archaeauto is offline   Reply With Quote
Old 12-01-2012, 09:43 PM   #1141
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
Same here. I've been using Shell V-Power since day one as well. The chirping started around ~1500 miles. It's not bad, but I hope Subaru and Toyota are working on a permanent fix and not just a hand out the same old same old.
n8dog11914 is offline   Reply With Quote
Old 12-01-2012, 09:53 PM   #1142
ToxicSneakers
Deleted
ToxicSneakers's Avatar
Chirps 'til 2800 miles and replaced high pressure fuel pump. Now +500 @3300 miles not a peep.
ToxicSneakers is offline   Reply With Quote
Old 12-11-2012, 11:48 AM   #1143
xdbuix
Drives: 2013 Galaxy Blue Limited BRZ
did u take it back? What's going on with your situation?
2013 Galaxy Blue Limited Subaru BRZ
DEAD 1994 Camry 9-21-2012
xdbuix is offline   Reply With Quote
Old 12-11-2012, 12:10 PM   #1144
Celica00
Celica00's Avatar
Drives: 86
meh, had the chriping, got it fixed. then 100 miles later it started again and worse than before.
Celica00 is offline   Reply With Quote
Old 12-11-2012, 12:52 PM   #1145
jeebus
I had chirping starting at 700 miles or so. The chirping got a bit louder over the next 4000 miles. Since around 5000 miles, the chirp has gone away on its own. I didn't change anything, still using the same gas stations, still AutoX every month. I'm at 6500 miles now. I'm wondering if the winter-blend gas is keeping the chirp away?
jeebus is offline   Reply With Quote
Old 12-11-2012, 02:24 PM   #1146
dj_mallu
dj_mallu's Avatar
Drives: BRZ-L Black
Originally Posted by 03Z33 View Post
Proof? Do you have a VIN for a BRZ that's had the fix and makes the noise?
Not doubting you, just that according to SOA there is no one coming forward.
03Z33, can you do an update on your situation? Any chirps now??
Xbox live: SealTeam6Member
Car: BRZ Limited
dj_mallu is offline   Reply With Quote
Old 12-11-2012, 03:40 PM   #1147
dawnst3ar
Drives: 2013 MT FR-S Asphalt
First cold day of the year, really. Took my wife to dinner and stopped at a drive through to get coffee on the way home. Roll down my window, and what do I hear? Damn crickets from the fuel system again.
Guess I'm heading to the dealer on my way to work tomorrow.
dawnst3ar is offline   Reply With Quote
Old 12-11-2012, 04:44 PM   #1148
dsgerbc
You probably developed a mental block for the noise
I went from 1k to 7k miles with the chirp until the first TSB attempt. It would get a bit quieter with cooler weather, but mostly due to different load on electrical system and hence different rpms; and due to harder driving being required to properly warm up the system. It's was around freezing here just before my second pump install, but I'd get it to chirp every time after an enthusiastic drive. If I drove like a grandma (or in heavy traffic) I would not get the chirp with cool weather.
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
