#71 |
Drives: 2013 scion frs firestorm m/t
Do you mind sharing wheel specs please?!?!! I just got some 18x9.5 +20 with falken 512 in 225/40 is this some what like what your running? Im just asking about your wheel specs to see if i will be sitting something like this...
#72 | |
Drives: FR-S, NA8, S13
its good you went with the falken 512 because they fit a little smaller and that size is more like a 215... should fit good. |
#73 |
Thanks, did you have to do alot of fender rollong? Also hows the rubbing and how many degrees of camber are you using? Thanks and sorry for so many ??'s but this is the first car i do low offset fitment on so im still a noob!
#74 |
#75 |
Yea, i havent got them yett, i will either get the bc ones or the megan track series, i was told i should go with. 10k/8k spring rate so it would be stiff and i wouldnt rub as much...
#77 | |
you will need to make the car pretty low with a good bit of camber to make these look good in all honesty... otherwise youll have mexipoke. im running about -3º all the way around. |
| The Following User Says Thank You to ebphoto For This Useful Post: | Junebug (11-30-2012) |
#78 |
I figured i would need something that. Im hope i can get away with it if not i will probably just go with like a +35 offset... Thanks for the help!
#79 | |
Forgot to add thats with pulled fenders front and rolled rear.
a 9.5 +35 would be about perfect... you could get rid of some of the camber all the way around and still be low. |
#80 |
car too low for toyota racks... -___-
free oil change... my labor. damnit. |
| The Following User Says Thank You to ebphoto For This Useful Post: | nix (12-19-2012) |
#81 |
I was wondering about that.
Did you raise it up and take it back to the dealer after? |
#82 |
no... told them i was just going to do it cause i have a track day and they just gave me what i needed.
will have to raise it to get the crickets removed whenever they get the parts in though. |
#83 |
diff. magnetic drain plug completely covered in sludge..
#84 |
Drives: 97 DB8
love the direction your going to be keeping an eye on this car
| Scion Ride and Drive- Good Info Inside, straight from Scion District Managers! | clevrname | Scion FR-S / Toyota 86 GT86 General Forum | 29 | 06-16-2012 08:39 AM |
| Scion FR-S Arrives at Scott Clark Toyota Scion | sctcmediaman | Dealer Cars | 48 | 06-07-2012 05:34 PM |
| Scion FR-S VIP video (posted by scion canada) | Saibot | CANADA | 5 | 03-09-2012 12:15 PM |
| sorry folks, Scion FRS will have Scion badge on steering wheel | CyberFormula | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 27 | 12-05-2011 01:36 AM |
| Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion | UriarteMD | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 19 | 06-14-2011 07:13 PM |
