Old 11-30-2012, 04:38 AM   #71
Junebug
Junebug's Avatar
Drives: 2013 scion frs firestorm m/t
Do you mind sharing wheel specs please?!?!! I just got some 18x9.5 +20 with falken 512 in 225/40 is this some what like what your running? Im just asking about your wheel specs to see if i will be sitting something like this...
Junebug is offline   Reply With Quote
Old 11-30-2012, 12:27 PM   #72
ebphoto
Drives: FR-S, NA8, S13
you will be 5mm more aggressive than my work setup as I am at x9.5 +25.
its good you went with the falken 512 because they fit a little smaller and that size is more like a 215... should fit good.
ebphoto is offline   Reply With Quote
Old 11-30-2012, 12:32 PM   #73
Junebug
Junebug's Avatar
Thanks, did you have to do alot of fender rollong? Also hows the rubbing and how many degrees of camber are you using? Thanks and sorry for so many ??'s but this is the first car i do low offset fitment on so im still a noob!
Old 11-30-2012, 12:48 PM   #74
ebphoto
on adjustable coilovers?
Old 11-30-2012, 12:59 PM   #75
Junebug
Junebug's Avatar
Yea, i havent got them yett, i will either get the bc ones or the megan track series, i was told i should go with. 10k/8k spring rate so it would be stiff and i wouldnt rub as much...
Old 11-30-2012, 01:30 PM   #76
ategs1992
ategs1992's Avatar
Drives: Black BRZ
how much of a drop? any other suspension mods besides the coils?
ategs1992 is offline   Reply With Quote
Old 11-30-2012, 01:58 PM   #77
ebphoto
alright... you may need arms or the whiteline bushings for the rear if you have to do more camber than what the static drop gives you.
you will need to make the car pretty low with a good bit of camber to make these look good in all honesty... otherwise youll have mexipoke.
im running about -3º all the way around.
The Following User Says Thank You to ebphoto For This Useful Post:
Junebug (11-30-2012)
Old 11-30-2012, 02:03 PM   #78
Junebug
Junebug's Avatar
I figured i would need something that. Im hope i can get away with it if not i will probably just go with like a +35 offset... Thanks for the help!
Old 11-30-2012, 02:17 PM   #79
ebphoto
Forgot to add thats with pulled fenders front and rolled rear.
no worries man!
a 9.5 +35 would be about perfect... you could get rid of some of the camber all the way around and still be low.
Old 12-04-2012, 10:04 AM   #80
ebphoto
car too low for toyota racks... -___-
free oil change... my labor. damnit.
nix (12-19-2012)
Old 12-12-2012, 12:18 PM   #81
NemeGuero
I was wondering about that.
Did you raise it up and take it back to the dealer after?
NemeGuero is offline   Reply With Quote
Old 12-12-2012, 03:55 PM   #82
ebphoto
no... told them i was just going to do it cause i have a track day and they just gave me what i needed.
will have to raise it to get the crickets removed whenever they get the parts in though.
Old 12-13-2012, 02:59 PM   #83
ebphoto
diff. magnetic drain plug completely covered in sludge..
Old 12-13-2012, 06:07 PM   #84
jserman
Drives: 97 DB8
love the direction your going to be keeping an eye on this car
jserman is offline   Reply With Quote
Scion Ride and Drive- Good Info Inside, straight from Scion District Managers! clevrname Scion FR-S / Toyota 86 GT86 General Forum 29 06-16-2012 08:39 AM
Scion FR-S Arrives at Scott Clark Toyota Scion sctcmediaman Dealer Cars 48 06-07-2012 05:34 PM
Scion FR-S VIP video (posted by scion canada) Saibot CANADA 5 03-09-2012 12:15 PM
sorry folks, Scion FRS will have Scion badge on steering wheel CyberFormula FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 12-05-2011 01:36 AM
Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion UriarteMD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-14-2011 07:13 PM
