#99 | |
MODERATOR-SAMA
Drives: Swagtron Scooter
and I think ToyotaObsession's question is a little more complex, than a simple resistor in line can answer. Correct me if im wrong, we are are talking about large quantities of energy being stored in a single point temporary for use, and all that energy must move seemlessly for the driver. And the concern is using the switching system via ECU, and the complication from using multiple power sources that are not tied together. EG Once the Capacitor switch is pulled, it should disconnect the source from the battery from the circuit, in fear of energy being backfed? Also the saftey of this system, while batteries hold lots of electricity, it seems like capacitors stores lots of unstable energy. During a colision or a sudden malfunction holding a full charge in the capacitor sounds scary and complicated to control. I use 2 batteries in my rx7, one powers the fuel pump and other electronics. The other powers the ECU, and both are tied to a circuit breaker box i built behind the passenger seat. Id think with a proper ECU regulating something like a digital circuit breaker, all those question and fears could be put to rest.
#100 | |
MODERATOR-SAMA
I think thats a bit different from charge decay, it almost seems like the purposely built the capacitor to discharge or loose energy from the capacitor after a short amount of time.
#101 |
Drives: Lexus IS-F
You could integrate ultracaps into the battery system using a buck boost convertor?
Run on bats normally, acceleration would see voltage drop, kick in caps. Opposite would charge caps. Not sure what you mean by unstable energy? Just think of cap = battery. How have you hooked up your dual battery system? |
#102 | |
Drives: Lexus IS-F
#103 |
Drives: '06 AM V8V Coupe
So I think power regulation ultimately isn't that hard to do, but ToyotaObsession brings up a good point: If we are to release all this energy in a short period of time, how should it be done in the best way (to improve performance, driving experience, efficiency, etc.)? With just a fat battery pack we don't run into this issue since the battery has enough energy to last more than a run to the top speed of the vehicle, or something like that. If we are to attempt to use the high peak power of an ultracapacitor, how quickly we use that energy, how much do we use in proportion to the main engine under partial power circumstances, how do we make it predictable and controllable for the driver, are all things that need to be done.
I don't think safety is that big of an issue in particular, it's no different from the risk of a lithium ion battery exploding or shorting or something. |
#104 | |
Drives: Lexus IS-F
Yeah, your right, my boss said they get huge charge very quickly by having extremely thin dielectric (insulation between the carbon plates). It would dissipate rather quick too. So yeah, it's to store as much energy as possible in the quickest amount of time. |
#105 | |
MODERATOR-SAMA
I have my batteries run on an isolator thats connected to a circuit breaker, w/ a rear quick disconnect. Originally i was required to have a battery disconnect switch and fuel pump switch at this racing sanction i was trying to join. So I ended up wanting to use a separate power system for my fuel pump and starter. It got complicated and i eventually didn't make the race. But it turned out great, because I didn't have to worry about electrical load when I switched to a 2 pump parallel fuel system, and a HKS TwinFire CDI ignition and MSD coils, which was really demanding when i was at 7000-8000rpms.
#106 | |
Drives: Lexus IS-F
As for seamlessness of capacitor discharge, you could easily set it up with a variable resistor to control a variable rate of discharge. Wouldn't seem hard to tie in with motor load or throttle position or both? |
#107 | |
MODERATOR-SAMA
My batteries are always around 75%-90% with the way its set up. I had to get a 180amp alternator to run a good charge without overworking. I am always worried that i might overcharge a battery. But i have the breaker set up so that both batteries are being drained at the same time which is pretty bad for the alternator. But fantastic great for the distribution of energy on my rx7.
#108 |
Variable resistor D: I hope you don't mean using that to directly control discharge.
But a converter that puts out constant voltage with variable input is not hard to do, neither is it hard to change that voltage. Of course we're not just going to switch on the capacitor with the motors and let it rip the tires loose, but there needs to be refinement in power delivery that people expect. |
#109 | |
Drives: Lexus IS-F
#110 | |
Drives: Subaru Legacy
I Read a very interesting artical on it. They are getting cheapper to manifacture all the time.
I'm sick of these mother f***ing earthquakes on these mother f***ing plains.
#111 | |
Drives: Lexus IS-F
#112 | |
MODERATOR-SAMA
