Old 11-02-2012, 04:27 PM   #113
Dezoris
Dezoris's Avatar
The hoses needed:
The intake manifold barb is 1/2"
PCV Valve Barb is 11/32"
The Following User Says Thank You to Dezoris For This Useful Post:
Basket Case (06-09-2014)
Old 11-05-2012, 01:37 AM   #114
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Watching
soros151 is offline   Reply With Quote
Old 11-10-2012, 10:52 PM   #115
MANDALAY
Drives: MR2
Sometimes its worth to see what other cars have installed/designed.
This is a great design , absolutely a work of art, all billet and blends in like an OEM part.
Works which is the key and is cheap at $179. One of the highest upgrade parts in the BMW scene
http://www.google.com.au/url?sa=t&rc...DeboWslkVSBpCA
MANDALAY is offline   Reply With Quote
The Following User Says Thank You to MANDALAY For This Useful Post:
Ingen (11-10-2012)
Old 11-11-2012, 01:50 PM   #116
Dezoris
Dezoris's Avatar
Nice piece, too bad it does not have interchangeable barb sizes.
Old 11-29-2012, 03:43 PM   #117
Ingen
Drives: Ultramarine FR-S 6MT
how off is it?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 11-29-2012, 05:06 PM   #118
Dezoris
Dezoris's Avatar
Originally Posted by Ingen View Post
how off is it?
That can is: 0.62" OD
The OEM FR-S BRZ Intake Manifold Barb is .50" and the PCV Valve is .425"
soros151 (11-29-2012)
Old 11-29-2012, 06:57 PM   #119
Turdinator
Señor Member
Turdinator's Avatar
Can someone explain to me how the PVC system works on the FA20? My knowledge of these systems is based on pre 80s engines and is clearly floored as looking at the Crawford oil air separator it should create a route for air to bypass the throttle which it clearly doesn't in practice.
1974 TA22 Celica
2013 86 GT
Old 11-30-2012, 11:07 AM   #120
Ingen
Huh. Well what's to stop a guy from getting a bar of hex aluminum off McMaster and spinning out a couple of hose-size-adapters? It doesn't seem too difficult, provided you have access to a lathe, which I will admittedly have to haggle over slightly.
But it's a gorgeous can, MUCH cheaper than the other options I have seen, and appears to be quality.
Tell me why this idea is bad?
Old 11-30-2012, 11:35 AM   #121
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It goes from the PCV valve to the intake manifold. There's another port (not PCV valve though) going to the intake tube that sees less blowby on a NA engine.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-30-2012, 11:35 AM   #122
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
He's not saying it's bad, just that it's going to take more work/parts to make it work.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-30-2012, 12:01 PM   #123
Dezoris
Dezoris's Avatar
I summarized a Toyota SAE Article about PCV Systems:
SAE Toyota Journal About the Importance of PCV Systems in Modern Engines Summarized by Dezoris:
What does the PCV System Actually Do?
The PCV system is designed to recycle engine blow by gasses back into the intake for emissions purposes.
However to do so it requires a variable PCV valve because the amount of blow by gas coming out of the engine down the PCV hose is not always equal to the amount of vacuum at the intake manifold.
So the PCV valve is opened and closed based on the amount of vacuum at the intake manifold and the amount of blow by gasses being vented. This helps to equalize the vacuum and gas pressure to insure smoother engine operation. The air to fuel ration and the tuning for that system takes into account PCV vacuum and air flow.
1. Full Throttle and high RPM = Lower Intake Manifold Vacuum, High Engine Blow By.
In this condition the PCV Valve is forced full open. If there is too much blow by then the breather hose will also be used to vent into the intake hose. This will only occur under high load situations.
2. Lower Throttle, Cruising = Moderate Intake Manifold Pressure, Lower Blow By.
In this condition PCV Valve is half open
3. Idle or De-Acceleration = High Intake Manifold Pressure, very low blow by.
In this condition the PCV valve is virtually closed.
Side Effects and how to Test for Issues:
PCV valve and PCV Hose:
PCV Valve is engine specific to engine tuning, if you use the wrong valve or it becomes clogged the air/fuel ratio computation tends to run rich. Rough Idle, stalling or performance issues could also occur.
Testing for blockage or faulty PCV Valve:
First you want to plug in your OBDII scanner and monitor engine RPM.
Once the car is fully warmed up or your coolant reaches 170 Degrees or higher, clamp off your PCV tube from the PCV valve to the intake manifold. Once blocked engine RPM should drop 50-100RPM.
If it does not you may have a damaged PCV hose or bad PCV valve or the system is clogged.
In this case you may see issues with rough idle or some drivability issues. The PCV line is under vacuum, not the breather hose.
A plugged PCV line will cause higher oil consumption in the crank case.
Breather Hose:
Its primary design is to vent excess blow by that the PCV valve and hose can't pass. Usually only under high load.
If the breather hose is clogged or blocked it will cause higher pressure inside the crank case which can cause higher oil consumption and or more unburned fuel which can contaminate the oil. However a leak in the breather hose wont generally cause any issues.
Used Oil Analysis:
Sending out used oil will help to show if there is a higher level of fuel in the oil which could also track back to a faulty PCV system.
Oil in Intake Tube:
Usually is caused by a faulty PCV valve stuck open restricted PCV hose which will cause more oil in the breather line.
Old 11-30-2012, 12:02 PM   #124
Dezoris
Dezoris's Avatar
Yes, if you like the can and have the tools needed to modify or adapt the barbs on the BMW can go for it.
Old 11-30-2012, 12:38 PM   #125
Ingen
Sweet, sold
This project will be fun. And it'll go nicely (if unrelated) to my DIY armrest that I am going to be working on soon. Eventually.... when I get around to it... yeahhhh...
Old 11-30-2012, 03:30 PM   #126
Razz
Razz's Avatar
Drives: Fast
Your best off putting a filter at the oil end and capping off the air intake side.
No need for catch can.
Razz is offline   Reply With Quote
blow by, carbon build up, catch can, crawford catch can, radium catch can, saikou michi
Catch Can ArKiTeCkT Engine, Exhaust, Transmission 31 09-15-2013 03:07 PM
Oil Catch Can? eblamble3 Engine, Exhaust, Transmission 4 03-15-2013 10:58 AM
where to plug the oil catch can hose... :S dompower Engine, Exhaust, Transmission 29 11-14-2012 12:30 PM
Cusco Oil Catch Can for BRZ/FR-S at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 0 07-01-2012 03:16 AM
Purpose of oil catch can? denverizzles Engine, Exhaust, Transmission 1 06-28-2012 03:55 PM
