Old 11-29-2012, 03:32 PM   #71
03Z33
drift
03Z33's Avatar
Had this TSB, DI Fuel Pump and ECU emmisions recall done yesterday. Less than 2hrs total for all the work. GPS seems to work fine now but still don't know if the XM Traffic works since my trial subscription expired.
03Z33 is offline   Reply With Quote
Old 11-29-2012, 05:12 PM   #72
whtchocla7e
Drives: 2013 FR-S Hot Lava
What is the ECU emissions recall? A California only thing?
Live to drive another day
whtchocla7e is offline   Reply With Quote
Old 11-29-2012, 07:23 PM   #73
03Z33
drift
03Z33's Avatar
ECU software update to enable DTC/CEL when CTS is out of range, required by California and several other states for emissions purposes. This update should also include the revised VVT cam gear tolerances to correct for the idle dip/P0017/P0019 DTC's.
Old 11-30-2012, 02:03 PM   #74
n7011n
Drives: 2013 GBS BRZ Limited 5MT
Had my GPS update done yesterday. It took over 2 weeks for them to get the parts in and when I took it in for service, after sitting in the waiting room for an hour, they discovered the parts delivered from Subaru didn't have the memory card. 1 1/2 weeks later they had the card in and took her back in for the repair. I'm pleased to report that I now have instant lock on the GPS satellites here in Chicago and no issues other than a few greasy fingerprints I need to clean off my dash. This was the first GPS TSB repair they'd done at Napleton Subaru in Schaumburg. I was impressed though with the service I received from their service manager. They set me up with an Outback loaner even though I didn't purchase the car from them (I picked mine up in NY in the first month of release).
n7011n is offline   Reply With Quote
Old 11-30-2012, 04:04 PM   #75
kwood9000
kwood9000's Avatar
Drives: Limited WRB AT6 BRZ
I had to take my vehicle in for the service department to "verify" the loss of GPS issue before they could order the parts. Instead of letting them duplicate the problem I just showed the technician a couple of videos with the issues.
The dealer had to order two parts from different sources – a bracket and the SD card. Make sure they order both and have both on hand before returning.
Before the fix I could count on losing the satellites every day. With the fix I haven’t lost the signal yet. The navigation voice is also different, uses different phrases, and easier to understand, IMO.
kwood9000 is offline   Reply With Quote
Old 11-30-2012, 04:04 PM   #76
kwood9000
kwood9000's Avatar
Duplicated post.
Old 11-30-2012, 11:33 PM   #77
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
I brought mine in for GPS and DI Fuel Pump TSB this week. The GPS now locks on plenty of satellites and has not lost signal yet! Woot!
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 12-03-2012, 02:42 PM   #78
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I called the dealer and gave him the TSB number and my VIN. He said they would order the parts and I didn't need to come in to verify. Haven't heard from him in over a month. Out of sight, out of mind. I'm sure they haven't ordered the parts, and it just isn't a big enough annoyance to take time off work to bring the car in.
Old 12-04-2012, 07:50 PM   #79
xdbuix
Drives: 2013 Galaxy Blue Limited BRZ
just to be completely sure, the GPS update does not touch the antenna on the roof of the car right? everything is done inside the car?
2013 Galaxy Blue Limited Subaru BRZ
DEAD 1994 Camry 9-21-2012
xdbuix is offline   Reply With Quote
Old 12-04-2012, 08:04 PM   #80
kwood9000
kwood9000's Avatar
Doesn't impact the antenna on the roof. The GPS antenna is in the dash.
The Following User Says Thank You to kwood9000 For This Useful Post:
xdbuix (12-04-2012)
Old 12-04-2012, 08:06 PM   #81
xdbuix
Sweet thanks. Just wanted to be sure because I installed the beat sonic antenna on top.
Old 12-06-2012, 12:36 AM   #82
kludger
kludger's Avatar
Drives: '13 Boxter S, '13 BRZ(gone)
Dealer called and said the parts for the GPS TSB were in, so I dropped off the car today and it turns out it was just the antenna bracket that came in but the SD card hadn't come in yet, so I told them to go ahead and do the antenna bracket today and I can bring it back when the SD card comes in.
The antenna bracket seems to have resolved my GPS signal issues and I think the XM satellite receives much better too, in my very wooded neighborhood where I could not get GPS lock before, I now have no problems getting lock and only lost signal once.
I will still take it in for the SD card update once it arrives in case it helps too, but I can confirm the antenna bracket seems to be the major fix.
kludger is offline   Reply With Quote
Old 12-06-2012, 06:46 PM   #83
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
I'm taking mine in for the recall and the tsb. They also told me they can't order parts until I bring it in. I asked if I could send him a video of it happening since I'd prefer not to have to drive 45 mins to be told to come back.
SubaSteve is offline   Reply With Quote
Old 12-22-2012, 02:46 AM   #84
Zadkiel
Drives: CBS BRZ Limited 6MT
Took mine in to get this done, sat there for 1 hour, the guy then came in and said, "We confirmed you fall into the TSB and you need the updates. We're ordering the parts now." It took everything I had not to yell at him and say, "No shit I fall into the TSB. I KNEW THAT! That's why I scheduled this 1 week ago so you could order the parts!"
Back in (Crystal) Black.
Zadkiel is offline   Reply With Quote
Nurburgring Video of Subaru BRZ Coupe / Subaru FR-S / Toyota FT-86 Shows off Handling Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 113 11-21-2020 01:02 PM
Subaru BRZ - RAW Subaru | Official Subaru Australia Ad Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 15 07-20-2012 08:20 AM
Subaru BRZ vinyl wrapped MATTE WHITE , Showing @ Subaru Summer Solstice 2012 Premium Auto Styling Southern California 2 06-22-2012 07:34 PM
Subaru/Toyota Coupe spotted in Socal with Subaru Plates owsiu Scion FR-S / Toyota 86 GT86 General Forum 150 05-25-2011 10:27 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 09:22 AM
