Old 11-29-2012, 11:13 AM   #1
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Automatic transmission question
So does anyone know the stall RPM for the torque converter on the auto?
as mentioned here: http://www.ft86club.com/forums/showthread.php?t=23154
Launch control is available for the AUTOMATIC but the launch control RPM must be set below the converter stall threshold.
anyone know?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 11-29-2012, 11:16 AM   #2
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
Not going to be worth even investigating with a stock converter. I think it's below 2500 RPM.
Useless....
I'd be happy to be proven wrong in any case
CircuitJerk is offline   Reply With Quote
Old 11-29-2012, 12:00 PM   #3
Dipstik-sportech
Dipstik-sportech's Avatar
Put it in gear floor the gas and the brake, see where the rpms stop. Lol.
Old 11-29-2012, 02:19 PM   #4
wparsons
wparsons's Avatar
Why would you want launch control with a torque convertor? The stall speed will do the same thing as launch control without any need for electronic stuff.
flickr
Old 11-29-2012, 03:40 PM   #5
carbonBLUE
Reverse Burnouts
Useless....
We have already discussed this, the rpm is ecu limited when the brake is depressed. I've already tested this.
And it isn't your normal torque converter, it can also lock up. EDIT: And don't misunderstand this concept, every converter locks up once it meets its stall speed(rpm), our converter can lock at any speed the ECU tells it to. Which begs the question, does our converter have an internal, non programmable, stall speed that also works in conjunction with the programmable locking (gears 2-6th). OR is the locking(stalling) mechanism programmable fully, to where we can adjust when the converter starts to lock up (stall) and the smoothness of that locking.
So upon releasing the brake, can the ECU tell the converter to lock up (like dropping the clutch) for an aggressive launch, If we programmed it to do so.
It's about thinking outside the box guys and understand what if?
Also I'm looking at insight on how this specific converter is programmed and designed.
the point of having a rev limit set below the stall rpm is to avoid damage from heat
I ask these questions because in "D" (drive mode) the converter acts loosely (slushy between gears) and in "M"(manual mode) there is no slipping regardless of acceleration, deceleration, and changing gears up or down.
This leads me to believe you can adjust the stall rate and the locking mechanism and it's harshness through ECU tweaking, it's just an educated guess, but non the less needs some investigating.
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
CircuitJerk (11-29-2012)
Old 11-29-2012, 04:27 PM   #6
CircuitJerk
Pull my finger...
I missed that discussion apparently. I'm all about thinking outside the box but there's also another box involved. So yeah, I'm thinking outside the box hahahah JK.
Thanks
Old 11-29-2012, 05:05 PM   #7
carbonBLUE
Reverse Burnouts
Thanks
ohh its fine, there are lots of lost threads and plenty of new members, its ok to go over threads but not beat a dead horse at the same time in any sense... its all speculation, if i had a team to figure it out, i would already have done so...
It's new tech, it takes time to learn and adapt to it
(wont forget you)
2011 Infiniti G37x
Old 11-29-2012, 07:25 PM   #8
CircuitJerk
Pull my finger...
I hear ya. Too much to keep up with!
Time will tell. I love your optimism.
Old 11-29-2012, 07:49 PM   #9
carbonBLUE
Reverse Burnouts
well for us AT folks, someone will find an answer. My celica took 5 years of being on the market before parts like the ones available for the FRS/BRZ/86 were around and our car is only 7 months on the market
(wont forget you)
2011 Infiniti G37x
Old 11-29-2012, 09:09 PM   #10
CircuitJerk
Pull my finger...
Yep. BTW I miss lift
Old 11-29-2012, 10:00 PM   #11
Captain Insano
I really wish a good tuner would look into reprogramming options for the AT software, launch control, shift speeds and points, etc... Also a trans vendor to crack open the AT to look at upgrade options. Like everything I think most of the focus is on the MT cars.
Captain Insano is offline   Reply With Quote
The Following User Says Thank You to Captain Insano For This Useful Post:
carbonBLUE (11-30-2012)
Old 11-30-2012, 10:29 AM   #12
wlfpck
Drives: 2015 GTI
The current shops that are looking into automatic transmission upgrades are as far as I know...
IPT
Level 10
SSP
From a couple months back, there was a post from SSP asking to see if anyone would be willing to volunteer their car as a test car.
If all else fails in terms of programming, there is always MegaSquirt. But that's pretty much a complete blank slate that you would have to program yourself, not to mention that the current stock programming is pretty decent.
2013 GTI - Gone
2015 GTI
wlfpck is offline   Reply With Quote
Automatic Transmission devinclfalcons Engine, Exhaust, Transmission 60 04-29-2014 09:42 PM
Automatic Transmission :( Almighty Bob Southern California 14 11-06-2012 01:13 PM
FT-86, manual or automatic transmission??? luisjr Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 03:00 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Any info on the automatic transmission? ryude Engine, Exhaust, Transmission 31 12-01-2011 05:30 PM
