Old 11-29-2012, 09:28 AM   #1
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
A warning about wheel studs
I installed aftermarket wheel studs and spacers to give me +38mm in the rear. I don't want to run staggered, but I like the look of staggered. Anyways I used a kit very similar to this one:
Ebay link
Well after a week I went to retorque my studs just to be safe and a single stud was spinning in the hub. Shit. Either it was broken or the worst nightmare, it rounded off the hub.
Well these cheap chinese studs were not made up to spec and were a hair smaller than the stock ones. I ended up getting two sets of ARP extended studs and they went in without a hitch.
I was able to bang out the shitty ebay studs with a tiny hammer and almost zero force. I probably could have got them out with my bare hands. The ARP studs would take a sledge hammer to remove.
So don't do something stupid and just use no name wheel studs. This is mostly my fault so I wanted to make sure no one runs into this problem as well.
post_break is offline   Reply With Quote
The Following 7 Users Say Thank You to post_break For This Useful Post:
Beyer Subaru (11-29-2012), Guff (12-07-2012), Jesse (12-01-2012), Maik L (11-29-2012), Rayme (11-29-2012), Sportsguy83 (11-29-2012), whataboutbob (11-30-2012)
Old 11-29-2012, 10:48 AM   #2
empower-auto
Kouki-Monster
empower-auto's Avatar
Use Eibach Trak+ or Project KICS spacers, not junk.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 11-29-2012, 11:16 AM   #3
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
H&R not eibach, i agree i might use Ichiba but would rather use either of those 2.
Old 11-29-2012, 11:21 AM   #4
empower-auto
Kouki-Monster
oops my bad. that's embarrassing lol. time to take some holidays.
next up, Tein turbo kits!
Rich Anderson
EMPOWER AUTO
The Following User Says Thank You to empower-auto For This Useful Post:
JoeBoxer (11-29-2012)
Old 11-29-2012, 11:23 AM   #5
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
The classic "You get what you pay for.". Thank You for sharing your experience and hopefully it will save others the same headaches.
Beyer Subaru is offline   Reply With Quote
Old 11-29-2012, 11:26 AM   #6
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Eibach has theirs also in 5mm and 10mm. The 10mm at least include studs, not sure about the 5mm ones.
Currently I use universal Project KICS spacers as needed (ie if I get a flat on the RPF1s and need to use an OEM wheel over the AP calipers).
I also use ARP studs though
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-29-2012, 11:43 AM   #7
JoeBoxer
JoeBoxer's Avatar
Damn correcting my correction lol, Trak+ are the H&R ones though.
Old 11-29-2012, 11:50 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Wasn't trying to correct really Just adding more info.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 11-29-2012, 11:52 AM   #9
post_break
post_break's Avatar
Just to be clear, the spacers in that ebay link are fine, they are hub-centric and high quality. It doesn't really mater who makes the spacers, just make sure you get hub-centric. Don't skimp on studs.
Old 11-29-2012, 11:55 AM   #10
ebphoto
Drives: FR-S, NA8, S13
guessing arp has part numbers for studs for the fr-s?.. or wha
ebphoto is offline   Reply With Quote
Old 11-29-2012, 11:56 AM   #11
empower-auto
Kouki-Monster
Not all spacers are completely flat. lol .. this is from experience. china has spat out some bad stuff.
Rich Anderson
EMPOWER AUTO
continuecrushing (03-30-2015)
Old 11-29-2012, 12:08 PM   #12
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
to accomodate 38mm spacers - how long were the studs? 70 / 80mm?
anything longer then 50mm, I'd recommend the ARP chromoly studs.
That's a lot of stress on some no-name brand studs.
at least nothing happened while the car was being driven.
Touge Factory is offline   Reply With Quote
The Following User Says Thank You to Touge Factory For This Useful Post:
wparsons (07-08-2014)
Old 11-29-2012, 12:09 PM   #13
Touge Factory
Drives: ZN6
Good points right here!
Old 11-29-2012, 12:09 PM   #14
post_break
post_break's Avatar
They were 10mm spacers.
MAX Spacer thickness for stock studs? FRSpdDmn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 06-09-2016 01:02 PM
broken wheel studs Matt Andrews Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-06-2012 12:47 AM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
Bolt Pattern, Wheel Hubs and Studs Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 03-08-2012 02:49 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
