Old 11-11-2012, 12:16 PM   #15
joergasm
joergasm's Avatar
Drives: Subaru BRZ 2013 - SWP 6MT
Hey everyone it happened again! I tried to put it into reverse and put a fair amount of pressure but it didn't go into gear...but then i tried the suggesting of shifting into second and then shifting into reverse and it worked!
Thanks again guys!!!
joergasm is offline   Reply With Quote
Old 11-11-2012, 01:01 PM   #16
einzlr
Drives: several
Glad to hear it!
Next time it happens, avoid using extra pressure; that won't help anything. Wiggling the shifter might in some cases help, but when you feel resistance the best thing to do is just go right to the clutch in/out or 2nd gear technique. After a while you'll do it without even thinking about it
Asphalt FR-S MT (future)
'05 Hyundai Accent; '01 BMW M Coupe; '01 BMW M Roadster (for sale); '99 BMW Z3 Coupe 2.8l (for sale)
"Simplicate and add lightness." - Gordon Hooton
einzlr is offline   Reply With Quote
Old 11-11-2012, 09:01 PM   #17
jmaryt
Drives: 2012 honda civic ex
Originally Posted by Ranatsu View Post
Its completely normal for a manual transmission car to do this.. Its caused by the teeth not aligning for the reverse gear, so you just put it in 2nd and then into reverse as was stated earlier..
My 04 STi would do this all the time. I'm sure someone will roll in here and give you a full technical reasoning with whats causing it.
this is the correct procedure!
Originally Posted by brbrz View Post
If you really want to know why you sometime cannot put the car in reverse check this out:
http://en.wikipedia.org/wiki/Manual_...ission#Reverse
The long and short of it is that reverse gear is usually built differently than the forward gears. It is not always meshed like the forward gears and usually has no synchro. So if the shaft happens to stop in a position where the reverse gear won't mesh then you can't put the car in gear. Just bump the car forward the tiniest bit and you'll be good to go ( if this is indeed the problem ). I have experienced this with every manual I have ever had.
generally this is NOT necessary! usually throwing the clutch,and "rowing" between the different gears will allow reverse to drop in!
Agreed, avoid shifting into reverse while the car is moving. Just bump the car forward an inch in first and stop, you should have no problem then selecting reverse. Just have to get the gears to move a little so reverse will mesh.
Sent from my Nexus 7 using Tapatalk 2
yes this will work too,however,again,not necessary! "see above!"
jmaryt is offline   Reply With Quote
Old 11-28-2012, 12:41 AM   #18
brbrz
Drives: 2013 BRZ Limited DGM
Going to try rowing next time, I guess I found something that worked and just stuck with it.
brbrz is offline   Reply With Quote
Old 11-28-2012, 12:52 AM   #19
Rich1
Drives: Cadillac DeVille DHS
Same issue
I just got my car this weekend and with ~230kms I had the same issue with reverse today. I couldn't get it to go this morning - temperature outside was about -1C and luckily I could move forward out of my driveway.
Same thing happened later on this afternoon too.
I tired the 2nd gear suggestion and eventually it went into reverse.
Scary needless to say at day 4 of a new car you've waited over 4 months for! I'm hoping it's just a break in period issue.
Rich1 is offline   Reply With Quote
Old 11-28-2012, 01:45 AM   #20
gmookher
hit the gym?
The Following User Says Thank You to gmookher For This Useful Post:
ngabdala (11-28-2012)
Old 11-28-2012, 02:03 AM   #21
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Just park it tail end first that way you don't have to put in reverse the next day
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-28-2012, 11:04 PM   #22
Timtamtt
Timtamtt's Avatar
I had this issue to but i found out you just gotta shove it in, there is a bit of resistence but then itll go in smoothly. At least for me haha
Timtamtt is offline   Reply With Quote
Old 11-29-2012, 12:08 AM   #23
Wattage
Wattage's Avatar
Drives: scion fr-s MT
I've had the same issue with going into Reverse gear.
What I do is either let the car roll a little bit, then stop and try again (I don't know if this actually accomplishes anything but it seems to work sometimes) - or put it into second gear then into reverse like people in this thread recommended.
It does feel like I have to shove it into reverse with some extra force sometimes, but it doesn't feel like it is a damaging amount.
Wattage is offline   Reply With Quote
gear, rear, shifting
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
Top Gear blackfireball5 Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2012 01:58 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
86/BRZ/FRS on Top Gear: When??? FT-86GOD Scion FR-S / Toyota 86 GT86 General Forum 20 07-04-2012 12:08 AM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
