View Poll Results: STI parts - painted or unpainted?
Unpainted 59 39.60%
Painted 90 60.40%
Voters: 149. You may not vote on this poll
Old 11-28-2012, 11:11 PM   #57
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Originally Posted by chanomatik View Post
Get the rear spats now that they're here! Be a test mule!
Already ordered and confirmed with japanparts via email that they will fit with the Subaru rear diffuser.
Originally Posted by japanparts
Thank you so much for your reply and an order. I've just got to hear from STi Japan. They've told me that it can use with Subaru REAR UNDER DIFFUSER (#484-005-005).
The Following User Says Thank You to switchlanez For This Useful Post:
chanomatik (11-29-2012)
Old 11-28-2012, 11:52 PM   #58
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Might be, but at the same time there's 12.8kg difference between those two also. 235 may give more traction... but 3.2kg each side weight on the wheel/tire does cause lack acceleration.
For me, I don't care bout 17 vs 18 or 19 stuff. I gonna test both 17's & 18's w different tires to fit for my need. If 18's give me the traction & movement I want w suspension setup I buy them, I'm totally go w 18's... but crossing my fingers, I'm hoping for 17's. 18 tires aren't cheap
I think the perfect magic size I saw was the Enkei RPF1 in a 18x9.5 with +38
I know they're a bit too wide, but they look sooo good
I'll find the member who has them up soon
Edit: here - http://www.ft86club.com/forums/showthread.php?t=20907
Snoopyalien24 is offline   Reply With Quote
Old 11-29-2012, 12:00 AM   #59
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
iirc that's Meng's FR-S right? If that's the case, I've seen it in person
Snoopyalien24 (11-29-2012)
Old 11-29-2012, 12:11 AM   #60
Snoopyalien24
Mr. Sarcasm
That is one sweeet ride!
Whats a good wheel width? I was thinking 8-8.5
Old 11-29-2012, 12:19 AM   #61
ichitaka05
Site Moderator
ichitaka05's Avatar
Which wheel size? 17 or 18? If 18 w non stagger than 8.5. If you're going 18 w stagger than F18x8 R18x9 37 offset like Moto-san
Old 11-29-2012, 08:41 AM   #62
Snoopyalien24
Mr. Sarcasm
I rather 18 and a non staggered. Cheaper that way too
The Following User Says Thank You to Snoopyalien24 For This Useful Post:
ngabdala (11-29-2012)
Old 11-29-2012, 01:03 PM   #63
xxscaxx
Drives: 2013 SWP BRZ
painted for sure.
xxscaxx is offline   Reply With Quote
Old 11-29-2012, 10:25 PM   #64
86BRZ
86BRZ's Avatar
Drives: BRZ Limited arrived on 9/1/2012
Originally Posted by switchlanez View Post
@Turbowned, @chanomatik, @ngabdala. I weighed the packaging today then subtracted it from the total weight of the packaging+wheel. Approximate weight of one black STI wheel is 18.4 lbs.
Anyone know the stock 17" wheel weight?
86BRZ is offline   Reply With Quote
Old 11-29-2012, 10:41 PM   #65
switchlanez
I believe it was 20.x lbs. Like 20.1 or 20.6... around there.
And I calculated the STI wheel weight by subtracting weights measured on 2 different scales not necessarily calibrated the same. So I wouldn't call it accurate but it's the best figure we have for now.
86BRZ (11-30-2012)
Old 11-30-2012, 02:40 AM   #66
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
You are correct! 20.1 lbs per several pieces of photographed evidence from various forum members, Scooby South being one of them.
I'm still on the fence about the STI wheels. I'd want 18". I kind of don't mind 7.5 width because I actually ENJOY "drifting" on smaller wheels. Everybody keeps going for ULTIMATE GRIP, but in my mind that's more reserved for cars with more torque. For autox I do want much wider wheels, but for everyday driving, I'm actually okay with narrower wheels.
If I do get STI wheels I'm thinking silver since I have a black BRZ.
I can't be the only one that prefers a little looseness in the rear, right?
Old 11-30-2012, 03:07 AM   #67
that_one_guy
Drives: none
+1 on that. I like my cars like I like my women, loose in the rear
that_one_guy is offline   Reply With Quote
The Following User Says Thank You to that_one_guy For This Useful Post:
chanomatik (11-30-2012)
Old 11-30-2012, 11:07 AM   #68
86BRZ
86BRZ's Avatar
So...going to 18" STI wheel save about 2lbs ea, 8 lbs total.
Wonder it can save 9lb or more on STI 17"?
( but then the whole STI lips, skirts, etc add back 10 lbs?)
Old 11-30-2012, 02:57 PM   #69
chanomatik
Snow Don't Hurt!
chanomatik's Avatar
switchlanez wheels are 17x7.5, which are 18.4lbs each, as revealed several posts down. For 18" no one knows for sure, but we presume just north of 20lbs, so comparable to the stock 17x7 wheels, except they'll be 18x7.5 for the STI wheels. That's not too bad if you're not looking for ultimate grip, like mentioned before, and want the look. switchlanez has stated that he prefers to stick with 17" since it's a good weight-saver at that size.
To me, having 18" and a tiny bit more width while still retaining the stock wheels weight isn't terrible, but I could definitely see the appeal of saving more weight. My only argument is that this car is plenty of fun with the stock wheels already, so I wouldn't mind continuing the fun with 18x7.5 with slightly lighter TIRES.
The Following User Says Thank You to chanomatik For This Useful Post:
86BRZ (11-30-2012)
Old 11-30-2012, 04:14 PM   #70
86BRZ
86BRZ's Avatar
You point out exactly and thanks. Plenty of fun as it is now and not sure if I want more grip with 7.5 either in 17 or 18. Thinking back, Toyota/ Subaru was on purpose to use that thin tire now....besides, it is so costly to buy 4 and just to find out if i like otherwise...
Perhaps Switchlanez can be kind enough to share the experience and compare ?
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
FR-S Price Poll: Are you still in, or are you out? KaliKev Scion FR-S / Toyota 86 GT86 General Forum 146 03-30-2012 11:11 AM
Color Poll markitect Scion FR-S / Toyota 86 GT86 General Forum 48 01-13-2012 08:59 AM
The individual age poll tranzformer Scion FR-S / Toyota 86 GT86 General Forum 41 01-05-2012 03:01 AM
