Old 11-28-2012, 03:39 PM   #435
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by SubieNate View Post
@JRitt - I'm not sure if this has been covered here, but what is your opinion on using calipers with no dust boots on the street? Obviously the temperature and use extremes seen would be much less, but on the flip side there is likely going to be much longer periods of time between inspections/bleeds/etc. than on a track only car.
Thanks,
Nathan
Jeff will cover this assuming he's not on a plane going to PRI already, but... do you track your car at all? If so, dust boots are kind of pointless anyways, they will melt/become brittle and dust after the first track day or two.
If this is a purely street car in question, wait for the formula kit
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 04:41 PM   #436
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I'm hoping to track my car, eventually.
Nathan
SubieNate is offline   Reply With Quote
Old 11-28-2012, 05:57 PM   #437
CSG David
CSG David's Avatar
Nathan
A set of good dedicated brake pads and brake fluid will do the trick. Most people underestimate how good the OE brake system is from the factory. We have the AP Racing kit for our future development in the upcoming time attack season.
Old 11-28-2012, 05:59 PM   #438
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You've been more lucky with yours than I have.. after the rotors delaminated I didn't want to run them again
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 06:11 PM   #439
CSG David
CSG David's Avatar
What did you do to your car?!?!?!
Old 11-28-2012, 06:13 PM   #440
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Can't wait to see the Formula setup, the others are overkill for my needs.
Old 11-28-2012, 06:44 PM   #441
mike2100
mike2100's Avatar
Drives: 23 BRZ
I remember someone smart saying that its not recommended to use calipers without dust boots on streets that may see road salt. That seems to put some folks between a rock and a hard place. I want to track the car regularly and daily drive it! What if it snows?!
mike2100 is offline   Reply With Quote
Old 11-28-2012, 07:14 PM   #442
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
See here: http://www.ft86club.com/forums/showp...&postcount=156
After just a couple of track days..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 07:14 PM   #443
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Oh I don't know.. no snow here
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
track_warrior (12-06-2012)
Old 11-28-2012, 07:35 PM   #444
SubieNate
SubieNate's Avatar
I'm asking out of curiosity as much as anything else. Plus I just think a nice set of fixed 4+ piston calipers with two piece rotors just looks awesome. I'm not immune to the desire to a bit of functional ricing.
Nathan
Old 11-28-2012, 08:10 PM   #445
CSG David
CSG David's Avatar
That is actually kind of weird. I don't know how that's possible, but it sure does make for an excellent prop. We must seriously be special if we can be so easy on the brakes while doing the things we do on a consistent basis.
Excellent pictures btw. Are you loving your AP Racing kit? We seriously are in love with it.
Old 11-28-2012, 10:54 PM   #446
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Yeah I've never seen a rotor like it either. The pads looked fine still. :shrug:
Yeah the AP Racing setup is working great! No complaints at all
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-01-2012, 09:19 PM   #447
Hanakuso
Got mine installed. Thank you Jeff for helping me out with the issue I had! Btw, I noticed a clicking sound (Sounds like putting a card in the spoke of a bicycle) and I narrowed it down to the contact between the pad and rotors. Is this normal? I'm thinking its coming from the J-hooks. I did notice Hawk HPS pads have 1-2mm more depth then the C300 so it's constantly making contact to the rotors. Maybe that's why it's clicking but I'm not 100%
Edit: Btw I checked the clearance with the OEM spare tire and it fits with a 20mm spacer. I'll double check later to make sure clearance is good enough.
Hanakuso is offline   Reply With Quote
Old 12-03-2012, 12:05 AM   #448
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Wow!! I finally got to test the car with the Sprint kit at the track and what a difference. I had a quick battle with an instructors NC MX-5 and after 15+ laps the brakes showed absolutely no signs of fade. The confidence inspired by the brakes made my post my best lap time so far , i went from a 1:31.3 to a 1:29.8 with just brakes . Cant wait to test them out with the R1'S. Ill write a review on my build thread soon.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
The Following User Says Thank You to track_warrior For This Useful Post:
WillRacer1jz (12-03-2012)
BC Racing Coilovers with Free Stainless Steel Brake Lines!!! Dustin@Dynosty Brakes, Suspension, Chassis 21 01-08-2013 10:34 AM
SS Racing Brake Line K1 Motor Works Brakes, Suspension, Chassis 5 06-29-2012 02:36 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
