Old 11-28-2012, 01:12 PM   #1639
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Originally Posted by Ravenlokk View Post
For stage 2? Couldn't find any confirmation from AVO in the thread. Toooo many pages!!
Because they didnt mention any changes to the downpipe, im assuming the downpipe is the same for both stage 1 and 2. Realistically downpipe size at 2.5 will be good for more than most people will get out of this car. I talked to Paul and he said you can pretty much change anything on this kit and I will probably be opting for the 3" variation.
Tansey86 is offline   Reply With Quote
Old 11-28-2012, 02:20 PM   #1640
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by AVOturboworld View Post
Flywheel torque?
This isn't wheel torque fellas.. let's see the wheel torque.
Peak torque really looks like about 219-220ftlbs, quite a bit different from 254..
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 02:29 PM   #1641
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
I feel like there isn't enough transparency with this kit.
Flywheel torque?
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-28-2012, 02:39 PM   #1642
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Flywheel torque?
The screen says flywheel but that is at the wheels, i'm pretty sure Crawford's dyno says the same thing i don't know why it is confusing.
Old 11-28-2012, 02:40 PM   #1643
Tansey86
Tansey86's Avatar
It says flywheel but it is actually wheel horsepower. This misconception has been covered several times I believe. Stage 1 is 230rwhp, do you really think they lost 10rwhp by upping the boost and finishing the exhaust?
Old 11-28-2012, 02:53 PM   #1644
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Flywheel torque?
It is a Dynopack Dyno. Crawford has the same deal and Perrin too. These Dynos call "Flywheel HP" the wheel hubs.
Just as a quick example,
This is Perrin's chart. He already explained why it is as well as Crawford as well as AVO.
Old 11-28-2012, 03:09 PM   #1645
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
Transparent enough?
[ame="http://www.youtube.com/watch?v=315BAOsePsk"]Drift-Office : AVO TurboWorld 6MT FRS Turbo Kit ~ Stage 1 - YouTube[/ame]
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 11-28-2012, 03:16 PM   #1646
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
That's even worse. That means the graph is a lie.
It mathmatically does NOT work. If you know the RPM and either HP or TQ you can mathmatically determine the other, and the numbers DO NOT work in the posted graph.
Example, if we have torque and RPM, we determine horsepower by: HP=TQ*RPM/5252. If we have HP and RPM, we determine torque by: TQ=5252*HP/RPM
So, if we use the spot they have a cursor on around 3225rpm, they show basically 254lbft of torque and approx 137-138hp, but lets call it 140.
If we do the math...
HP=254*3225/5252
HP=156HP
TQ=5252*140/3225
TQ=228lbft
So if we use EITHER of their provided numbers at a set RPM, it simply DOES NOT work. You can pick any RPM, I did so with a few and the results were always the same - the graph doesn't make sense if both are wheel numbers.
So take you pick, both are wheel and the graph is a lie or one is calculated somehow. Both can't be wheel and accurate. Unless the Dynopack changes the fundamental definition of the relationship between HP and TQ of course.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Last edited by Dave-ROR; 11-28-2012 at 03:21 PM. Reason: oops fixed a bad typo. Meant "can" wrote "can't"
Old 11-28-2012, 03:22 PM   #1647
Sportsguy83
Drives: Limited BRZ
It mathmatically does NOT work. If you know the RPM and either HP or TQ you can't mathmatically determine the other, and the numbers DO NOT work in the posted graph.
HP=254*3225/5252
HP=156HP
TQ=5252*140/3225
TQ=228lbft
This has already been explained too. That Dyno graph shifts up the Torque side so that peak HP and peak TQ are in the same level line. Look at the torque scale on the left, you will see a different number then the HP scale on the right (this is the shifting). That is why they don't meet at 5252.
The numbers are not Lying. It doesn't say 279 TQ and 279 HP, it says 254 TQ and 279 HP, they look like that only because of the torque shift up. And again, it was not intended to mislead, as AVO had already explained it.
Old 11-28-2012, 03:24 PM   #1648
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
This has already been explained too. That Dyno graph shifts up the Torque side so that peak HP and peak TQ are in the same level line. Look at the scale on the left, you will see a different number then the scale on the right. that is why they don't meet at 5252.
I'm not talking about where they cross, that's obvious.
Look up how to determine HP from TQ and RPM, the scale of a dyno chart doesn't mean ANYTHING. They could have provided just HP and RPM in a chart and you can calculate the torque.
The dyno itself doesn't even measure both, it calculates HP from TQ and RPM.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 03:26 PM   #1649
ngabdala
This kit just hasn't been through legit testing . Don't get me wrong I want this kit. There's more to a kit than dyno charts.
Where's the application on a track or even on the street? The videos are vague and I'd hardly call a drive to SEMA and a drifting clip a real test.
Old 11-28-2012, 03:28 PM   #1650
Sportsguy83
Drives: Limited BRZ
Oh yeah, I did not read the mathematical portion of your post and you are correct. It does not add up.
The only thing I can say is that it has been said since day one that Dyno chart is on Japan, and the Dyno chart to go by in the USA adds up and makes sense, the one that was done in Oregon for 230 HP and 198 TQ.
Here's the USA Dyno chart:
Old 11-28-2012, 03:33 PM   #1651
Tansey86
Tansey86's Avatar
Yeah i guess data logging 1500mile road trips through every type of weather and below sealevel to 6000ft isnt enough. Read the first post, this kit has more r&d than any other kit in my opinion
Old 11-28-2012, 03:33 PM   #1652
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by deucethemoose View Post
Transparent enough?
Hey, look at that, a quick check shows that math works.
Has nothing to do with the graph I was talking about from the JDM office though...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
