Old 11-26-2012, 04:39 PM   #1
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Bazooka tube sub?
Ok. So I'm in need of bass. I miss it way too much. Lol. My problem is space (who's isn't though). I'm not a huge audio guy and am not looking to spend much at all on audio. Stock speakers are great and the HU is ok for now. I don't want to drop 300+ on a stealthbox or whatever and thought of the Bazooka tubes. Small, seems easy to remove if needed, and relatively cheap. I am coming from a pair a 12 Sony Xplods running off a Rockford amp and they did a damn good job as far as I'm concerned. With this in mind will the sound disappoint me? I'm looking at getting a 10" this time. TIA.
Old 11-26-2012, 05:08 PM   #2
fender9530
fender9530's Avatar
Drives: Asphalt FR-S
I used to have an 8" Bazooka in my GTi. It had its own amplifier...which was tiny. I really enjoyed the sound. It won't be anywhere near your 2 12" subs but will definitely sound better than stock. I'm thinking about picking up another soon but need to find a good location.
It's also easy to remove if you need extra space at some point. Just one connector and it's out.
fender9530 is offline   Reply With Quote
Old 11-26-2012, 07:01 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I bought one of these. It's a small sub with a integrated 100 watt amp. wx-50 pioneer I believe. They came stock in the rsx type s. It fits into the spare tire. basically replacing the chunk of foam that does nothing.
Bazooka tubes are good. They fill a niche.
TheGuyWithTheFireStorm (11-30-2012)
Old 11-26-2012, 07:58 PM   #4
bebopblues
5th Hairpiner
bebopblues's Avatar
Drives: 2015 FR-S RS 1.0
I got the 8" bazooka pre-amped sub installed. Adds plenty of bass for my taste.
bebopblues is offline   Reply With Quote
Old 11-26-2012, 08:34 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
how is the sound quality of these?
thanks
Nardi330 is offline   Reply With Quote
Old 11-26-2012, 09:55 PM   #6
rmjjensen
rmjjensen's Avatar
Drives: 2013 Subaru BRZ Limited in WRB
In the past I used concrete sonotube form with MDF rings to create a quick "Tube" enclosure. It sounded great and was cheap to put together.
rmjjensen is offline   Reply With Quote
Old 11-26-2012, 10:09 PM   #7
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
I have used powered Bazookas in both my Supra and the 240z, best bang for the buck installation and sound-wise. I did see the S/O powered sub from Crutchfield in their latest catalog, it looks nice. Smaller footprint, but same difference. I won't use the Bazooka in the FR-S because I want the full tire-loading experience and I am pretty happy right now with the stock stereo.
Eric G
mkiisupra is offline   Reply With Quote
Old 11-27-2012, 12:51 PM   #8
finch1750
finch1750's Avatar
Thanks guys. I think the Bazooka is what I'm looking for. Good sound, fits in the trunk, and easy to remove when needed. Now let me see if I can manage to sell my Rockford amp for enough to pay for it. Haha
Old 11-27-2012, 01:39 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
thanks
Its a 5.25" woofer with a built in 50watt RMS amp. It cost me $79 off ebay. I think they used to be $199 new. Anyway, the sound quality is good for a 5.25. It isn't going to impress someone down the block, or probably even outside the car. It adds some bass and doesn't take any of the prime real estate.
I have not upgraded the door and dash speakers yet, but plan too. I have a nice Class a/b amp that I plan on using for them. I figure then I'll be happy with the sound.
Old 11-29-2012, 02:29 AM   #10
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Where are you guys mounting the Bazooka straps? My thoughts were to mount it on the passenger side of the trunk with the sub facing to the back of the vehicle. The problem I am running into is that the manual suggests having the plastic brackets on the bottom, but this will not work for two reasons:
1) It would make the spare inaccessible
2) There is styrofoam under the trunk carpet
I'd like to keep the damage to a minimum with the install. Any suggestions?
OjiGeorge is offline   Reply With Quote
Old 11-30-2012, 12:16 AM   #11
zooki
Drives: waiting on a 2021...
I have my Bazooka strapped down to a piece of 1/4" plywood. It's about 16" wide, and as long as the sub is. I'll carpet it eventually. It fits in the trunk, doesn't move around at all, and is easily removable if I need to get to the spare.
zooki is offline   Reply With Quote
Old 11-30-2012, 06:23 AM   #12
gonzo
Drives: frs
There is no audio product that will ever disappoint you. Get the Bazooka.
If you find some extra change in the couch get this for the backseat:
[ame="http://www.amazon.com/JL-Audio-CP108LG-W3v3/dp/B001UDIGAC/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=3KTJ107GS04I8 &coliid=IOBWQ8XRDCMEA"]Amazon.com: JL Audio CP108LG-W3v3: Car Electronics[/ame]
gonzo is offline   Reply With Quote
The Following 2 Users Say Thank You to gonzo For This Useful Post:
finch1750 (11-30-2012), OjiGeorge (12-01-2012)
Old 12-01-2012, 04:18 AM   #13
OjiGeorge
OjiGeorge's Avatar
Just finished installing the BTA10250D..
This isn't going to impress an audiophile; but when properly adjusted it sounds pretty decent. I've had the crazy systems when I was a wee grasshopper and I'm over it. For the 86 this fits the bill very well.
At $200, I don't know how you could possibly best it. It's an inexpensive, self contained setup that sounds pretty darn good. It's fairly light weight if you compare it to a full box+sub+amp set up. The only improvement would be in the mounting department. I'd def buy this again.
Old 12-01-2012, 05:40 AM   #14
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I added the JBL MSBass Pro SQ, its a 10" sub in a ported box with 300w amp. It's pretty large but you can take it out easily if neccessary. I just used some velcro and it doesn't move around at all. It honestly sounds like a pair of 10's or a really nice 12". Retail is $500 but i got lucky on ebay for $200 shipped.
Saturday mods. Exhaust tips and a bazooka tube. Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 23 03-14-2013 11:24 PM
why do people not like the sound tube? pr086 Scion FR-S / Toyota 86 GT86 General Forum 104 02-25-2013 09:08 PM
Sound tube mod? smbrm Engine, Exhaust, Transmission 25 06-20-2012 08:24 PM
The intake sound tube MrVito Scion FR-S / Toyota 86 GT86 General Forum 8 12-09-2011 08:32 PM
Sound induction tube Yay, or ay? ahausheer Scion FR-S / Toyota 86 GT86 General Forum 22 12-04-2011 10:30 PM
