Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 11-08-2012, 03:51 AM   #15
brian_c_m
brian_c_m's Avatar
Drives: Toyota 86 - Silver High Spec
So yesterday I managed to remove the handbrake cover and silver panel that surrounds the gear shift lever. This helped me to see into the area where the loose bolt is rolling around but the space is too small to really see what's going on. Will need to try and remove the entire panel at some stage but that's rather tricky. If anyone is interested, I found a helpful guide over here;
http://www.ft86club.com/forums/showthread.php?t=8336
The only difference is that I have the highspec and I'm assuming that the start/stop switch will make it much trickier to get to the last 2 bolts holding down the center panel.
Will let you know if I get it right and will add pictures to the DIY.
Cheers
brian_c_m is offline   Reply With Quote
Old 11-26-2012, 10:10 AM   #16
brian_c_m
brian_c_m's Avatar
Hi all,
just to update you that I managed to dismantle my center console this weekend to get rid of that annoying sound coming from beneath the center console.
Good news is that I managed to solve the problem and at the same time eliminate another rattle coming from the gear shift panel. Bad news is that I didn't find the bolt that was rolling around Once I took the panel off I think the it slipped between some carpeting or something but whatever happened to it, it's gone now.
Also wanted to let you all know that the ^^ above ^^ post with a link to the DIY is 100% correct and I got all the panels off easily and without any scratches or broken clips etc. :-)
On another note. I seem to also be affected by this known issue which is my next project. Anyone else hearing this annoying sounds coming from the rear?
http://www.ft86club.com/forums/showthread.php?t=13451
The Following User Says Thank You to brian_c_m For This Useful Post:
Vic_RSA (11-26-2012)
Old 11-26-2012, 01:36 PM   #17
v3rgil
Drives: Toyota 86 Black (Standard)
Originally Posted by brian_c_m View Post
Hi all,
i have that same sound in the rear, think if we jam some weather strip in there that it might eliminate, will try that 2morrow
v3rgil is offline   Reply With Quote
Old 11-27-2012, 05:43 AM   #18
brian_c_m
brian_c_m's Avatar
Yeah, that was my plan too. I'll rather push something in there with a screwdriver to keep them apart. let you know if it solves the problem
Old 11-27-2012, 09:40 AM   #19
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
I'm really glad I got a Tuesday car because I'm not experiencing any of these issues.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 11-27-2012, 09:43 AM   #20
v3rgil
they sort of sneak up on us all, mine only started recently @ 3350km on the clock, but i did drive a dirt road once
Old 11-27-2012, 09:48 AM   #21
sav
sav's Avatar
I'm on 5000km already... *touch wood*
I'm not going near any dirt roads with my 86 though.
95RON SAV Tuned
Old 11-27-2012, 10:05 AM   #22
JouMaSeHoes
JouMaSeHoes's Avatar
Drives: Toyota 86 RED!
I drive 20km of dirt road every time I use my girl, and she handles it beautifully!
On around 4500km and still okay (besides the hail dent on the bonnet!).
JouMaSeHoes is offline   Reply With Quote
Old 11-27-2012, 11:20 AM   #23
v3rgil
hail, say no more, removed 13 of those dents from my bonnet about a month ago,
still have a small one on the roof, was not interested in them removing my roof lining
Old 11-27-2012, 11:33 AM   #24
brian_c_m
brian_c_m's Avatar
you're a lucky one. sometimes I think I got a friday car that was built after phuza-thursday :-( but it's only a rattle here or there. Thank goodness no CEL issues yet.
Old 11-27-2012, 11:36 AM   #25
sav
sav's Avatar
LOL! yeah a rattle here and there is manageable, it' when you have to start taking your car to the dealer...
95RON SAV Tuned
Old 11-27-2012, 11:36 AM   #26
sav
sav's Avatar
BTW
I know mine was built on a Tuesday because it still had the factory papers(with dates) and stuff on the windows when I first saw it.
95RON SAV Tuned
Old 02-04-2013, 09:15 AM   #27
sav
sav's Avatar
I've recently started noticing this...
95RON SAV Tuned
Old 02-04-2013, 09:27 AM   #28
Vladror
Vladror's Avatar
Drives: Toyota 86 M High - Dark Grey
dang, seems like an annoying one..
Vladror is offline   Reply With Quote
loose parts, rattle, vibration
Rattles/Squeaks in the BRZ? cammyfive BRZ First-Gen (2012+) — General Topics 190 01-12-2017 11:24 PM
Engine shaking/vibrations at 1700rpm - when in neutral/idle kharn83 Issues | Warranty | Recalls / TSB 9 11-07-2013 11:00 PM
Rattles are a major issue in this car jflogerzi Issues | Warranty | Recalls / TSB 49 11-05-2012 11:59 AM
steering wheel vibrations fiveoneoh Scion FR-S / Toyota 86 GT86 General Forum 17 09-08-2012 06:29 PM
