Old 11-22-2012, 06:09 PM   #1
Eric1855
Drives: LP DSP / CSP '13 BRZ
Crush Washer Sizes
I tried searching but no luck.
Does anyone know what size crush washers are used on the differential fill and drain plugs?
I saw the oil plug is M16, are these the same?
I really don't see the need to drive into town and pay a dealer when you can get them from the local auto parts store for $1. I'd just like to know which sizes to pick up ahead of time, instead of pulling it off and taking it up.
Thanks!
Eric1855 is offline   Reply With Quote
Old 11-28-2012, 09:34 AM   #2
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
Thanks!
You don't need to change them. They are flat aluminum washers.
No Limit Motorsport is offline   Reply With Quote
Old 11-28-2012, 09:49 AM   #3
diirk
diirk's Avatar
Drives: 4Runner
I just bought some from the local dealership for the diff. They were crush washers.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 11-28-2012, 09:50 AM   #4
No Limit Motorsport
Than its the transmission only that has the flat aluminum? Either way there is no issue reusing them, they seal just fine.
Old 11-28-2012, 09:57 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
From another post:
Originally Posted by xn7485 View Post
Just got a both pairs with part numbers quoted from Opie at Subaru. Rear diff drain and fill plugs look identical, but are both crush type washers. I recommend getting new ones to form a better seal. Price is 1.73 for fill, 1.98 for drain.
Yes, the transmission fill/drain washers are freaking $7.87 each. These are solid washers, and do not seem like they require replacing, but I special ordered these so I bought them. Though I got them at net price it was still freaking $5.19/washer.
You are correct.
Old 11-28-2012, 10:00 AM   #6
diirk
diirk's Avatar
Drives: 4Runner
That makes sense. Any chance you can get the size and we can look for a reasonably priced replacement option?
diirk
Old 11-28-2012, 10:05 AM   #7
No Limit Motorsport
I will see what I can do.
Old 11-28-2012, 10:29 AM   #8
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Even those should be crush washers. When you use one of the new ones you'll feel it crush. Honda's been using that style for a long time. They look like normal washers, until you use them the first time. I wonder if my old S2K ones would fit...
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 10:32 AM   #9
No Limit Motorsport
My point is when you reuse them at least the first time they seal and don't leak what so ever. I am all for changing out something if there is a benefit but if it doesn't leak than its working.
Old 11-28-2012, 10:35 AM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Well sure you can reuse them until they leak but any leakage is more expensive with these fluids than the cheap crush washers are. :shrug:
My point was simply that I highly doubt they are normal washers, despite their appearance.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 11-28-2012, 10:47 AM   #11
Sportsguy83
Drives: Limited BRZ
thanks for your input, and thanks for changing my mind, I'll replace them now
Old 11-28-2012, 11:03 AM   #12
No Limit Motorsport
IF they leak but any leakage is more expensive with these fluids than the cheap crush washers are.
I am messing around, if you guys want to change the washers, have at it. No harm done.
Old 11-28-2012, 11:17 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Agreed and I've reused them before on other cars. It also depends on how often you reuse them. If you are someone who changes trans and diff fluid often (which I do with any car I track) then you'll see them fail a lot sooner than a car that gets a trans fluid change every 100,000 miles
For this first change I re-used them even since I haven't gotten my replacements in yet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-03-2012, 10:21 PM   #14
developer
Drives: BRZ Limited
So I just received my overpriced gaskets/washer for the transmission and the differential:
Differential fill plug gasket: SU00300122 - 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: TOY1215710010 - 24mm OD x 18mm IDx 2mm Crush
Transmission fill/drain plug gasket: SU00303626 - 24mm OD x 18mm ID x 2mm Flat
They all look to be aluminum but that is just a guess. All measurements were made with calipers.
Edit: The crush washers stuck to the magnet on the drain plug so I guess they are not aluminum
Left Image is the diff drain/fill gaskets and they look identical. They are the exact same outer/inner diameter and thickness. They are both crush type washer.
The right image is the transmission fill/drain plug gasket is the same size as the differential gasket but is a flat washer.
After I pull the transmission gasket I will compare the thickness of the used and the new gasket to see if the transmission flat washer did actually "crush".
Edit: The original flat washer was within a 1000th of an inch of the new flat washer so I would guess they are not meant to crush.
When I order the differential crush washers again I will just order two of the same part number instead of two different parts.
developer is offline   Reply With Quote
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 04:08 PM
Pressure Washer $60 at super store Aznek CANADA 6 09-10-2012 11:08 AM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 02:06 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 03:31 PM
