Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 11-22-2012, 06:32 AM   #15
GeeTee86
86 Nut
GeeTee86's Avatar
Drives: 86 Satin 6MT High
Avo sport is thinking that its related to oil pressure. (incorrect oil?)
GeeTee86 is offline   Reply With Quote
Old 11-22-2012, 07:16 AM   #16
v3rgil
Drives: Toyota 86 Black (Standard)
Originally Posted by sav View Post
Cool, somebody mentioned that a spring or something on the cam gear pops out if you redline it withing the first 1600km. Not sure what would change after 1600km but you never know.
it was me, according to the guys from TRD that worked on my car, the spring inside the VVTi cam gear got stuck in the advanced position because it hadent had time to seat properly in its moving path, hence the 1600km drive in at various RPM, and engine oil needs to be at operating temp before going over 4000rpm always.
v3rgil is offline   Reply With Quote
The Following User Says Thank You to v3rgil For This Useful Post:
Crewzern (11-22-2012)
Old 11-22-2012, 07:18 AM   #17
v3rgil
not pressure, but thickness!
Old 11-22-2012, 10:20 AM   #18
Jono
Drives: Toyota 86 black
I have asked toyota to have a look at the parts changed and they have agreed, want to see exactly how this spring operates and where/how it could fail, will post an update when I see the parts hopefully tomorrow.
Jono is offline   Reply With Quote
Old 11-22-2012, 10:50 AM   #19
v3rgil
there is a metal plate on the face of the Cam gear, the spring is located under it, and it caused the cam to get stuck in advance
Old 11-22-2012, 11:10 AM   #20
Yruyur
Yruyur's Avatar
@Afzal, haven't put any fuel in yet, still using the tank I got form the dealership.
They have confirmed today that it is one of the cam gears and have received the part so will hopefully get car back by tomorrow. This to me would not be a fuel problem though, it is definately to do with timing. Previous experience with bad fuel has been a jerky vehicle throughout rev range. They did also confirm the error code of P0019.
Sucks them having to pull the entire front of the engine apart so early in life. I was not happy when they did mine for the cel issue.
Sent from my flux capacitor using Taptalk
Old 11-22-2012, 11:16 AM   #21
GeeTee86
86 Nut
GeeTee86's Avatar
Oil weight (or thickness if you will) have a huge impact on oil pressure - just saying
Old 11-22-2012, 12:02 PM   #22
v3rgil
that's also true, and the thickness also has to do with the running temp of the oil, lets just say that the engine in our 86's are very sensitive ,
Old 11-22-2012, 12:49 PM   #23
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
0W30 straight from the factory, don't think we can even get that in ZA. Waiting to see who gets the lucky first service to find out what to use!
Vic_RSA is offline   Reply With Quote
Old 11-23-2012, 12:46 AM   #24
v3rgil
that would be interesting, they did however have to drain my oil when they replaced the Cam Gear, will find out what oil they put back in.
Old 11-23-2012, 12:56 AM   #25
Jono
I would like to see how this spring is sticking though, is it failing or jamming? It really is sad to have to change bits on an engine so early. @v3rgil, after your repair did they extend your service plan as I am going to demand this. Its not that I don't trust the car its the workmanship by Toyota technicians. After previous bad experiences with tech's from numerous manufacturers this is by far the biggest worry. Not quite sure how well or if they have done any training on this vehicle. I will also ask about oil when I get car back today.
Old 11-23-2012, 01:20 AM   #26
v3rgil
they actually did extend it by 1 service interval
ps. and they gave me a jacket with the 86 logo on the back
Old 11-27-2012, 01:16 AM   #27
Jono
Hey guys an update for you. Got the car back on Friday and going really well. Very interesting to see the old gear, rather simple design so wonder if this will be changed in future. Got extended service plan, full tank of fuel, 86 jacket and cap, box of chocolates and flowers for the missus. Car feels so different and low down torque seems much better so must have had an issue from when I got car. Glad to be back on the road.
Old 11-27-2012, 01:19 AM   #28
GeeTee86
86 Nut
GeeTee86's Avatar
Cool man! Is the new gear any different from the old?
ECU replaced. Still has slight misfire, rough idle xomp Issues | Warranty | Recalls / TSB 1 11-01-2012 08:53 AM
