Old 11-17-2012, 05:56 PM   #1
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Brembo conversion problem
So yes I have searched and read all the available topics through and through and even posted in some of them.
I have my 2008 STi Brembos and tried to remove an allen screw in order to switch the bleeder to the other side. I used a 3/8 socket allen wrench to remove it and it tore through the screw. So now I have to use an extractor to take it out but if I do that I won't have a replacement screw to put back in. I could just put in another bleeder and have bleeders on both ends. I could just install them with the bleeder on the bottom but use a piece of wood and bleed the caliper while its unbolted. I could install them upside down.
If anyone knows where I can get replacement allen screws that would be great. However I do not think removing these screws is a simple job and I have a feeling the other 3 will probably follow suit.
Let me know what you think and TIA.
mrha is offline   Reply With Quote
Old 11-17-2012, 07:28 PM   #2
UncleFester
I read several people suggest using a torch to heat them up before trying to remove them.
UncleFester is offline   Reply With Quote
The Following User Says Thank You to UncleFester For This Useful Post:
mrha (11-17-2012)
Old 11-17-2012, 07:48 PM   #3
mrha
#1819
mrha's Avatar
Yeah I saw that too but I tried doing it without torching it though. Even if I did get it out I would need to replace the screw and I have no idea where to get a new one.
Old 11-17-2012, 07:56 PM   #4
mrha
#1819
mrha's Avatar
Normal allen screw
FUBAR allen screw
Old 11-17-2012, 08:44 PM   #5
Dustin
Twin Screw You
Dustin's Avatar
Drives: 2013 Supercharged Whiteout FR-S
If you decide to get all new bleeder screws................
http://vr-speed.com/store/stop-tech-...3-p-14481.html
Under $13 for all four.
Dustin is offline   Reply With Quote
The Following User Says Thank You to Dustin For This Useful Post:
mrha (11-17-2012)
Old 11-17-2012, 09:16 PM   #6
JDMenrique
DEEEERP
JDMenrique's Avatar
i would suggest using something like [ame="http://www.amazon.com/Aircraft-Tool-Supply-Screw-Grab/dp/B005VR52K0"]screw grab/mr torque[/ame] next time. the shit works wonders.
JDMenrique is offline   Reply With Quote
The Following User Says Thank You to JDMenrique For This Useful Post:
mrha (11-17-2012)
Old 11-17-2012, 09:22 PM   #7
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
helicoil it out.
Surok is offline   Reply With Quote
Old 11-17-2012, 10:04 PM   #8
wheelhaus
wheelhaus's Avatar
you could also try a torx bit, the six point star can grab and dig into the hex shape, where a standard hex bit can sometimes ramp itself out once it rounds off just a bit, which only makes the problem worse.
I also recommend a good quality set of L hex wrenches, the black coated anti-corrosive type seems to always do the trick where other shiny/chromed finishes failed because they slip too easily. Bondhus brand always worked extremely well for me, great quality. The black surface of these will feel dry and almost abrasive. Bicycle shops sell an awesome 3-way Y-shaped hex tool made by Park tools made of the same stuff. It has 4mm, 5mm, and 6mm and is extremely handy. I don't recall ever having a hex bit strip with these after many years of daily use as a mechanic.
http://www.bondhus.com/bondhus_produ...hes/index.html
http://www.parktool.com/product/3-way-hex-wrench-aws-1
The Following User Says Thank You to wheelhaus For This Useful Post:
mrha (11-17-2012)
Old 11-17-2012, 11:44 PM   #9
jamal
jamal's Avatar
Drives: Legacy GT
Originally Posted by Surok View Post
helicoil it out.
And how would that work?
Hammering in the next size up torx bit is probably one of your best options.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
mrha (11-17-2012)
Old 11-17-2012, 11:51 PM   #10
mrha
#1819
mrha's Avatar
Sounds like a good idea but I'd still have to figure out how to replace the screw.
Old 11-17-2012, 11:52 PM   #11
mrha
#1819
mrha's Avatar
Originally Posted by JDMenrique View Post
i would suggest using something like screw grab/mr torque next time. the shit works wonders.
I wonder if I can buy that stuff locally. If it works this would be amazing since I have more than one allen head stripped on my car.
Old 11-17-2012, 11:57 PM   #12
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
My local hardware store has Allen plugs.. I don't see why this wouldn't work.. I personally would just do what you said if and when I get a set of these.. Just bleed them with a board or something between the pads.. I even have caliper to olds, is id use them.. But I wouldn't o thought the hassle of removing the screws.. I am looking for a good set on eBay lol
On a side question.. Which calipers bolt up.. Just the WRX STI ones???
Gixxersixxerman is offline   Reply With Quote
Old 11-18-2012, 12:15 AM   #13
mrha
#1819
mrha's Avatar
The allen screws are recessed into the calipers themselves. I guess it wouldn't hurt to try bolts if I could find them in the right thread pitch and size.
I'm using 2008 STi Brembos. They bolt up the best since 04-07 rears need adapters.
Old 11-18-2012, 12:41 AM   #14
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
I am sorry i was confusing helicoil with another product.
i mean use one of those reverse thread things that you can drill into the bolt and then unscrew
GRB Brembo caliper on BRZ RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 66 11-15-2016 02:50 PM
Brembo BBKs Announced oneday Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 06-11-2014 10:51 PM
The price of one Brembo Caliper. chuttney1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 01-18-2013 04:32 PM
New Brembo BBK installed on shop car vividracing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 11-16-2012 01:48 PM
R35 Brembo Brakes - Full set 2013GTRNate Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-06-2012 10:08 AM
