| BRZ First-Gen (2012+) General Topics All discussions about the first-gen Subaru BRZ coupe |
#15 | ||||
Night Owl
Drives: 2013 Subaru BRZ
Thanks for the feedback fellas ![]() Quote:
#16 |
Seρor Member
Drives: white BRZ 6MT
just so you guys know, pretty much every car's VIN includes the chassis code in some form.
BRZ is ZC6. 86/FR-S is ZN6.
#17 |
#18 | |
Site Moderator
Drives: ichi 86 Project
iirc Z - Boxer C/N - BRZ/FRS 6 - Engine type |
#19 | |
Drives: 4 Wheels Auto
I think I can chime in on some info about the VIN. Here are some samples of the VINs for BRZ and FRS:
BRZ VINs JF1ZCAC16D1600049 - Limited 6 Speed Manual Galaxy Blue Silica (Pre-production demo shown in NE) FRS VINs JF1ZNAA14D1700129 - MD Firestorm JF1ZNAA12D2700446 - NC Firestorm AT So as you can see these: 1. The manufacturing company is JF1 (FHI. There are JF1 and JF2 for FHI so JF1 *may* means factory 1 - main). 2. ZCA is for BRZ where as ZNA is fore FRS 3. C1 is for BRZ limited, B1 is for BRZ premium, and A1 is for FRS. The 1 in this word is for restraint type. 4. the next digit is for check number. Algorithm follows later. 5. D for model year 2013 6. the next digit (11th) is for plant/transmission code. In this case, 1 for manual and 2 for automatic transmission. For some other brand, this could means the plant number. 7. digit 12-17 are the sequence code. Here is something strange between FRS and BRZ. The pre-production of BRZ starts with 6. I wonder if the regular BRZ also starts with 6 or do you have a different number. Furthermore, all the FRS I found so far all starts with a 7. I am not sure if this is true for all the cases. Now the check-digit algorithm: (copied from WIKI http://en.wikipedia.org/wiki/Vehicle...ication_Number) Code:
If trying to validate a VIN with a check digit, first either:
(a) remove the check digit for the purpose of calculation; or
(b) utilize the multiplicative property of zero in the weight to cancel it out.
The original value of the check digit is then compared with the calculated
value. If the two values do not match (and there was no error in the
calculation), then there is a mistake in the VIN. However, a match does not
prove the VIN is correct because there is still a 1 in 11 chance of any two
distinct VINs having a matching check digit: an example of this would be the
valid VINs 5GZCZ43D13S812715 (correct with leading five) and SGZCZ43D13S812715
(incorrect with leading character 'S').
Transliterating the numbers
Transliteration consists of removing all of the letters, and substituting them
with their appropriate numerical counterparts. These numerical alternatives
(based on IBM's EBCDIC) can be found in the following chart. I, O and Q are not
allowed, and can not exist in a valid VIN; for the purpose of this chart, they
have been filled in with N/A (not applicable). Numerical digits use their own
values.
Transliteration key: values for VIN Decoding
A: 1 B: 2 C: 3 D: 4 E: 5 F: 6 G: 7 H: 8 N/A
J: 1 K: 2 L: 3 M: 4 N: 5 N/A P: 7 N/A R: 9
S: 2 T: 3 U: 4 V: 5 W: 6 X: 7 Y: 8 Z: 9
S is 2, and not 1. There is no left-alignment linearity.
Weights used in calculation
The following is the weight factor for each position in the VIN. The 9th
position is that of the check digit. It has been substituted with a 0, which
will cancel it out in the multiplication step.
Position 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
Weight 8 7 6 5 4 3 2 10 0 9 8 7 6 5 4 3 2
Worked example
Consider the hypothetical VIN 1M8GDM9A_KP042788, where the underscore will be
the check digit.
VIN 1 M 8 G D M 9 A K P 0 4 2 7 8 8
Value 1 4 8 7 4 4 9 1 0 2 7 0 4 2 7 8 8
Products 8 28 48 35 16 12 18 10 0 18 56 0 24 10 28 24 16
1. The VINs value is calculated from the above table, this number will be used
in the rest of the calculation.
2. Copy over the weights from the above table.
3. The products row is a result of the multiplication of the vertical columns:
Value and Weight.
4. The products (8,28,48,35..24,16) are all added together to yield a sum of 351
5. Find the remainder after dividing by 11
351 MOD 11 = 10
351 χ 11 = 31 10/11
6. The remainder is the check digit. If the remainder is 10 then the check digit
is X. In this example the remainder is 10, so the check digit is
transliterated into X.
With a check digit of 'X' the VIN: 1M8GDM9A_KP042788 is written as:
1M8GDM9AXKP042788.
Straight-ones (seventeen consecutive '1's) will suffice the check-digit. This
is because a value of one, multiplied against 89 (sum of weights), is still 89.
And 89 divided by 11 is 8 with the remainder being the fraction "1 over 11,"
thus 1 is the check digit. This is an easy way to test a VIN-check algorithm.
| The Following 2 Users Say Thank You to Want.FR-S For This Useful Post: | mo8ius (12-22-2012), SkullWorks (05-22-2012) |
#20 |
got mine right-
6MT SWP BRZ got number 00911 which is perfect for me since I grew up a Porsche fan.
| The Following User Says Thank You to Flat Black VW For This Useful Post: | MannyO (06-11-2012) |
#21 |
Night Owl
#22 |
Drives: DGM BRZ Limited, 05 Baja Turbo
I have 00071...does anyone know how many of the pre-production cars were made -- would those be on the same numbering scheme? I was thinking if there were 25 or 50 of those made, a 71 would actually be more like the 21st or 46th US production vehicle, but wasn't sure if this was the case.
#23 |
Thanks for the info! #635 for me.
#24 |
#25 |
Drives: 13' SSM BRZ
oo nice little find. 131 !
| Tags |
| brz vin, decoder, vin, vin# |
| List differences between USDM and JDM specs | ayau | BRZ First-Gen (2012+) General Topics | 28 | 03-01-2012 02:06 PM |
| Pics of a USDM Premium interior? | Grimlock | BRZ First-Gen (2012+) General Topics | 17 | 02-19-2012 04:28 PM |
| Why does USDM model get the smaller muffler tips? | ayau | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 12-26-2011 06:39 AM |
| Insideline's USDM BRZ test review | madfast | BRZ First-Gen (2012+) General Topics | 95 | 12-08-2011 04:52 AM |
