Old 11-17-2012, 06:03 AM   #3823
Calum
That Guy
Drives: 2013 asphalt FRS MT
When I sent mine I tried to include cold start to fully warm, with a couple wot runs (in the highest gear I could use) from just off idle to redline, once the engine was warm. I got the impression this was more then was required but I tried to make sure he could see info for as many conditions as possible, while giving the ECU enough time to correct what is was capable of correcting.
Calum is offline
Old 11-17-2012, 06:54 AM   #3824
_F-R-S_
Drives: 13 whiteout scion frs
How to get this tun?
_F-R-S_ is offline
Old 11-17-2012, 11:41 AM   #3825
Yruyur
Yruyur's Avatar
I assume I should not drive with a lean condition? If I put the stock drop in filter will that help or hinder? Problem is that I have a full tank of e85 in there now and getting a cel for lean afr. Using my obd reader gettting 14.5 ish until I coast in gear and getting 20ish. Sent logs to john already. Not sure if I need to find alternate transportation?
Sent from my flux capacitor using Taptalk
Yruyur is offline
Old 11-17-2012, 03:34 PM   #3826
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
I have a Injen intake and SRT headerback on the e85 tune and haven't had any CEL come on. Only issue so far is cold starts and my fuel gauge. I have noticed though when doing cold starts if I turn off the HVAC and make sure the headlights are not set on auto it starts on 1st or 2nd try. Before if would take up to 3-4 tries.
Area86 is offline
The Following User Says Thank You to Area86 For This Useful Post:
Yruyur (11-17-2012)
Old 11-17-2012, 03:40 PM   #3827
Yruyur
Yruyur's Avatar
Still getting cel after putting the stock filter in. Going to put an ad on craigslist for free e85 so I can get someone to siphon my tank and I can return to pump gas for now.
Yruyur is offline
Old 11-17-2012, 03:41 PM   #3828
Unleashed
Unleashed's Avatar
Drives: 13' WRX
why not just siphon the gas into a gas can and save it for later?
Unleashed is offline
The Following User Says Thank You to Unleashed For This Useful Post:
SkAsphalt (11-19-2012)
Old 11-17-2012, 03:51 PM   #3829
Yruyur
Yruyur's Avatar
Could. But I don't have ability in my current living situation. Apartment. :o
Yruyur is offline
Old 11-17-2012, 04:01 PM   #3830
Unleashed
Unleashed's Avatar
Drives: 13' WRX
Oh bummer.
Old 11-17-2012, 05:08 PM   #3831
Gregory Gawaran
Drives: 2018 Subaru BRZ tS
Thanks, I will do it that way. Looks like a good place to start. Thanks for the heads up.
Gregory Gawaran is offline
Old 11-18-2012, 07:15 AM   #3832
WatchmaN
WatchmaN's Avatar
Drives: the girls crazy
I have to make an apology to Visconti, even if I never posted bad comment on this thread. But I did in my head.
I did not order his tune seeing so many people complain about his service. But by doing some research on ecutek on the web a came across his name very often. And by matching the dates I realise that he is not only working on are make and model but also on very much other cars make.
I can't imagine how much job he must have, to send orders, analyse logs, respond messages, refine tune considering the logs he received.
So taking all that in to account, the guy is doing one hell of a job.
Vortech SC(314hp/226tq), Perrin pully, Tanabe strut tower bar, Perrin exhaust, LP Tune, hsd coilovers, DTC-60 fr, hp+rear),track rubber RS3 and Continental :-), Forester oem oil cooler,Custom brake cooling kit. Driveway lab rear diffuser, Wasp front spliter, TRD canard/fenders.
WatchmaN is offline
The Following 2 Users Say Thank You to WatchmaN For This Useful Post:
SkAsphalt (11-19-2012), Visconti (11-19-2012)
Old 11-18-2012, 10:28 AM   #3833
Yruyur
Yruyur's Avatar
Turns out we have a screen installed on the filler preventing siphoning. Good thing my fuel gauge was stuck from the tune. I thought I still had a full tank. I ended up adding 5 gallons of 91. No more cel running on map 1.
Yruyur is offline
Old 11-18-2012, 06:48 PM   #3834
lopro25
lopro25's Avatar
Drives: Hot Lava FR-S
Does the ProECU software work on a chromebook operating system? I wouldn't think it would work, but wondering if anybody has any insight into that.
Sent using mobile Tapatalk App
lopro25 is offline
Old 11-18-2012, 06:50 PM   #3835
xjohnx
Grip>Slip
xjohnx's Avatar
Windows only.
xjohnx is offline
Old 11-18-2012, 08:54 PM   #3836
lopro25
lopro25's Avatar
Originally Posted by xjohnx View Post
Windows only.
Does it work on Windows 8?
lopro25 is offline
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 02:05 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 07:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 01:42 PM
