Old 11-16-2012, 03:38 PM   #15
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
How did you separate the boot from the knob?
just pull on it. its just tightly pulled over a lip. idk what knob mine is, but you can't see any thread. I'd take a pic, but its at my painters.
xclusive_brett is offline   Reply With Quote
Old 11-16-2012, 05:18 PM   #16
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
Mt knob doesnt fit At... Trust me
rhood168 is offline   Reply With Quote
Old 11-16-2012, 05:39 PM   #17
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
It's odd that it wouldn't fit. You'd think that besides the actual gear assembly the shifter is the exact same part, just oriented differently for the AT. Why would they give it a different thread pattern?
Nevermore is offline   Reply With Quote
Old 11-16-2012, 07:15 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Isn't the manual a Subaru unit while the AT is a Toyota part?
Old 11-17-2012, 12:04 AM   #19
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Hmmm... If that's true then that would explain it.
So how would we be able to tell if a knob might work or not? Or is this basically impossible to do without the physical knob?
Old 11-17-2012, 01:49 AM   #20
finch1750
finch1750's Avatar
I'm sure it's a standard knob pitch that varies forr different manufacturers, so maybe its on here somewhere. I'm on my phone or I'd try to google it and share the link.
Edit: manual is 12x1.25 and auto is 8x1.25
Nevermore (11-17-2012)
Old 11-17-2012, 09:53 AM   #21
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by jazztennor View Post
Does anyone know if the Flossy knob can/will work on AT
If the only difference between the MT knob and the AT is the thread being 8 agsnsit 12,I know how to fix it. Will post when I get home.
Sent from my HTC One XL using Tapatalk 2
Old 11-17-2012, 10:57 AM   #22
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
any shifter that fits an Impreza 08 AT will fit then brz/frs AT. I have a AT flossy knob and just asked them to thread it the same size as the 08 Impreza at. Although they should already know the brzfrs AT thread size
mechaghost is offline   Reply With Quote
Old 11-17-2012, 09:32 PM   #23
Sportsguy83
Drives: Limited BRZ
OK. Here's the solution. http://www.scionlife.com/forums/showthread.php?t=210718
Open that page and see the first post. It contains a link where you can buy an adapter that will convert the 12x1.25 to 8x1.25. That will make any MT shift knob fit on the AT rod. The price of the adapter is $2.50.
You welcome!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
finch1750 (11-17-2012)
Old 11-19-2012, 11:22 PM   #24
rhood168
rhood168's Avatar
You welcome!
Your the MAN!
I hope this works, now i am buying an armrest your friend makes lol. I didnt know who to buy it from.
The Following User Says Thank You to rhood168 For This Useful Post:
Sportsguy83 (11-20-2012)
Old 11-20-2012, 07:24 AM   #25
Sportsguy83
Drives: Limited BRZ
Originally Posted by rhood168 View Post
Your the MAN!
You welcome man!
Old 12-09-2012, 09:18 AM   #26
rhood168
rhood168's Avatar
Are you sure 8x1.25 is the auto size for the knob ordered an adapter and it didnt fit. I'm going to assume it is 10x1.25 like other subaru cars.
Old 12-09-2012, 09:25 AM   #27
Sportsguy83
Drives: Limited BRZ
Damn, that sucks. I really had never even seen an AT shift knob, but I had read in multiple places it was 8X1.25...
Old 12-10-2012, 10:56 AM   #28
finch1750
finch1750's Avatar
That was the answer in two or three places when I googled it, but it was forums that could be wrong like I was. My bad man. Maybe someone should ask a vendor that sells em for a definitive answer (even though its gotta be 10 if it isn't 8).
Shift Knob Jwong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 12-12-2014 01:33 AM
Shift Knob Zoomryder Issues | Warranty | Recalls / TSB 5 04-09-2013 08:39 PM
any other shift knob? oso_25 Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2012 01:38 AM
TRd Shift Knob GaN-MaN Cosmetic Modification (Interior/Exterior/Lighting) 1 07-24-2012 01:57 PM
