Old 11-10-2012, 10:38 PM   #127
rhood168
rhood168's Avatar
Drives: Black Subaru Brz Limited
I actually reset it right after i took the picture it jumped to 19.1 when i used up all the gas. I'm trying to figure out what would cause this.
rhood168 is offline   Reply With Quote
Old 11-10-2012, 10:41 PM   #128
serialk11r
Drives: '06 AM V8V Coupe
Don't look at the indicator, what are you getting when you fill your tank? 16mpg on a car like this should only happen if you're making 5 minute trips only, or using only 1st gear (or otherwise intentionally wasting gas). Otherwise there's a problem.
Old 11-10-2012, 10:47 PM   #129
rhood168
rhood168's Avatar
Around 19 mpg and its an automatic. The 16 was overall for the 1000 mile break in, I reset it when i filled up im tracking how many miles on this tank to figure out what it and keeping my driving real limited(work only)but this really doesn't add up.
Old 11-13-2012, 07:06 AM   #130
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
I have 800Mi and 3 full tanks. average 22mpg at 60/40 hi-city. high way speed is 55-60mph and 15-25mph at city. about 6 full stops with in 15miles and a lot of accelerating due to overtaking.
FYI I live in the Philippines w/ a lot of OVERTAKING. Free/Express roads give me around 28-30mpg at 67-69mph. 1st tank used 94 octane 10% ethanol. 2nd tank is 100 Octane 10% ethanol (High Octane fuel). 3rd is 95 octane 10% ethanol.
FYI I frequently travel with companions and with trunk or rear seats loaded with stuff (FULLY loaded ~300lbs)
Temperature here is 25decCel - 38decCel 60% humidity
Tire Pressure is at 32psi cold, Hot-??psi
Added weight from stock is roughly ~50lbs
Did a Change oil at 800mi and I will inform you guys if there are changes. Oil used is Motul 5w40
Good Milage for such a Sporty Car
Margovincent_22x is offline   Reply With Quote
Old 11-14-2012, 09:05 PM   #131
TemeCal
Drives: 86
1200 miles on my car. Best I've got was 23mpg on a tank. The last 2 tanks, I can't seem to get above 20mpg. 90% city driving, and getting just over 200miles on a tank.
I don't understand how you all are getting such good gas mileage, unless you are driving your car unbelievably slow. I'm by no means WOT all the time...but I do drive aggressively 50% of the time. I've tried accelerating incredibly slow, and shifting around 3k RPM. None of that seems to help. I still get below 20.
TemeCal is offline   Reply With Quote
Old 11-14-2012, 09:12 PM   #132
rhood168
rhood168's Avatar
Happy to know I'm not the only one, we must be doing something wrong or city driving really rips this car. Ive tried a few things and i constantly float between 19 -21 mpg
Old 11-14-2012, 09:18 PM   #133
Yruyur
Yruyur's Avatar
It would be interesting to plug in a obd Bluetooth adapter and use the torque app on your phone to monitor things while driving. Then find a local member fretting better mileage and do the same. Curious if the timing advance and other things are the same or yours is different.
Sent from my flux capacitor using Taptalk
Old 11-14-2012, 09:20 PM   #134
WorldRallyBlueBRZ
WorldRallyBlueBRZ's Avatar
Drives: World Rally Blue BRZ
I am currently yo to 28.4 MPG
WorldRallyBlueBRZ is offline   Reply With Quote
Old 11-14-2012, 09:23 PM   #135
TemeCal
Drives: 86
Ya - either something is seriously wrong with my car, or I just don't believe others are driving their cars hard enough. I will say, however, that I live in a very hilly area. I've always averaged a little less than the "claimed average MPG" in my other vehicles. But, none have been as dramatic as this car.
Old 11-14-2012, 11:02 PM   #136
chbsc
Drives: Scion FRS manual
Mpg
I just got back from a 700 mile highway trip and mpg average is showing 26.8
chbsc is offline   Reply With Quote
Old 11-14-2012, 11:06 PM   #137
lastsnare
^_^
Drives: 2013 BRZ Galaxy Blue Silica
I've gone through a few tanks now, mpg's are up (surprisingly) after flogging it a bit on some hilly roads last weekend, about 950 miles on the odometer currently.
My last tank, the computer said 25.2mpg, and measuring how much gas I put in and how many miles since my last fill-up,
I calculated that I actually got 29mpg.
Computer currently says average 26.2 right now, so I'll see what I calculate at my next fill-up in a day or two.
2004 WRX sedan Java Black Pearl (manual)
2013 BRZ Galaxy Blue Silica (manual)
lastsnare is offline   Reply With Quote
Old 11-15-2012, 12:42 AM   #138
Estey
Drives: Scion FR-S, Ultramarine
yeah my mileage sucks here where I live. I average 23 mpg because of the hills. but once i get out on the freeway itll get to the upper 30s
Estey is offline   Reply With Quote
Old 11-15-2012, 01:56 PM   #139
Wcmarshall
Drives: 2013 Asphalt FR-S
Mine was 28.5mg before I had the ECU changed out due to the CEL/Idle issue. Haven't had it back long enough to figure out if mpg has changed with new ECU and programming.
Wcmarshall is offline   Reply With Quote
Old 11-15-2012, 02:13 PM   #140
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I dont know my mpg but I love to drive the hell out of my FR-S!! is a daily driver and I love it so much that I really dont care about Fuel compsuption,,, and in Puerto Rico Fuel is expensive unless I fill up on the military base!!
kombatlion is offline   Reply With Quote
