Old 11-14-2012, 05:27 AM   #1
Tyson
Drives: black FT86
Brake in.
Hey seeing as the 86/brz/frs has been out for a little while now, just curious as to who actually followed the manual exactly and who just did what they felt comfortable with, and ofcourse what results you have seen from your method of running in the 86/brz/frs.
sorry if this has been done i thought it was slightly different to most posts about break in periods etc, im mostly interested what people have personally done and their thoughts.
Tyson is offline   Reply With Quote
Old 11-14-2012, 07:48 AM   #2
Gardus@Supersprint
Drives: Clio TCE
Usually you gradually increase pushing the cars for the first 1500/2000 km, avoiding long amounts of time at constant speed.
Supensions, gearbox and brakes also need to be broken in, so you'll need to increase the pace as well in a gradual way...
Gardus@Supersprint is offline   Reply With Quote
Old 11-14-2012, 08:21 AM   #3
atledreier
Drives: GT86 DGM
"The manual says to take it easy the first 1000km, so I better grannydrive it and then give it the beans once i cross 1001km..."
I just don't see the logic?
I am going to ease mine into it, first few hundred kilometers I'll take is a bit easy and then gradually drive it harder and at faster rpm towards the magic 1000km mark. Babying it isn't breaking it in.
atledreier is offline   Reply With Quote
The Following User Says Thank You to atledreier For This Useful Post:
FreshFRS (11-14-2012)
Old 11-14-2012, 09:35 AM   #4
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I figure the people writing the owners manual know more about the topic than I do so I followed their recommendations. It didn't make that much difference to me anyhow as that's the way I normally drive.
whaap is offline   Reply With Quote
Old 11-14-2012, 09:45 AM   #5
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Some people say….
You should break in an engine by beating on it.
However, there's no way to know until engine reaches old age. I seriously doubt redlining it a few times during the break up would make the engine die at a younger age… it's quite rare to see an engine not make it to 300 000 km nowadays no matter how it was broken in.
Rayme is offline   Reply With Quote
Old 11-14-2012, 09:57 AM   #6
Akired86
Akired86's Avatar
Drives: 2013 Scion FR-S Asphalt
Engine break in period done by the factory before it is mounted on your vehicle. Just drive it like you stole it! This is 2013 car, break in period is a myth! Get over it!
Akired86 is offline   Reply With Quote
Old 11-14-2012, 10:01 AM   #7
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
I like this idea. Have anything to back it up?
Freeman is offline   Reply With Quote
Old 11-14-2012, 10:19 AM   #8
Akired86
Akired86's Avatar
Drove it 200 miles, oil change at home. Drove it to 1000 miles, oil change again. I did 2 oil changes and looking for any sign of metal pieces from break in the engine, nothing in the oil pan nothing in the filter. Confirmed!
The Following User Says Thank You to Akired86 For This Useful Post:
soros151 (11-15-2012)
Old 11-14-2012, 11:55 AM   #9
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Follow the manual. I did but when I got to around the 600 miles mark I'd push it to 5k rp max, 700 miles 6k rpm, etc until I hit 1000 miles.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 11-14-2012, 12:08 PM   #10
Freeman
Freeman's Avatar
Nice, but nothing official from Toyota or Subaru?
Old 11-14-2012, 12:16 PM   #11
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
This has been debated on every forum that deals with a combustion engine.. Always have a thread every new model year on the bike forums... Back in the day, I completely understood the break in period.. But if you've seen the thread with the FRS being built.. They roll every car straight on a dyno and run that shit straight to redline.. Along with other rpm points.. I just broke mine in with what I was comfortable with.. It hit the redline, hit the limiter, was up in the high rpms, but not like racing it so it didn't stay in those areas for extended periods.. I can look on gixxer.com for a article that's always posted when this comes up, about this guys scientific research on modern engines about breaking it in very hard, to use the combustion pressure to seat the rings.. I'll look for it and post it
Gixxersixxerman is offline   Reply With Quote
Old 11-14-2012, 01:09 PM   #12
wparsons
wparsons's Avatar
^^ There's a difference between combustion heat and rpm. You can get lots of heat at lower RPM's under WOT and lots of load. The manual even says to give it some WOT acceleration up to 4000rpm during the break in period.
I kept mine under 4000rpm for the first tank, 5000rpm for the second tank, 6000rpm for the third tank and redline since.
I was getting about 550km's per tank, so by about 1600km's I was redlining. I'm not convinced it helps at all, but I was commuting about 100km's per day plus other driving, so I hit 1600km's in about 12 days. If I had to wait a month for that many km's there's no way I would have held out.
flickr
Old 11-14-2012, 06:52 PM   #13
Tyson
Drives: black FT86
What does WOT mean?
Old 11-14-2012, 07:24 PM   #14
A5D5TRYR
A5D5TRYR's Avatar
Drives: FR-S 6MT Ultramarine (BeeDrill)
Originally Posted by Tyson View Post
What does WOT mean?
Wide-Open-Throttle, ie gas pedal on the floor.
A5D5TRYR is offline   Reply With Quote
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
Big Brake Kit? htl2195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-06-2012 11:18 AM
The third brake light looks like a car! Longhorn248 BRZ First-Gen (2012+) — General Topics 12 06-06-2012 08:14 PM
Big Brake? Ladnerd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 04-30-2012 08:32 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
