Old 04-25-2012, 12:02 PM   #1
Ladnerd
Drives: 02 celica
Big Brake?
Front brake only ???? This is what is listed for performance accessories for 2013 FRS.
Ladnerd is offline   Reply With Quote
Old 04-25-2012, 05:24 PM   #2
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
front brakes do most of the work
G-Man is offline   Reply With Quote
Old 04-26-2012, 11:19 PM   #3
Alliedforces86
Flat 4 Handyman
Alliedforces86's Avatar
Drives: Firestone Red FR-S & WRB MY2002 WRX
For a cheaper easy upgrade, just slap on some 06-07 WRX front calipers. They're 4pot and will most likely fit behind the stock wheels with no spacer, and you retain the oem rotor so you save money there.
Alliedforces86 is offline   Reply With Quote
Old 04-27-2012, 12:14 AM   #4
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That would just screw up the brake bias causing longer stopping distances and understeer during trailbraking. It would not be an upgrade in any sense other than piston count.
old greg is offline   Reply With Quote
Old 04-27-2012, 12:35 AM   #5
Ladnerd
Drives: 02 celica
From strictly an styling point of view it really needs the back brake too. Check out the TRD GT - 86.
Old 04-27-2012, 01:25 AM   #6
Alliedforces86
Flat 4 Handyman
Yeah I read through the other brake thread where everyone is pointing that out. It would "work", but not really be an upgrade.
Yeah, but IMO, 6 piston fronts and 4 piston rears is a little overkill on these cars. Not to mention you'd had to use 18" wheels which these cars weren't really designed for.
Old 04-27-2012, 02:24 AM   #7
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
This might also be an issue... these setups are not exactly the same(STI=WRX position), interchangeability is speculative.
chulooz is offline   Reply With Quote
Old 04-27-2012, 03:01 AM   #8
OrbitalEllipses
Drives: Attitude
As pointed out in a few other threads, this is an issue with Brembos but not FHI/Nissan 4 pots. In any case, the FHI/Nissan units won't be an upgrade.
Old 04-27-2012, 03:05 AM   #9
chulooz
Registered you sir
chulooz's Avatar
placement in relation to the direction of the car isnt a concern? Like I said above, wrx is the same place as sti
Old 04-27-2012, 03:12 AM   #10
OrbitalEllipses
Drives: Attitude
FHI 4pots aren't differential bored. Brembos are.
You can flip FHI units left/right to get the right bleeder orientation and they'll work fine. Brembos won't.
Furthermore, Ken@KNS Brakes aka WRX Brakes now carries rear adapters that locate the rear FHI 2 pots to the 08+ WRX knuckle assembly. Theoretically, one could take the FHI 4/2pot setup and place it on the BRZ (if the rear suspension is lifted entirely out of the WRX, as was suggested in an earlier thread).
Again, the FHI 4/2 setup provides no heat capacity over stock; only increased modulation of the pedal and more rearward bias (at least, in the WRX it moves bias rearward).
Old 04-27-2012, 03:22 AM   #11
chulooz
Registered you sir
chulooz's Avatar
I see what you are saying about fitment, but then to claim that they are not an upgrade is certainly speculative. I would be willing to bet that the 4/2 setup will out-brake and outperform a stock setup, any wagers?
Old 04-27-2012, 03:26 AM   #12
OrbitalEllipses
Drives: Attitude
I'll take that wager.
Most people move to larger brakes due to fade; they require more heat capacity for repeated sessions at the track. These are WRX sliders on a car that weighs 400-500lbs less, they won't be as prone to fade as they are on that pig. The sliders are woefully undersized for 3300-3400lbs of AWD grip, not so much a 2762lb runabout. The 4/2 units are iron, and as such, likely weigh more than the sliders while using the exact same rotors front and rear. The additional unsprung mass, from the calipers, at all four corners will offset the gains from playing with bias and modulation methinks. Regardless, I would consider it a waste of money. The proper first step is new pads, lines, and fluid. Then talk about bigger brakes...where keeping the same size rotors is by and far, not the point.
The bias on the early WRX was very nearly 70/30. FHI 4/2 were a tremendous upgrade in that they moved bias rearward and made the pedal stiff as tits instead of squishy like bread. The pedal here, in the BRZ, is already stiff; moving to the 4pot setup is a waste of time, IMHO.
Old 04-27-2012, 05:10 AM   #13
chulooz
Registered you sir
chulooz's Avatar
You cant know how stiff the pedal will feel until you start really pushing it. You also cant deny that you will gain a great amount of feel from these, as the newer WRX guys still benefit from them on more recent models.
Tires,pads,lines,fluid,master cylinde/brace, + duct work would really seal the deal. I think they weigh less; and with the sliding pads they are easier to swap in/out, and have more aftermarket options. Its not all too pricey either, especially considering the nice benefits of a compromise between street and performance driving.
Old 04-27-2012, 06:33 AM   #14
Gardus@Supersprint
Drives: Clio TCE
If you don't go FI the stock brakes will be enough, just fit some track spec pads, braided hoses and RBF600 or any other good boiling point oil.
Gardus@Supersprint is offline   Reply With Quote
which brake pads? NESW20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 165 02-25-2018 02:07 AM
TireRack has big brake kits for FR-S. Cheddar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 04-17-2012 02:42 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
