Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 11-13-2012, 04:10 PM   #1
xpicer
xpicer's Avatar
Drives: 2013 frs white out
ready to take your f for the fuel pump recall??
I took mine on monday, to toyota dch in mamaroneck,ny and well it was a good expercience. I total it took them 2 days, the tech that worked on my vehicle also owned one and took good care of mine, they gave me a loner and didnt pay 1 cent! overall great experience !!
" Knowledge is nothing with out execution"
xpicer is offline   Reply With Quote
Old 11-13-2012, 04:13 PM   #2
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
did mine as well.. they gave me a prius for a loner
fast and easy TSB!
86_ZN6 is offline   Reply With Quote
Old 11-13-2012, 04:18 PM   #3
Jayde
Jayde's Avatar
Seeing as how the issue keeps popping up, I'll wait a little longer before taking mine in.
Jayde is offline   Reply With Quote
The Following User Says Thank You to Jayde For This Useful Post:
dori. (11-14-2012)
Old 11-13-2012, 04:22 PM   #4
Vicious LED
Drives: Scion FR-S Asphalt
I had mine fixed about 2 months ago...then had the ECU replaced about 2 weeks ago for the CEL/SCL issue. Right after receiving my FR-S back from the dealership, as soon as I got home (about 10 miles away) the chirping came back...now mind you this is after they already replaced the fuel pump once. I have a sneaking suspicion it's not just due to the fuel pump.
Vicious LED is offline   Reply With Quote
The Following User Says Thank You to Vicious LED For This Useful Post:
Bluecille (11-14-2012)
Old 11-13-2012, 05:11 PM   #5
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
Replace a fuel pump....
with the same exact fuel pump
expect different results
this is called insanity.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
The Following 5 Users Say Thank You to YourFearlessLeader For This Useful Post:
DanoFA20 (11-13-2012), dori. (11-14-2012), Jive Turkey (09-30-2013), Lonewolf (11-15-2012), sklimo (09-30-2013)
Old 11-13-2012, 06:19 PM   #6
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
me too mine comes and goes ive noticed if im sitting at idle it like chirps a second goes away then comes back ten goes away if im driving i dont here it but then if i go to downshift push the clutch in i here it for a second until the clutch reengages
DanoFA20 is offline   Reply With Quote
Old 11-13-2012, 06:21 PM   #7
DanoFA20
Shift Down
DanoFA20's Avatar
it actually is sir. my friend is a tech at toyota and the report given to them is that the part will be replaced by request of owner, but its still the same HPFP from manufacture until they fix the plunger problem youll get the same HPFP that will give you the crickets. he told me to wait.
Old 11-13-2012, 06:25 PM   #8
Vicious LED
Thanks for the info
Old 11-13-2012, 06:33 PM   #9
DanoFA20
Shift Down
DanoFA20's Avatar
Thanks for the info
no problem at all bud :happy0180: ill update everyone if im the first to know when the new fixed pumps are available for install. huzah for being 24,000$ beta testers lol
The Following 3 Users Say Thank You to DanoFA20 For This Useful Post:
ft86Fan (11-19-2012), Shagaliscious (11-14-2012), Vicious LED (11-13-2012)
Old 11-13-2012, 07:32 PM   #10
travace
travace's Avatar
Drives: Scion FR-S
same here. mine comes and goes. when it does come its loud tho
travace is offline   Reply With Quote
Old 11-14-2012, 08:10 AM   #11
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
Mine was replaced by Subaru and it chirps again 500+ miles
Sent from my Galaxy S3 using Tapatalk 2
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 11-14-2012, 08:38 AM   #12
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It's never going to be a recall sadly, no safety issue, just noise... :S
Rayme is offline   Reply With Quote
Old 11-14-2012, 09:13 AM   #13
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
It's not a recall, but it is a warranty issue and there is a TSB for the fix. If you take your car in and they hear the chirping, they'll fix it via the TSB free of charge.
The only difference between this and a recall is that the customer has to bring the issue to the dealership's attention rather than the other way around.
Grimlock is offline   Reply With Quote
Old 11-14-2012, 12:36 PM   #14
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
At this point, I'm just like "let it chirp". Just finding it hard to care nowadays...
dori. is offline   Reply With Quote
Fuel pump and speed sensor Tt3Sheppard Issues | Warranty | Recalls / TSB 28 04-20-2017 02:54 PM
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 10:28 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
Dynosty Pushing the Limits... Fuel Pump and Clutch Dustin@Dynosty Engine, Exhaust, Transmission 29 08-15-2012 07:53 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 11:33 PM
