Old 11-12-2012, 08:20 PM   #407
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by MANDALAY View Post
The runners are touching the block and heat will travel.
Phenolic Spacers.
http://www.grimmspeed.com/catalog/pr...products_id=54
Draco-REX is offline
Old 11-12-2012, 10:10 PM   #408
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
Originally Posted by FreshFRS View Post
very nice i want to run the biggest pump i can without too much weight though and cobra pumps seem to be working fine in some cars (mustang for example)
this is the pump i wanna use:http://www.xylemflowcontrol.com/mari...fugal-pump.htm :thumb up:
Did you mold those hoses?
mines13 is offline
Old 11-12-2012, 10:17 PM   #409
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
what about meziere pump?
http://www.meziere.com/displaycatego...id=244,352,372
Mars2 is offline
Old 11-12-2012, 10:19 PM   #410
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
You guys lost me, i think this and the Vortech threads need spin off threads of upgrades you can do to the kit, most people aren't going to re-engineer their FI system they just spend 4k on.
JoeBoxer is offline
Old 11-12-2012, 10:40 PM   #411
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
that wasn't my picture but im going to run .75" teflon lined stainless flexible hoses i think.
FreshFRS is offline
Old 11-12-2012, 10:42 PM   #412
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Originally Posted by Mars2 View Post
looks to be a good one as well! might just have to take that one. i had a meziere on my S2k worked flawlessly.
FreshFRS is offline
Old 11-12-2012, 10:57 PM   #413
MANDALAY
Drives: MR2
does now :happy0180:
Very good volume pump ! Just see that it can run for some time without the water just in case something happens
MANDALAY is offline
The Following User Says Thank You to MANDALAY For This Useful Post:
FreshFRS (11-12-2012)
Old 11-12-2012, 10:59 PM   #414
MANDALAY
Drives: MR2
Originally Posted by Draco-REX View Post
Heads up on spacers like that they are porous with many SW20 MR2's having them and only leaking oil out due to oil going in the plenum thru the PCV
MANDALAY is offline
Old 11-12-2012, 11:02 PM   #415
MANDALAY
Drives: MR2
Yep , i have done a real lot.
Thats probably why i have been suggesting because of the experience i have gained
MANDALAY is offline
mines13 (11-13-2012)
Old 11-12-2012, 11:06 PM   #416
MANDALAY
Drives: MR2
Just remember number one rule with water pumps in a A/W set up the more the flow with good pressure the better. Also the bigger the line th better.
If you can fit 30 mm the best. The Johnson M90 that i have also has a model with bigger lines. DO NOT skimp here
MANDALAY is offline
Old 11-12-2012, 11:58 PM   #417
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
19-20mm should be sufficient for the size of the intercooler we will get with the Innovate supercharger kit. and im thinking the meziere pump should be sufficient as well.
FreshFRS is offline
Old 11-13-2012, 02:13 AM   #418
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Well, this thread went sideways fast. I hope Innovate releases some more info in the future about this kit, in the mean time this thread is mostly worthless.
RedLeader is offline
Old 11-13-2012, 05:17 AM   #419
MANDALAY
Drives: MR2
Seriously ?
Common man look where i live. Where do you think they are getting the kit from ? America ?
MANDALAY is offline
Old 11-13-2012, 09:00 AM   #420
Draco-REX
Corner Junkie
Draco-REX's Avatar
We've been spoiled by the Accelerated Performance threads and others like them. They had the parts in-hand, and involved the community (who would be buying the kit) in the build and development. These threads where a kit is announced, then goes back behind the curtain leave an information vacuum that the community will fill itself. If they want the focus to be on their product, they have to keep the information flowing.
Frankly, Innovate had a unit in their hands at SEMA. It should be on a car by now. Bullet has one of these unit (is the manufacturer of them?) but info from them is nigh non-existant also, and they've had one on a dyno. At this point, the only people who will buy one of these kits are those who want the "bling" of a manifold-mounted blower.
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
