AVOturboworld
Old 11-12-2012, 04:27 PM   #1471
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
I wonder if there would be ability to run as little boost as possible for a reason - winter icy roads or fuel saving
it could be done by special ECU map with IWG staying open all the day long - but some boost would still be generated
HOW MUCH THOUGH?
MSTiFK8R is offline   Reply With Quote
Old 11-12-2012, 04:50 PM   #1472
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
HOW MUCH THOUGH?
Or a EBC, or don't go into boost?
Tansey86 is offline   Reply With Quote
Old 11-12-2012, 05:01 PM   #1473
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
ECUtek can take far lead without using such an oldscool thing as EBC imho
but what would the teeeerrrbbo say when you floor that petal, despite the WG is spread wide as Missisippi?
Right!
The Following User Says Thank You to MSTiFK8R For This Useful Post:
Sportsguy83 (12-31-2012)
Old 11-12-2012, 05:47 PM   #1474
Calum
That Guy
Drives: 2013 asphalt FRS MT
What?
Old 11-12-2012, 05:50 PM   #1475
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Freaking funny pic hahaha.
Nevermind....
Old 11-12-2012, 11:17 PM   #1476
ahaghshenas
ahaghshenas's Avatar
Drives: Subaru BRZ
The AVO catch can has 3 ports (that I can see) where are they connected to??
ahaghshenas is offline   Reply With Quote
Old 11-12-2012, 11:43 PM   #1477
AVOturboworld
One line from the oil reservoir tank off the turbo, one from the standard breather line/pcv valve, one back to the intake system. If you don't have a breather tank, or just a two port (in/out) style, you will need to plumb the breather line from the reservoir back into the standard breather line system via a supplied t piece and line.
To answer a separate question, there's no point in running a "lower" boost system at any time to get better gas mileage. The best system for getting better gas mileage is to simply keep your foot out of the gas. Turbo's don't automatically boost as you get into the higher rpm's, they do that in direct response to the amount of throttle input vs. rpm. You can rev it all the way to 7k at partial throttle and not break into positive manifold pressure. Due to that fact, turbocharged variants of n/a motors often get slightly better gas mileage on the freeway than stock.
The Following 2 Users Say Thank You to AVOturboworld For This Useful Post:
MSTiFK8R (11-13-2012), Sportsguy83 (11-13-2012)
Old 11-12-2012, 11:53 PM   #1478
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
So if I slap on AVO stickers all over my car can I get a free kit ?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
thebear21 (11-13-2012)
Old 11-13-2012, 12:01 AM   #1479
brzadmir
Drives: 13' BRZ, 05' 325xi, 02' RAV4
How is the lag on this turbocharger? Is it really noticeable if there is? Also, being now you are producing more HP to the vehicle should i upgrade my suspension(sway bars, coil overs, wider tires size varies, etc.) to balance out the power? If so, what do you recommend?
brzadmir is offline   Reply With Quote
Old 11-13-2012, 12:06 AM   #1480
AVOturboworld
One of the forum members drove our car with the kit:
http://www.ft86club.com/forums/showp...postcount=1445
I'd look at how you are planning to drive the car before planning out suspension upgrades - it's a very capable car right out of the door, and while the power upgrades make it more edgy, it doesn't overpower it - yet.
BRZranger (11-13-2012), spitz (11-13-2012)
Old 11-13-2012, 12:18 AM   #1481
brzadmir
Ok, whats the suspension mods you made to your vehicle with this turbocharger? My ideal set up as of now is my SRT Header Back, with your turbo kit(stage 1), don't know if i want to go the tire route, camber adjustments etc. Whats your ideal set up for suspension along with your turbocharger to make this car feel like the ultimate go-cart?
Old 11-13-2012, 01:56 AM   #1482
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
That's good to hear that you don't think your kit's power is too much for the stock suspension. I opted to just change out the stock rubber for a high performance tire and it looks like that should be sufficient.
vubaru is offline   Reply With Quote
Old 11-13-2012, 05:23 AM   #1483
MANDALAY
Drives: MR2
Is this kit being made in America ?
MANDALAY is offline   Reply With Quote
Old 11-13-2012, 07:03 AM   #1484
MattQ-WP
MattQ-WP's Avatar
Drives: Pearl White
I would DEFINITELY upgrade the stock brakes before adding power
An opinion is like a bad smell, every A$$HOLE has one!
INITIAL DRIVING CLIP
MattQ-WP is offline   Reply With Quote
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
