Old 11-12-2012, 01:35 AM   #1
Estey
Drives: Scion FR-S, Ultramarine
Downshifting AT
So I just purchased an AT FRS last friday and i really enjoy the car. and with the paddle shifters ive started to downshift as well as use the brakes when i come to stops and i was wondering if that would put wear and tear on the transmission over time.
Estey is offline   Reply With Quote
Old 11-12-2012, 01:43 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If you don't downshift, it will for you. So no ( at least not more than stock). It rev matches and that is the most important thing.
Old 11-12-2012, 03:12 PM   #3
Estey
well of course it downshifts for you but i meant more than stock. as in using the engine to slow the car down as well as the brakes.
Old 11-12-2012, 03:17 PM   #4
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i'm curious why you think you need to do any of this
just use the brakes man, you're driving an automatic
Old 11-12-2012, 03:42 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have an AT also. I down shift in manual mode sometimes. It's fun, it rev matches, and is unlike any other auto I have driven. I also drove my car very gently for the break in period.
Edit: If you feel that you are being harder on your car, you probably are.
Old 11-12-2012, 04:02 PM   #6
mhigham
It will be fine, especially with rev matching. Why else have the paddles? When you need engine braking, use it.
mhigham is offline   Reply With Quote
Old 11-12-2012, 05:42 PM   #7
Estey
awesome, thanks for the help
Old 11-12-2012, 05:46 PM   #8
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I downshift mines all the time even in "D"... There is absolutely no harm in doing so!
Just don't downshift all the way to 1st gear when you're traveling over 10-15 KM/H. I usually manually downshift to 2nd and that's as far as I will go.
The car will downshift to 1st automatically as you slow down while applying the brakes... (Safer that way for the transmission)
:happy0180:
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-12-2012, 06:02 PM   #9
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Higher RPMs will be more wear and tear on the whole drive train. The ECU will basically shifts down when RPMs fall to a point near where the engine would stall if nothing was done. If you're very aggressively down shifting all the time and causing the RPMs to spike to say 6000 then long term this is going to be more wear and tear on the whole drivetrain.
If your not going crazy with it then there should be little to no effect.
I personally love the feel and sound of a quick double tap of the paddle as I enter a turn. The RPMs jump giving me lots of torque to accelerate out of the turn.
The Following 2 Users Say Thank You to neutron256 For This Useful Post:
Dadhawk (11-13-2012), M&M_Hwy9 (11-13-2012)
Old 11-13-2012, 04:00 PM   #10
Danfrscion
Danfrscion's Avatar
Drives: 2013 FRS
Do you know if there is a quick way to go into neutral? I know that you can put the AT directly to neutral, but was wondering if there is a quick way to hold it there. When I am at a stop, on level ground, my manual tranny cars I have just put in neutral.
Danfrscion is offline   Reply With Quote
Old 11-13-2012, 07:02 PM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Why would you need to put it in neutral? The reason for neutral at a light is to allow the driver to not have to hold his/her foot on the clutch. An AT doesn't have a clutch.
Old 11-13-2012, 10:17 PM   #12
Danfrscion
Danfrscion's Avatar
Drives: 2013 FRS
I know that an AT does not have a clutch. I was wondering if any knew of a quicker way.
Old 11-13-2012, 11:11 PM   #13
srtblake
Chrysler/jeep/dodge tech
srtblake's Avatar
Drives: FR-S driver
actually they have several clutches (clutch packs to be exact)
the paddle shifters actually protect against from a lot of dousche-bag aka reckless shifting duplication from owners.
just stick to driving how it was designed mang. :happy0180:
srtblake is offline   Reply With Quote
Old 11-13-2012, 11:26 PM   #14
gwascopter
Drives: MUNI
step the f up and get a MT then come back.
gwascopter is offline   Reply With Quote
Manual Downshifting to 1st Gear Kundiethala Scion FR-S / Toyota 86 GT86 General Forum 45 08-31-2013 08:08 PM
AT Manual Mode Downshifting Reprobate Scion FR-S / Toyota 86 GT86 General Forum 2 07-23-2012 12:40 PM
