Old 10-20-2012, 01:10 PM   #43
Joeprelude
Joeprelude's Avatar
Drives: 2013 FRS, 2002 WRX Wagon
Texas has no Law, per se, on HID lamps (use or aiming) BUT..... SEMA put out an article explaining why HID conversion are in violation of Federal law. Now for the boring part:
Under FMVSS No. 108’s Section S7.7 (Replaceable light
sources), each replaceable light source for headlamps must be designed to conform to the
dimensions and electrical specifications for the headlamp source it is intended to replace. For
example, if an HID kit is marketed as replacing an H1 light source, then it must match the H1’s
wire coil filament size and location, the electrical connector size and location, and the ballast
design for use with an H1 light source (which is impossible since there is no ballast).
Basically saying that if the car didn't come with HID, then you can't retrofit or convert. it goes on to say that even the company that imports the kit is subject to fine...blah blah blah....BUT who is gonna know, really??? If it works, It works. If someone says something, tell em its factory. But like a Cop buddy of mine said "I don't know if it's illegal???" he's been on Dallas PD for 12-13 years......
But to Answer your Question, Texas Has NO law regarding the HID's you want to put in or already have in your car. Just aim them and be happy...
Joeprelude is offline   Reply With Quote
Old 10-20-2012, 01:23 PM   #44
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
Originally Posted by Honeydew View Post
Quick question for you guys!!! WHen i turn on my car and turn on the headlights are the HIDs suppose to slowly gain brightness? It would be dim at first and then he brighten up in like 10 secondish.. is it a problem with my hid or what? please help i don know if i should get replacement
It's normal
JesseE is offline   Reply With Quote
The Following User Says Thank You to JesseE For This Useful Post:
Minovsky (10-20-2012)
Old 11-10-2012, 10:06 PM   #45
seven
Tells it like it is
seven's Avatar
Drives: SS1LE | F150 Diesel | Civic | S3
It's the lights actually warming up. OEM HIDs do this too.
seven is offline   Reply With Quote
Old 11-10-2012, 10:06 PM   #46
seven
Tells it like it is
seven's Avatar
Can someone re-host the pics in the original post?!
The Following User Says Thank You to seven For This Useful Post:
yuicebox (09-16-2013)
Old 12-11-2012, 10:39 AM   #47
Anduz
Anduz's Avatar
Drives: Audi A3
yes please
Black?
Anduz is offline   Reply With Quote
Old 12-30-2012, 09:19 PM   #48
Mac1235
Mac1235's Avatar
None of the photos in this write up actually show up, and it says server error when I try to download them to view separately. Just a bunch of broken download windows.
Mac1235 is offline   Reply With Quote
Old 01-07-2013, 11:07 PM   #49
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
Pics in ops post are showing up as red question marks
Cajun is offline   Reply With Quote
Old 01-08-2013, 05:08 PM   #50
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Hmm question about these HIDS:
@ HIDmasters.com it comes with a free SMD LED bulb pair. What is this and what size should I get to make use of it? (31, 36, 39, 41mm or T-10/194)?
and @ ddmtuning.com what is the extra HID harness and error eliminator? Do I need these?
l0aded is offline   Reply With Quote
Old 04-19-2013, 07:50 PM   #51
eurominican
Bringing Hachiroku Back
eurominican's Avatar
Drives: 2013 Firestorm FR-S
Proper way to plug prongs into stock harness
Some one PLEASE post a pic on whats the proper way to plug those prongs on the stock harness.. A friend gave me an HID kit that did not come with the adaptor and I dont want to mess anything up. Do people simply plug the prongs in and tape it up with electrical tape? Thanks in advance for replies! The kit in this vid comes with the adaptor. Does anyone know where can one get just the adaptor for a good price?
[ame]http://youtu.be/xmp_pU_kgtE[/ame]
EDIT: Found the answer/solution to this problem
eurominican is offline   Reply With Quote
Old 09-16-2013, 01:31 AM   #52
yuicebox
Drives: Asphalt FRS
one more who wants pictures to be fixed here
yuicebox is offline   Reply With Quote
Old 10-04-2013, 10:43 PM   #53
Admired
Drives: 2013 Scion FRS
Please fix pics, I need to install my Powerhouse HID's!
Admired is offline   Reply With Quote
Old 01-03-2014, 09:04 PM   #54
souleffecx
souleffecx's Avatar
Drives: Scion FR-S Raven
pictures please? primarily one that has relay harness set up as well!!
souleffecx is offline   Reply With Quote
Old 03-21-2014, 04:56 PM   #55
Stayreal
Drives: 13' Scion FR-S
Picture fix?
Stayreal is offline   Reply With Quote
Old 06-27-2014, 06:27 PM   #56
slim blanco
slim blanco's Avatar
Drives: 2017 86
turns out i'm still a moron haha. i figured it out, they work fine with no problems now.
slim blanco is offline   Reply With Quote
leather seat conversion stalon320 Interior Parts (Incl. Lighting) 6 07-20-2012 04:36 PM
LED Conversion [M] Cosmetic Modification (Interior/Exterior/Lighting) 38 06-18-2012 08:44 PM
LED exterior and turn signal conversion fenton Cosmetic Modification (Interior/Exterior/Lighting) 0 06-07-2012 11:33 PM
Anyone ever heard of a coupe to removeable hard-top conversion shop? Saibot CANADA 26 02-09-2012 10:38 PM
