Old 11-10-2012, 04:40 PM   #141
Celica00
Celica00's Avatar
Drives: 86
isnt the vortech sc good for up to 15psi that doesnt seem small or am i missing something
Celica00 is offline   Reply With Quote
Old 11-10-2012, 05:14 PM   #142
Opposed
Drives: 2013 Asphalt FR-S
Correct, Vortech told Perrin that this blower can support up to about 15psi.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-10-2012, 05:42 PM   #143
gmookher
usable target is about 9psi...aiming higher than that, well you could, but why? finding a balanced solution is the goal. As soon as hp and tq numbers are out you'll see it here
Old 11-10-2012, 05:48 PM   #144
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
anything more than about 8 and ull need to run higher than 93, just saying.
Tansey86 is offline   Reply With Quote
The Following User Says Thank You to Tansey86 For This Useful Post:
gmookher (11-10-2012)
Old 11-10-2012, 06:05 PM   #145
2forme
I'm still waiting for dynos so we can see what kind of torque curve we're dealing with here.
Old 11-10-2012, 06:07 PM   #146
MANDALAY
Drives: MR2
Ok corrected 80 HP at 5 psi, but thats not much at all and the most important fact its only at MAX REV .
Its about area under the curve.
So at say 5,000 rpm what you have is probably 35 Hp really nothing.
There is a thought your car can do 180 kms/hr , well yes , do you do it all the time , well no.
There is no reason for putting a small powered turbine SC . Put the biggest and control the output.
Your far better using a smaller pulley , getting the boost up way low and controlling the max boost.
MANDALAY is offline   Reply With Quote
The Following User Says Thank You to MANDALAY For This Useful Post:
Calum (11-11-2012)
Old 11-10-2012, 06:14 PM   #147
MANDALAY
Drives: MR2
Why ? well easy answer that 9 psi is only at red line.
Balanced solution ? you describing a Turbo set up.
The turbine SC is just a pump , air compressor , if you use it properly you control the psi.
Then vary it on the mods you have.
As far as waiting for hp and tq numbers , well i dont have to wait as they wont be much and it will only show whats going on with the tune
Calum (11-11-2012)
Old 11-10-2012, 06:15 PM   #148
MANDALAY
Drives: MR2
That might be the case but as i said thats at red line
Calum (11-11-2012)
Old 11-10-2012, 06:20 PM   #149
MANDALAY
Drives: MR2
Forget about you told what , where are the specs for that SC ?
IF it be 15 psi and you are seeing only 8 psi therefore the kit is being out fitted with a larger pulley What a waste BUT at least latter on you can install a smaller pulley.
If it isnt then the unit has low air compressing capability and it wasted money because as soon as your satified with the power you will want more.
Calum (11-11-2012)
Old 11-10-2012, 06:24 PM   #150
TheSt|G
TheSt|G's Avatar
Drives: BRZ L 6MT, 128i 6MT, E39 M5, E36 M3
Fun fact: If you click the " button next to the quote button you can queue up multiple quotes in one post instead of spamming the crap out of this thread.
3.2 911 5MT
BRZ Limited 6MT
BMW E82 128i 6MT
BMW E39 M5 6MT
BMW E36 M3 5MT
TheSt|G is offline   Reply With Quote
The Following 2 Users Say Thank You to TheSt|G For This Useful Post:
FRSPirate (11-12-2012), gmookher (11-10-2012)
Old 11-10-2012, 06:42 PM   #151
MANDALAY
Drives: MR2
Here i will describe it in simple terms.
Vortech or Rotrex or any other centrifugal blower just blows air relative to the belt.
The amount it blows is directly proportional to
a) gearing
b) size
Its maximum that it will blow is directly proportional to the pulleys used to get that maximum.
You will get maximum ( which the kit will do do to its size and pulley size ) at maximum revs.
Anything lower than 7,600 rpm and you get less.
Turbo guys balance theirturbo to give power low and carry that psi to red line.
Well thats what you want to do. Get the electronics to control max boost, the same way traction control controls traction
Here is a big Rotrex SC same one ive put in my car but the plot is of another car
Its boost it being controlled by a waste gate.
Another point being most kits are so very conservative and really have only the hard ware as thats the easy part. A real kit will also include the electronics and which have been properly tuned and mapped. More time is spent on that than any of the fabrication.
Calum (11-11-2012)
Old 11-10-2012, 06:45 PM   #152
MANDALAY
Drives: MR2
Thank you , something i learnt today
Maybe others have learnt something and might review the way the look at a SC , whether its a Vortech or and other centrifugal blower
EDIT
Just realised that this 80 hp is only on a dyno pac. The increase might be there but its relatiive to what the STD engine does as a percentage , about 40% .
Dyno pac will always have higher numbers.
Ive searched but cant seem to find any island plots ?
Are there any ?
Calum (11-11-2012)
Old 11-10-2012, 08:35 PM   #153
gmookher
Mandalay, thats enough. Get a vendor account and start another thread.
If you dont think this is the kit for you, build use and enjoy your own.
Reread the title of this thread. Youre making a fool of yourself.I really suggest you pitch your turbo, your rotrex, or piss on their solution elsewhere. Its in poor taste and form on your part here. I would suggest you delete your posts of drivel here, and seek somewhere else to naysay a solution.
Your posts arent adding value. As soon as Vortech is ready to release results I'll let you know.
The Following User Says Thank You to gmookher For This Useful Post:
TuxedoCartman (11-10-2012)
Old 11-10-2012, 08:54 PM   #154
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Why bother..
RedRocket is offline   Reply With Quote
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
HKS Supercharger getting closer gtauto AUSTRALIA 166 09-03-2012 07:11 PM
TRD Supercharger anyone?? poormans_LFA Engine, Exhaust, Transmission 48 04-27-2012 11:42 PM
Supercharger for Infiniti G25 Lottta Other Vehicles & General Automotive Discussions 2 02-12-2012 09:10 PM
