Old 11-10-2012, 12:30 AM   #379
UltraFRS
UltraFRS's Avatar
[ame="http://m.youtube.com/watch?v=KWb6Ff5HzDs"]Bullet SC 86 - YouTube[/ame]
UltraFRS is offline
Old 11-10-2012, 10:59 AM   #380
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Thanks!
[ame="http://www.youtube.com/watch?v=UbNgNcEfsUY&feature=youtube_gdata_player"]Mercury Motorsport Custom Tune: SUPERCHARGED Toyota 86 - YouTube[/ame]
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline
Old 11-10-2012, 12:20 PM   #381
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
does it come with an intake or do does it work with aftermarket intake or does it use the factory intake?
also can you still use the cusco strut bar or does the supercharger get in the way?
draggin_az is offline
The Following 2 Users Say Thank You to draggin_az For This Useful Post:
IllusiveFRS (11-10-2012), Lawnik (11-10-2012)
Old 11-10-2012, 03:54 PM   #382
nonicname
Drives: it has 4 wheels and a motor
it uses the factory intake.
It seems like only Australian performance companies have the right idea about building kits. they are conservative and use as many factory components to keep costs down.
Both IM and AVO have the righ idea.
nonicname is offline
Old 11-10-2012, 04:44 PM   #383
draggin_az
draggin_az's Avatar
what if you put on an aftermarket and threw your factory intake away?
Old 11-10-2012, 04:47 PM   #384
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I'm sure somebody would sell you their factory intake cheap but in the future i wouldn't throw away your take off parts.
JoeBoxer is offline
The Following User Says Thank You to JoeBoxer For This Useful Post:
TheSt|G (11-10-2012)
Old 11-10-2012, 05:08 PM   #385
nonicname
If aftermarket intakes are meant to mount to everything else stock and this turbo kit is made to mount to a stock intake, then obviously yes.
Old 11-10-2012, 05:19 PM   #386
sw20kosh
Drives: 2013 Black FR-S
Not really. If the aftermarket intake replaces the air box and doesn't have an airbox or filter that shares the stock airbox connection location then it wont work. Yes all intakes connect to the throttlebody but they all haver their own routing and piping that does not follow the stock airbox config.
sw20kosh is offline
The Following User Says Thank You to sw20kosh For This Useful Post:
Unleashed (11-10-2012)
Old 11-10-2012, 05:53 PM   #387
EN2_Squirrel
EN2_Squirrel's Avatar
How close is an airaid intake to the stock air box? i have that one and it looks close.
Sent from my SCH-I510 using Tapatalk 2
STREET MOD. My wallet now hates me....
EN2_Squirrel is offline
Old 11-11-2012, 03:00 AM   #388
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
So simple. Wow. Looks great, can't wait to see the power output of this setup!
Coheed is offline
Old 11-11-2012, 05:08 AM   #389
Tradewind
Drives: 2006 Subaru Liberty EZ30 S/charged
Smile Aus
Thats kind of true, to some extent the resources to make complicated new parts are more expensive or even not possible in Aus so its make the best of what you got. The kits still come out awesome tho
Toyota 86 test driver
Tradewind is offline
Old 11-11-2012, 08:25 AM   #390
MANDALAY
Drives: MR2
Long term testing is what ill be interested in with this SC set-up.
Bullet is definitely innovative to say the least and have the only Road registered and approved Australia wide V8 MX5.
I can be wrong and hopefully will be but 2 other systems that used a Laminova inter cooler over the engine built in the inlet plenum suffered from heat soak, the Stillen Vortech 370Z and the Speed of science NSX.
Rotrexsperchargers of UK have a really dear but wonderfully engineered setup but changed from the laminova to a plate and frame once they saw heat soak being an issue.
Maybe the Sprintex doesn't heat the air as much or the psi is purposely kept low so as not to have the issue
MANDALAY is offline
Old 11-11-2012, 09:36 AM   #391
RedRocket
RedRocket's Avatar
Drives: Firestorm Red FR-S
Heat Soak is a product of insufficent surface area on a heat exchanger..
IF you cannot remove enough heat the unit is undersized, or the SC is producing too much heat.
There have been hundreds of SC's/Turbo chargers that use Air/Liquid coolers, and don't have problems with Heat Soak.
A small mount of set ups have a problem, yet people are ready to say that EVERY system will have this problem.. It's Simply NOT TRUE.
RedRocket is offline
The Following User Says Thank You to RedRocket For This Useful Post:
FreshFRS (11-12-2012)
Old 11-11-2012, 10:29 AM   #392
gmookher
while this is not specific to this system ,it applies to all:
turbos heat up motor oil faster than SCs cause sc's are belt driven, turbos are driven by hot compressed exhuast gas...and utilize engine oil as their lube
turbo engagement=hotter motor oil
not so with SC, own both systems in my garage and track both here in AZ...fwiw
gmookher is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 03:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 10:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 06:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 07:10 AM
