Old 11-10-2012, 04:34 AM   #1
pdreams
What torque dip?
I think the car on stock ecu has enough to deal with the torque dip.
Running on Perrin overpipe and front pipe and Greddy Axleback w drop in filter.
Massive difference after the Perrin parts.
More than enough torque and power to move around w this setup.
Am on 98 fuel but I don't think thats going to make much of a diff.
So does a tuned ECU make the car any much more better?
Opinions?
pdreams is offline   Reply With Quote
Old 11-10-2012, 04:40 AM   #2
Burn
Slack Bum
Burn's Avatar
Drives: FT86
A tuned ECU will optimize your setup and let your car run at it's full potential
Burn is offline   Reply With Quote
Old 11-10-2012, 07:38 AM   #3
Gardus@Supersprint
Drives: Clio TCE
I'm not so sure about that, I still have too see a dyno with a "cured" dip in the torque curve.
Gardus@Supersprint is offline   Reply With Quote
The Following User Says Thank You to Gardus@Supersprint For This Useful Post:
Drift-Office (11-11-2012)
Old 11-10-2012, 08:31 AM   #4
2forme
This. After my I/E, the dip FELT like it was gone, but in reality, it was just cut in half. Instead of losing 20 ft lbs, I was losing 10... much less noticeable.
Old 11-10-2012, 09:04 AM   #5
Gardus@Supersprint
Drives: Clio TCE
The thing is, IF it was possible to correct this throught ECU tune, they would have don it from the factory.
If you analyze the OEM intake and exhaust you'll notice a number of resonators, I think they are there to reduce the issue.
arghx7 (11-10-2012)
Old 11-10-2012, 10:13 AM   #6
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
My opinion is the torque dip will always be there unless going FI.
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
The Following User Says Thank You to ngabdala For This Useful Post:
Subie (11-10-2012)
Old 11-10-2012, 10:53 AM   #7
pdreams
What I meant was the car is not as "torque-less" as most people make it out to be.
The amount of external static pressure in the exhaust system is quite substantial for this car i.e. cats, resonators, inefficient bends etc. Anytime there is a smoother way for the exhaust gases to go with, the difference is noticeably felt.
Sure there is a torque dip but its really not as bad as when the car was full stock exhaust.
I think a tuned ECU will still be good but perhaps try one with an efficient IHE setup first for those still thinking about ECU tuning. The car is a different machine even with a just the changes I have.
Having said that, those with IHE mods and ECUTEK, its probably a real blast.
Old 11-10-2012, 11:10 AM   #8
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Yup, should be much more optimised and smoother power delivery
Old 11-10-2012, 11:13 AM   #9
xwd
Nothing is as cost effective as a tune for helping make power and helping "fix" the torque dip.
Here is someone's dyno with similar mods as you, the lower run is without the tune, the higher one is with the tune, and this is on 93 octane. Even without the exhaust it will still do more than an exhaust will.
Old 11-10-2012, 11:16 AM   #10
Calum
That Guy
Drives: 2013 asphalt FRS MT
I think an intake manifold may also cure the dip, but I have no evidence of this.
Old 11-10-2012, 11:21 AM   #11
Opposed
Drives: 2013 Asphalt FR-S
I have yet to see anything N/A "cure" the dip, but it makes a huge difference in the size and length of the dip. Here is my baseline and then Ecutek tune. Sorry for the horrible picture, I only have the printouts. I laid them out so the RPM's match.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 11-10-2012, 05:35 PM   #12
arghx7
Drives: car
ding ding ding
Old 11-10-2012, 05:42 PM   #13
xjohnx
Grip>Slip
xjohnx's Avatar
E85 does a pretty damn good job of minimizing the dip.
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Opposed (11-10-2012), SkullWorks (11-12-2012)
Old 11-10-2012, 05:49 PM   #14
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
i have the FA20club 93 octane tune and the dip is 95% gone. its there but not near as bad as it is on a factory tune.
draggin_az is offline   Reply With Quote
Torque App - What does your layout look like? DriftEightSix Electronics | Audio | NAV | Infotainment 27 05-01-2016 08:52 PM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
Torque gains, what does the job? JoeBoxer Engine, Exhaust, Transmission 21 10-01-2012 05:46 AM
Wheel Re-Torque to 89 ft-lb Brzce Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 08-22-2012 10:55 PM
Torque App ZetaVI Other Vehicles & General Automotive Discussions 4 12-02-2011 12:22 AM
