Old 11-09-2012, 09:51 PM   #1415
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Tansey86 View Post
I dont think so. The terms change when dealing with the stock exhaust system and a turbo system. This kits comes with the manifold that connects to the turbo that connects to the downpipe which then connects to the factory frontpipe. At the end of the front pipe the catback connects. The only thing left stock about the exhaust after this kit and a catback is the frontpipe.
Take a look at the stock Header and where it ends and connects to the overpipe. Now look at the UEL header, turbine, and connecting pipe and see it conecting to the exact same spot the stock header connects to the overpipe
and besides, AVO has already confirmed the turbo kit will bolt on to any header back exhaust, meaning that if you have the stock overpipe or an aftermarket one, the kit will connect to the overpipe connection.
Edit: I already replaced the overpipe/frontpipe on my car and know for a fact the kit is connecting to the stock overpipe.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ngabdala (11-09-2012)
Old 11-09-2012, 10:00 PM   #1416
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Alrighty, I may have misjudged the system I apologize. So if you want a full exhaust post turbo kit, you need to replace the overpipe + frontpipe + catback?
Tansey86 is offline   Reply With Quote
Old 11-09-2012, 10:09 PM   #1417
Sportsguy83
Drives: Limited BRZ
Correct, that s what is needed for full exhaust after turbo kit.
No worries on the misunderstanding, we are all here to learn among ourselves. :happy0180:
Old 11-09-2012, 10:16 PM   #1418
Tansey86
Tansey86's Avatar
All we need now is a uncatted full 3" TBE
Old 11-09-2012, 10:32 PM   #1419
2forme
I bet the turbo would LOVE the SRT HB. Would probably quiet the exhaust down a bit too.
Old 11-09-2012, 10:36 PM   #1420
nix
nix's Avatar
Drives: AVO BRZ
Why are you guys confusing people.
The header is removed from the stock system and replaced by the UEL manifold, the turbo, and a new 'dump pipe' which connects up to the stock over pipe location.
nix is offline   Reply With Quote
Old 11-09-2012, 10:37 PM   #1421
Tansey86
Tansey86's Avatar
Yeah, we already clarified that.
Old 11-09-2012, 10:37 PM   #1422
Tansey86
Tansey86's Avatar
Turbo needs bigger diameter piping than 2.5". Needs as little back pressure as possible,
Old 11-09-2012, 10:38 PM   #1423
vubaru
Now with Boost!
vubaru's Avatar
Drives: 2013 SWP BRZ Ltd.
Originally Posted by AVOturboworld View Post
Sadly, yes - haven't even had a chance to wash off the car after the 1400 mile trip back from Las Vegas/SEMA. If it wasn't for driving through a monsoon at 70+ miles an hour after crossing the Oregon/Washington border, it'd still have the bugs on the front!
I STILL have a bug cemetery on my clearbra from SEMA. Lol.
The kit & catback sound amazing.
2.5" should be fine for this size turbo no? Aren't there circumstances where 3" could be too big or would that be more appropriate on a turbo like this?
vubaru is offline   Reply With Quote
Old 11-09-2012, 10:44 PM   #1424
Tansey86
Tansey86's Avatar
Any more than what this kit is making with 2.5" on a turbo kit will start robbing power.
Old 11-09-2012, 11:05 PM   #1425
Shit Luck
Drives: red frs
The turbo itself is all the backpressure you will ever need.... I am planning to build a 3 inch straight pipe system. Might hang an hks high power canister on it just so it looks like I am making an effort to be "legal"
Shit Luck is offline   Reply With Quote
Old 11-09-2012, 11:09 PM   #1426
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Love everything about this kit but two things. These two things are all pref, just dont like hhow you cant hear the turbo sucking in air and the bov. I think my first issue can be fixed by using a metal air intake?
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 11-09-2012, 11:14 PM   #1427
Tansey86
Tansey86's Avatar
Its only 5 psi, and using the stock intake. Up the boost a bit and match it up to a aftermarket airbox and you should hear it plenty.
AVO offers a BOV options for 200 bucks
Old 11-09-2012, 11:15 PM   #1428
AVOturboworld
2.5" on stage 1 through, say, stage 3 is "right sized" for spool/response. It's a 2.0-liter motor, there's not a lot of exhaust gases to work with, so we are doing everything we can to maximize response within that framework.
If you were moving up to that 350+ WHP area, you will start looking for 3" after about 380whp. But keep in mind, low-end response will be sacrificed, and a lot of other upgrades besides the exhaust as well.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Sportsguy83 (11-10-2012)
accelerated performance, avo turbo kit, avo turboworld, avoturboworld turbo kit, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs fi, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz fi, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 09:59 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 02:42 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 01:19 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 07:23 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
