Old 11-08-2012, 09:52 PM   #15
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Originally Posted by Coheed View Post
Hmmm, there are only two issues I see here. Both ACT clutches I've had in the past either shot the springs out, or didn't hold their rated capacity.
The spring issue has been years ago and resolved. Was an unfortunate time for ACT.
The not holding rated capacity is really going to be about use. Nothing will hold up to a ton of drag race launches or stop light to stop light launches either. Not sure how it was used, but I would not hesitate to put this in our car with SC kit.
FT-86 SpeedFactory is offline   Reply With Quote
Old 11-08-2012, 09:53 PM   #16
staycrushing
staycrushing's Avatar
Drives: A Hot Mess
im running the hd-ss kit as pictured above. this should be way more than enough... they also have 4 puck + 6 puck (sprung and unsprung) and cintered iron options as well. trust me... this kit is more than sufficient with our motor even supercharged.
if you need more than that, use a sprung 6 puck thats what i run on my 240 which is putting down way over 300ftlb of torque to the wheels.
one of the first people to ruin the frs.
staycrushing is offline   Reply With Quote
Old 11-09-2012, 11:35 AM   #17
wu_dot_com
Drives: accord
im running the same kit except with prolite FW.
like stay says. if you need even more torque. get the 4 puck solid hub version. the NVM will probably be very noticeable though.
wu_dot_com is offline   Reply With Quote
Old 11-09-2012, 09:01 PM   #18
No Limit Motorsport
No Limit Motorsport's Avatar
Drives: 2013 DGM BRZ
Send a message via AIM to No Limit Motorsport
+1 This problem is over and done with. Watch out for some of the 6 spring clutches out there like Comp Clutch, they shoot springs out occasionally. I haven't had a customer with an ACT clutch do that in a LONG time.
If you guys want more holding power there will be a 6 puck sprung disc that will be available. They are a bit trickier to drive than the full face disc's, but still very streetable.
As far as lightweight flywheels go, sometimes too light is a bad thing, like poor drivability and also cause issues like "random misfire" check engine lights etc. Although that is a car dependent thing, so it might be great on these cars.
Adam
No Limit Motorsport is offline   Reply With Quote
Old 11-13-2012, 03:26 PM   #19
FT-86 SpeedFactory
Totally agree. Thanks Adam.
Adam
Eibach FR-S at SEMA 2012 AE86guy FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 40 12-07-2012 05:37 PM
JRP LIVE @ SEMA 2012 *updated daily@SEMA* Stav CANADA 22 11-21-2012 02:56 PM
SEMA 2012 Paul_S Cosmetic Modification (Interior/Exterior/Lighting) 0 11-02-2012 10:05 AM
SEMA 2012 & Subie Invasion Vegas BRZ First-Gen (2012+) — General Topics 0 09-13-2012 06:01 PM
