Old 11-01-2012, 08:53 AM   #491
skatery1989
Drives: BRZ Limited
Might be wrong but I think they already switch the driveshaft.
skatery1989 is offline
Old 11-01-2012, 09:26 AM   #492
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Just because its a 2 piece driveshaft doesn't mean its not strong enough or up to the task of putting the power down. I am sure that there will be a stronger aftermarket driveshaft developed in the future. Generally, when exerting more force on a driveshaft than it was ever designed for they twist and in most cases just beat up the tunnel. It's uncommon for a driveshaft to have a complete failure, where as, if a UJOINT fails, it can get very ugly. There have been some very high hp cars that run a 2pc driveshaft without any problems and at very high speeds as well (think 1000+hp and over 200mph in a standing mile). Primary concerns for driveshafts are quality of materials, balance, weight and proper angles for all of the joint. Not saying the OEM driveshaft can take 500+hp all day long but it may have no problems at all.
Kwaziekeller is offline
Old 11-01-2012, 01:47 PM   #493
cf6mech
Drives: FRS Silver LS1 swapped.
Isn't the u-joints , carrier bearing , and yoke parts of the drive shaft as a whole?,.....thats my point. I'm from the Mustang world recent convert to a FRS, driveshafts are a weak link in the highly modded modern mustang. I'm just questioning the design limit of the driveshaft (as a whole,u-joints and all ) when ur upping the torque and HP, to not just 50% but three X factory stock,.....just curious if they are still running stock,thats all
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
Silverdub (11-02-2012)
Old 11-02-2012, 12:41 AM   #494
Kwaziekeller
They very well could be. idk for sure tho. I consider them all different parts tho, as its possible to upgrade some and not others, but if you were to upgrade them all there is no doubt you'd have a stronger setup. I really think that the relatively low torque and progressive nature of the turbo setups helps the rest of the driveline stay intact. Yes... they make some great hp/torque but it's not a massive "surge" of power... it's progressive and isn't making 400 ft-lbs at 1700 rpms or anything. Plus the relatively light weight of the car reduces stress on the drivetrain. A lot harder to get almost 4k lbs moving in a mustang than this 2700lb car, less intertia.
Old 11-02-2012, 10:53 PM   #495
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
PST makes a single piece Carbon shaft. i wouldnt be suprised if it can take all sorts of power and 10.2lbs less weight than the factory 2 piece. a bit pricey though looks like a quality piece. be my next mod, in the new year sometime.
FreshFRS is offline
Old 11-03-2012, 07:53 AM   #496
bakerr6
Drives: 2013 raven black fr-s
Coming from the engineering and the mustang world, I can tell you this drive shaft should last any amount of power that 90% of us are going to be throwing at it. With that saidd, anytime you are modding a car, you run the risk of things breaking. Just grab a ds safety loop and be on your way.
I also came from the mustang side, and this drive shaft has better qualities, does not take the surge of tq immediately and is not hauling a boat. The only thing I would be worried about is the ds binding under extreme conditions, causing it to lose its hardened properties and would cause the ds to resonate and potentially break.
In all reality, you should be able to hear if it ever needs replaced, long before any mechanical damage would occur with the level of power most of us are putting down
bakerr6 is offline
The Following User Says Thank You to bakerr6 For This Useful Post:
carbonBLUE (11-03-2012)
Old 11-03-2012, 11:47 AM   #497
SnapOv3st3r
Drives: 400whp Scion tC
Enough of the driveshaft talk. When will we see some more developments, videos, commentary on the setup? Updates please.
SnapOv3st3r is offline
The Following 2 Users Say Thank You to SnapOv3st3r For This Useful Post:
Floggin Tires (11-03-2012), usptwins (11-04-2012)
Old 11-06-2012, 03:08 PM   #498
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
Originally Posted by MattQ-WP View Post
And also... how does a driveshaft become a Point Of Sale?
lawl )
nos145 is offline
Old 11-07-2012, 12:53 AM   #499
Visconti
Drives: 05 STi
You won't be waiting a month. I promise
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
tripjammer (11-18-2012), usptwins (11-07-2012)
Old 11-07-2012, 09:28 AM   #500
Don@Accelerated
Don@Accelerated's Avatar
For the Driveshaft? I should have the prototype today actually. 9lbs lighter than stock!
Don@Accelerated is offline
The Following User Says Thank You to Don@Accelerated For This Useful Post:
Old 11-07-2012, 10:41 AM   #501
Visconti
Drives: 05 STi
No to go faster
Visconti is offline
Old 11-07-2012, 05:38 PM   #502
Don@Accelerated
No to go faster
LOL....Theres always next year...
Old 11-07-2012, 05:41 PM   #503
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
600wheel and 9's gogogogo
Tansey86 is offline
The Following User Says Thank You to Tansey86 For This Useful Post:
Old 11-10-2012, 05:32 AM   #504
cf6mech
Thanks Don ! , I knew this would be something you would be looking at. Had to fight off all the knuckle heads.....should of just called you.....btw I haven't installed your turbo yet, I'm installing Arias forged pistons lowering compression to 9 to 1 and forged rods,.... maybe over kill, but I will be able to run full boost on pump gas.
cf6mech is offline
brz forum, brz forums, brz quater mile, come at me bro, fbm lol, ninja posting, subaru brz forum, subaru brz forums, subaru brz quarter mile, subaru brz turbo, subaru brz turbocharged, turbo brz, turbo subaru brz, turbocharged brz, turbocharged subaru brz, vague, vanishing act, visconti bonfire special, visconti is a boy toucher, viscontifried
Accelerated Performance BRZ-400 - Visconti Tuning Don@Accelerated Engine, Exhaust, Transmission 356 06-21-2013 09:05 PM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 05:43 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
