View Poll Results: Do you park in gear
Never 25 11.79%
Always 129 60.85%
Only on steep hills 58 27.36%
Voters: 212. You may not vote on this poll
Old 11-06-2012, 06:27 PM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
parking in gear
Just curious as to how many people actually park in gear. Do you always park in gear or just on slopes?
jarviz is offline   Reply With Quote
Old 11-06-2012, 06:30 PM   #2
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
Because of habit, and I always break the wheels to one side.
I am very insecure. I have no friends. I want people to love me
Old 11-06-2012, 06:35 PM   #3
DIM
Only on hills!
DIM is offline   Reply With Quote
Old 11-06-2012, 06:36 PM   #4
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
I always park in gear. If I am on any kind of slope I will also set my hand brake.
whaap is offline   Reply With Quote
Old 11-06-2012, 06:38 PM   #5
Vicious LED
Drives: Scion FR-S Asphalt
Gear + Brake always.
Vicious LED is offline   Reply With Quote
Old 11-06-2012, 06:39 PM   #6
travace
travace's Avatar
Drives: Scion FR-S
i have a slanted driveway so yea always as its just habit now.
travace is offline   Reply With Quote
Old 11-06-2012, 06:53 PM   #7
jstans84
Drives: Scion FR-S
Always.
jstans84 is offline   Reply With Quote
Old 11-06-2012, 06:57 PM   #8
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
In gear + handbrake + wheels curbed on slopes, always.
Subie is offline   Reply With Quote
Old 11-06-2012, 06:57 PM   #9
jstn
Drives: '15 Vortech Supercharged
in-gear and handbrake on every time I park. I'm paranoid.
jstn is offline   Reply With Quote
Old 11-06-2012, 07:01 PM   #10
70NYD
70NYD's Avatar
Drives: RX8 S1
I always park in gear (1/R depending on what way I'm on a slope), plus brake, but I have to get out of this habit as I want to get remote start
70NYD is offline   Reply With Quote
Old 11-06-2012, 07:12 PM   #11
roddy
roddy's Avatar
Drives: '13 Ultramarine
In gear, brake on. Always.
Old 11-06-2012, 07:22 PM   #12
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
You should always use your handbrake also, parking on just the gears can cause unnecessary tension on the gears. The odea of parking in gear is to be a backup in case the parking brake fails.
1 or R shouldn't matter, if your in gear it would need to be turning over the engine to roll regardless of which gear your in.
Either way, I only use the parking brake unless on a steep slope, ive had manual cars with remote starts for the past 6+ years so parking in gear was a no no. Never had a car roll.
Flat Black VW is offline   Reply With Quote
Old 11-06-2012, 07:41 PM   #13
hippari
I Love your GUCCI Wheels!
hippari's Avatar
Drives: Raven Black FR-S
Send a message via AIM to hippari
In gear always, habit I got into when I had my first manual car and would sometimes forget to put the handbrake up and end up chasing a rolling Miata at a gas station.
@jinxyboi | @_iLLdynasty
Rice for the Rice God
hippari is offline   Reply With Quote
Old 11-06-2012, 07:46 PM   #14
whaap
whaap's Avatar
Think about that one for a minute. If you think parking a car in gear on a relatively flat surface causes tension on the gears what do you think push starting a car does to the gears? Tension is not causing any harm. Enough tension to shatter a gear is not going to happen and for sure you're not going to bend a gear because of tension. If a car were on a severe slope and left in gear only, it could start rolling down the hill turning the engine over as it went along its way.
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 12:42 AM
Hit and Run in parking lot PoRco Scion FR-S / Toyota 86 GT86 General Forum 39 08-17-2012 01:44 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
