#71 | |
USMC Veteran Semper Fi
Drives: 2010 WR Blue STi
http://www.ebay.ca/itm/321005462366?...#ht_500wt_1180
#72 | |
Drives: Ultramarine FR-S (MT)
For debadging, DarrenDriven wrote a great post with lots of pictures here: http://www.ft86club.com/forums/showthread.php?t=7296 You may also be interested in painting your badge before putting it back on using plastidip. You may also be interested in putting the 86 logo instead.
#73 |
Well I changed to the Toy T, in my rush I chipped the front paint, so I went down to Signs of Santa Fe and got some black reflective vinyl, when the light hits it at night it's bright white.
#74 |
My wheel emblems came in also. 25.00 with freight total.
Spartan65's DROID RAZR
#75 |
Drives: FRS, IS300, 911sc
I used the fish wire technique with hair dryer heating it first. Some glue was so strong that a some paint came off as I sew through the glue with fishing wire. Just a word of caution to other people.
#76 |
Drives: 2013 Scion FR-S Raven
I think those of us in South Florida have an advantage with all the heat and humidity, it seems to loosen these things pretty well.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#77 |
after failure in with front badge using fishing wires... i used steam for the rear. WORKS easily and no scratches at all. HIGHLY recommend steaming to remove the badges.
#78 |
Have we confirmed whether the badges ordered from Toyota from the Corolla and the Avalon come with the adhesive already on them? Do I have to provide my own adhesive or are they peel and stick ready?
Thanks in advance. |
#79 |
I think everyone needs to visit the DIY section. You must 100% use a source of heat to get these emblems off, the glue they use has a very low melting point and when heated it is very easy to pry off with absolutly zero damage to the car. If there is residue left, there is no need to use any chemicals, use more heat and a clean pair of gloves and it will just roll off the paint with a very light rub.
#80 |
New ones have adhesive
| The Following User Says Thank You to tonystewart For This Useful Post: | Mac1235 (12-17-2012) |
#81 |
#82 | |
Drives: GT86
http://www.ft86club.com/forums/showthread.php?t=23723 Merry Christmas
#83 |
Drives: ZN6
Has anyone looked into the toyota nameplate badge that is positioned on the rear left side on the gt86's.
After looking at extensive pictures etc i know that really doesn't help hah but I found that the 03s and on camrys nameplate badge on the back is very similar if not the same as the gt86. Pn# 75447-AA020 for those that want to take a look. I ordered one so ill let you guys know how it looks when it arrives!
#84 |
Drives: 13 Firestorm FRS MT & 09 DGM WRX
Here are my new badges, used carbon fiber vinyl behind them.
| **Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 10:24 AM |
| Swap your Scion key emblem for a Toyota | Synack | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 08-03-2012 05:58 PM |
| Plastidip emblem??? | jarviz | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 08-02-2012 03:21 PM |
| Toyota Emblem replacement | jarviz | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-26-2012 11:12 AM |
| Non USDM BRZ oil weight | BMWDavid | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 06-21-2012 02:55 PM |
