Old 09-28-2012, 02:44 AM   #57
psk
Drives: scion fr-s
Originally Posted by VietnamPhenom View Post
I just got the Corolla and Avalon rear emblems today. Lucky for me, I work for Firestone. So, I got a discount an 10% over cost. I wanted to change mines up a little bit, and I plastidipped them black. I want see you guys opinions. I'm at a 50/50. If I don't like them, I can always peel it off back to chrome.
black and white always looks good. i just plasti dip'd all my emblems on my asphalt fr-s. 86 piston padge and everything lol.
so i went to the toyota dealership today to get a price check on the avalon and corolla rear emblems. the avalon emblem was only 9 bucks, but the corolla was $30. you guys need to make sure you double check if you go through with your dealer's parts dept. because the only emblem they had that matched the part number "90975a2003" (corolla rear) was in SATIN silver (like the scion emblems) and NOT chrome. so i settled for the avalon emblem which was chrome and snatched a chrome corolla emblem off ebay for $15.
sine we've found a way to go around buying emblems that fit the FR-S, has there been any success finding wheel/center caps? i came across these http://www.ebay.com/itm/4x-TOYOTA-Wh...66c62a&vxp=mtr but i believe they are too big.
psk is offline   Reply With Quote
Old 09-28-2012, 08:35 PM   #58
VietnamPhenom
Drives: 2013 FR-S WHITEOUT
The ones I got were chrome and not satin silver. Lucky for me, i get a discount through all the dealers. I paid $34 for both after tax.
VietnamPhenom is offline   Reply With Quote
Old 09-30-2012, 03:46 PM   #59
GL4787
Toyota Service Writer
GL4787's Avatar
Drives: Whiteout M/T, 2003 Duramax
ordered mine through work ended up being about $20. matched up perfectly and looks great, thanks to whoever first found out about the corolla/avalon fitment. Now only question is how to do toyota wheel caps on the cheap, if not, guess i just gotta get wheels
Whiteout Manual
I'm a service writer at a Toyota/Scion dealership, if I can help at all let me know.
GL4787 is offline   Reply With Quote
Old 09-30-2012, 04:44 PM   #60
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
The money I saved I used to offset the cost of the wheel caps from Carson Toyota.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 10-03-2012, 09:15 PM   #61
knaa
Drives: FRS
Noobish question, but any recommendations on double sided emblem tape? Or can you buy it from a local dealership
knaa is offline   Reply With Quote
Old 10-03-2012, 09:57 PM   #62
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Guys we have these on our car and on our website plus stock them.
Got our silver car done up in these.
FT-86 SpeedFactory is offline   Reply With Quote
Old 10-05-2012, 11:19 AM   #63
pjb86
pjb86's Avatar
Drives: 2013 Scion FRS Raven
Can someone who has changed their emblems give us a detailed desription of removing the old ones without damaging the paint?
pjb86 is offline   Reply With Quote
Old 10-05-2012, 01:01 PM   #64
tonystewart
Car color is Raven, let it sit in the South Florida sun for 30 minutes.
I wet the area with hot water from the tap.
I put on thick gloves and wrapped 8 lb test fishing line around my fingers, slid it behind the emblems and used it like a saw. It took about 1 minute per emblem to break lose the emblem.
Grabbed it with my ungloved hands and peeled it off slowly.
Bathed the area in Goo Gone, let sit about 30 seconds, rubbed with a hot water cloth.
It came off very easily, almost like rolling up taffy.
I cleaned the area with Dawn dish washing soap, dried it, waxed it with Turtle wax.
This is how I did it, I'm sorry if I upset those who don't like my method.
The Following User Says Thank You to tonystewart For This Useful Post:
SkAsphalt (12-17-2012)
Old 10-06-2012, 06:49 PM   #65
pjb86
pjb86's Avatar
Thanks for the directions for removal.
Old 10-06-2012, 07:18 PM   #66
VietnamPhenom
I used 3M Adhesive/Wax remover. The rear emblem I just pryed off by hand and it came clean off with no adhesive residue. The front, I had to use the 3M adhesive remover and used my plastic decal removal tool.
Old 10-07-2012, 01:12 AM   #67
try2findmark
Drives: Bukkake FR-S
Hmm.. wondering if the toyota emblem from a 92 previa would work?
try2findmark is offline   Reply With Quote
Old 10-13-2012, 08:54 AM   #68
Project_GT86
Drives: Scion tC
Appreciate the research! Now waiting for a cheaper wheel logo replacement.
Project_GT86 is offline   Reply With Quote
Old 10-15-2012, 04:55 PM   #69
CrazyWookiee
Drives: Whiteout FR-S
I ordered these to stick on top. They are a tad bigger, but I think there's some room to cut around.
http://www.ebay.ca/itm/4X-56mm-Toyot...item2a20f7e507
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 11-04-2012, 08:48 PM   #70
636
636's Avatar
Drives: '23 CWP BRZ
Do we know if Subaru emblems will fit on an FR-S? Also, does anyone know the part code for the BRZ?
636 is offline   Reply With Quote
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
Swap your Scion key emblem for a Toyota Synack Scion FR-S / Toyota 86 GT86 General Forum 6 08-03-2012 05:58 PM
Plastidip emblem??? jarviz Cosmetic Modification (Interior/Exterior/Lighting) 20 08-02-2012 03:21 PM
Toyota Emblem replacement jarviz Cosmetic Modification (Interior/Exterior/Lighting) 3 07-26-2012 11:12 AM
Non USDM BRZ oil weight BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-21-2012 02:55 PM
