Old 10-31-2012, 06:10 PM   #57
Mark Slide Squad
Mark Slide Squad's Avatar
Drives: 2013 Whiteout FR-S 6MT, S14 Kouki
Bias in that car was notoriously front heavy. But it's generally a better idea to run all 4 calipers than just the fronts, though I have no idea on what the bias in this car is. That said, 08+ STI calipers should bolt right on in the rear (rotors will need to be drilled) and any STI caliper will bolt on in the front (will need to swap bleeders).
Same rotor, thinner pads I think.
Just searched and the rotors are in fact smaller diameter on the EVO, but thicker.
EVO front
320mm diameter
32mm thick (29.8mm min thickness)
43.5mm total height
STi front
326mm diameter
30mm thick
not sure on height
Mark Slide Squad is offline   Reply With Quote
Old 10-31-2012, 07:31 PM   #58
OrbitalEllipses
Drives: Attitude
And that'd make sense as to why the pads are thinner. I have a full set of these in the garage waiting to be reconditioned...
Old 11-02-2012, 02:57 PM   #59
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I'm thinking about ordering the parts to make this swap. I haven't seen anyone mention brake lines, but I am assuming the BRZ brake lines in OEM and stainless steel aftermarket variety will bolt up to the 08+ STi calipers front and rear.
Old 11-02-2012, 09:17 PM   #60
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
I sure hope so because I plan to do this when I return!
kmbkk is offline   Reply With Quote
Old 11-04-2012, 04:50 PM   #61
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Well I ordered the parts yesterday, so you can check out mine before you get yours, haha.
Old 11-05-2012, 10:52 AM   #62
kmbkk
kmbkk's Avatar
Drives: FR-S, Flex
Did you go with the STI calipers? If so, where did you them?
Old 11-05-2012, 03:25 PM   #63
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I got a used set of front and rear 08-12 STI calipers off NASIOC.
Old 11-05-2012, 09:02 PM   #64
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
Has anybody running a bbk, or Sti calipers had pad knockback yet? Curious how stout the front components are.
dorifuto is offline   Reply With Quote
Old 11-06-2012, 05:23 PM   #65
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
so i have 05 brembo's laying around. i plan on putting them on the brz. i understnad that you need to swap bleeders to mount then correctly but my maine question is has anyone tried fitting the stock wheels on with front brembo's? how much of a spacer do you need to clear, i plan on slapping them on in the spring and i want to know if i should look into a new winter setup for next year and try to sell the stock wheels.
Jive Turkey is offline   Reply With Quote
Old 11-13-2012, 11:42 PM   #66
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
I just got a set of 2012 STi front and rears tonight. Anyone install the rears yet?
mrha is offline   Reply With Quote
Old 11-14-2012, 12:10 AM   #67
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Corgi!
TouchMyHonda is offline   Reply With Quote
The Following 2 Users Say Thank You to TouchMyHonda For This Useful Post:
Enigmus (05-05-2013), mrha (11-14-2012)
Old 11-14-2012, 02:44 PM   #68
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I installed them on Monday. You will have to severely bend the dust shield or cut it off like I did.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
chanomatik (12-16-2013), mrha (11-14-2012)
Old 11-14-2012, 07:13 PM   #69
mrha
#1819
mrha's Avatar
May I see pics? Also which rotors did you use?
Old 11-14-2012, 07:31 PM   #70
jamal
jamal's Avatar
Drives: Legacy GT
Rear rotors have to be for an 08+ STi with re-drilled holes. wrxbrakes carries them.
The 04 sti 5x100 rotors DO NOT work.
jamal is offline   Reply With Quote
will the sti brembos fit fr-s/brz? driver01 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 51 04-12-2014 02:25 PM
Those Brembos, fixed caliper? Or not? [Patent inside!] madfast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 155 12-08-2011 02:06 PM
