Old 11-02-2012, 07:59 PM   #1
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
BRZ hardwire radar.
here is a quick and easy DIY to hardwire your radar into your BRZ. i know there is one already on this site, but this one is a bit simpler IMO.
to start get the right wireless connectors. blue ones were too big, as well as the on that came with the V-1.
anyway i wired it to the auto-dimming mirror the harness SHOULD be there even if you don't have the mirror as an accessory.
to get to it simply pull the dome light, it ISN'T screwed in and just pooped out. there are 4 metal clips that hold it in place just give it a nice tug. (i'm not responsible for you snapping anything)
then locate the harness. it will be on the right, and will consist of three wires. BLACK BLUE GREY. atleast thats what it was one mine.
you tap ground to the BLACK wire which is ground.
then you tap power to the GREY wire which was power.
the blue wire didn't get any power when i tested it.
then after you tap it just make sure to connect your radar to double check before you tuck everything up. it should be on in acc and on.
i mounted my radar in the top left corner and ran the wire along the headliner.
here is where i mounted it. out of the way but close enough to mute. also for radars to work effectively they HAVE TO BE MOUNTED HIGH with clear visibility and no obstructions. so mount carefully.
enjoy,
-ivan
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
phobos512 (03-19-2015)
Old 11-02-2012, 08:11 PM   #2
QFry
QFry's Avatar
Drives: '13 Argento FR-S
Pictures no work...
2013 Argento FR-S -> Lots of random PlastiDip, UNIChip Custom Tune, aFe Takeda Intake, Nameless Performance front pipe and axle back exhaust, Motegi MR125 7.5x17, Rally Armour mud flaps, Gloss black vinyl roof, ACT street clutch and flywheel,Whiteline bushings; Kartboy Shortshifter and shift bushing
QFry is offline   Reply With Quote
Old 11-03-2012, 07:40 AM   #3
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
No offense but how is this easier then the method in the thread I posted? The wires in this look sloppy compared to the thread I posted where it is 1 simple wire with 2 prongs you plug into the existing harness....
speedracer38 is offline   Reply With Quote
Old 11-03-2012, 11:34 PM   #4
Jive Turkey
the tuna, no crust.
didn't know you'd get butthurt.
this uses the stock hardwire kit that came with the v-1 and one extra tap. this is the same way i did it in my 11' sti. its just a different option for people who prefer positaps so they know which wires to tap. please explain how it looks sloppy? i took a picture off all the wire hanging for a reason...so you can see where it all runs.
Old 11-04-2012, 12:21 AM   #5
sierra
Drives: Skoda Yeti DSG diesel 4x4
enjoy,
-ivan
The last radar detector comparison I read found better results by fitting them low as the signals were reflected off the car bonnet and amplified the signal.
sierra is offline   Reply With Quote
Old 11-04-2012, 12:32 AM   #6
Jive Turkey
the tuna, no crust.
link me? interested in reading this as many have always said other wise.
Old 11-04-2012, 12:40 AM   #7
sierra
I'll try to retrace my steps and post it?
Edit-Couldn't find that one but the first article when I googled "best place position radar detector" got this which said low.
http://www.radarbusters.com/mountdet...rlyarticle.cfm
Here's the one I read before.
http://www.delonixradar.com.au/radar...e-to-mount.php
The Following User Says Thank You to sierra For This Useful Post:
Jive Turkey (11-04-2012)
Old 11-04-2012, 12:59 AM   #8
Jive Turkey
the tuna, no crust.
i'd appreciate that.
Old 11-05-2012, 10:55 PM   #9
knaa
Drives: FRS
will these steps work for the stock frs? I noticed that you have a different rear view mirror than i do.
knaa is offline   Reply With Quote
Old 11-07-2012, 12:18 PM   #10
Jive Turkey
the tuna, no crust.
it should. i know on the wrx's and sti's the wiring was already there for the autodimming mirror. in theory it SHOULD be there, to check just pull the dome light and feel for a harness on the passenger side. if you dont have that mirror it will just be the male end that i spliced into.
Old 11-14-2012, 05:04 PM   #11
Eau Rouge
Eau Rouge's Avatar
Drives: 2013 BRZ, Limited, C7P, 6AT
I think low mounting works well for forward facing radar detection (where most of the risk is) due to the reason posted previously. I think high mounting is advised because some radar detectors, like my Escort, detect both in front of and behind the car. Low mounting will impair rearward detection if the unit ends up sitting below the bottom of the rear window opening.
Eau Rouge is offline   Reply With Quote
Old 03-19-2015, 10:11 AM   #12
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
I checked my wiring with a multimeter Blue is Positive, Grey is Negative and Black is just N/A.
Can anyone else confirm this?
Kayysonie is offline   Reply With Quote
Old 03-20-2015, 12:11 AM   #13
Eau Rouge
Eau Rouge's Avatar
I should have mentioned this before but why not just get one of the fused connection kits from eBay and wire your radar detector into your rear view mirror? That's what I did.
DIY-Replacing Rear View Mirror/Hardwire Radar Detector Lil Abner DIY (Do-It-Yourself) Guides 40 06-11-2020 02:48 PM
Mounting a radar detector Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 24 02-06-2014 12:39 PM
What radar/laser detectors do you use? sa1126 Electronics | Audio | NAV | Infotainment 131 12-16-2013 09:39 PM
Win a Laser/Radar detector! raul Off-Topic Lounge [WARNING: NO POLITICS] 0 10-10-2012 01:57 PM
Radar Detector? Longhorn248 Other Vehicles & General Automotive Discussions 68 07-14-2012 04:31 PM
