Old 11-03-2012, 07:50 PM   #127
zoomzoomers
zoomzoomers's Avatar
BTW, has anyone from Perrin been in touch with any of you guys about the rattling? It's beginning to really get annoying. With them being so far away I honestly don't know what they could do about it.
Old 11-03-2012, 07:55 PM   #128
DSOmegaX
DSOmegaX's Avatar
Originally Posted by zoomzoomers View Post
Personally, I don't know what good poly hangers would do for an exhaust system. I mean most, if not all, CBE's are designed to use stock mounting points so why would stiffer hangers be beneficial? Maybe I don't know something someone else does, but that doesn't make any sense to me.
They're beneficial for aggressive driving (autocross, track, etc.). They prevent exhaust systems from shifting around (significant movement) during aggressive cornering. They are not meant to eliminate any of the vibration issues me and you are having. It's more piece of mind. OEM rubber mounts can hold up just fine under normal use. I use the middle hangar mostly because I don't want the resonator to make contact with the transmission tunnel during cornering.
@dsomegax.cars
Old 11-03-2012, 08:11 PM   #129
zoomzoomers
Gotcha!
Old 11-04-2012, 01:14 AM   #130
Zaneman
Drives: 2013 BRZ limited
I contacted them and with a little work on my part I was able to stop the rattling. Albeit mine was different then yours, unless one of your pieces has a flaw I don't see why with some work you couldn't stop the rattling.
Zaneman is offline   Reply With Quote
Old 11-04-2012, 09:44 PM   #131
zoomzoomers
Well that's the thing if I had access to a lift I could get under there and fool around to see if I can find a fix. Unfortunately, I have to get to a shop to do this.
Old 11-04-2012, 10:27 PM   #132
cnk
Drives: '13 DGM BRZ Limited
You don't need a lift to work on the exhaust. I did my install and tinkering afterwards with ramps and 2 jack stands.
Old 11-05-2012, 01:57 AM   #133
ShoShin
ShoShin's Avatar
Drives: WRB Premium
Thanks for your input. If anything I will most definitely go with a cat for the frontpipe. For 2 reasons, 1. the noise factor and 2. because I live in a nazi state (California). LOL
Allow me to jump in. How much exhaust modification can we get away with in CA? I was thinking we can safely modify anything beyond the cat. Maybe I should ask, where's the cat located on the BRZ/FR-S??
(apologies in advance for noob question)
ShoShin is offline   Reply With Quote
Old 11-05-2012, 10:26 AM   #134
zoomzoomers
There's a cat after the header and another in the front pipe.
[=MyNameIsArjuna;538896]Allow me to jump in. How much exhaust modification can we get away with in CA? I was thinking we can safely modify anything beyond the cat. Maybe I should ask, where's the cat located on the BRZ/FR-S??
(apologies in advance for noob question) [/QUOTE]
Old 11-05-2012, 10:31 AM   #135
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
[/QUOTE]
I want to add that for emissions purposes the O2 Sensor is between the two cats. This makes the cat in the header critical and the one in the front pipe just for extra cleansing.
Unfortunately its hard to see the cat in the header so a catless front pipe will look like a catless exhaust to people who aren't 86 enthusiasts.
F1point4 is offline   Reply With Quote
Old 11-05-2012, 10:59 AM   #136
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
^if that's the case, there will be some hard nuts to convince
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 11-05-2012, 12:38 PM   #137
zoomzoomers
Unfortunately its hard to see the cat in the header so a catless front pipe will look like a catless exhaust to people who aren't 86 enthusiasts.[/QUOTE]
I wonder if you could pass emissions in CA if you keep the stock header & cat, but go with a non-cat front pipe. Because then you could go with a complete header back system.
Old 11-05-2012, 01:23 PM   #138
ShoShin
ShoShin's Avatar
Drives: WRB Premium
My thoughts exactly.
Old 11-05-2012, 01:44 PM   #139
zoomzoomers
Not to mention that a front pipe w/o a cat is half the price of one with a cat.
Old 11-05-2012, 01:46 PM   #140
cnk
Huh? It's a $100 difference. Front pipe w/o cat is $315 from Perrin's site directly and $415 with the cat. If you're in a state where they do visual inspections, $100 is nothing compared to a ticket.
exhaust, headerback, perrin
Perrin Catback Exhaust vs Nameless Performance Exhaust. vignesh Engine, Exhaust, Transmission 201 06-05-2013 09:47 PM
NEW! Perrin SS Catback Exhaust System Up to +9rwhp | In-Stock| FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 31 04-06-2013 09:05 AM
Brand New SRT Headerback Exhaust System prest1ge Southwest 5 10-16-2012 06:06 PM
