Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 11-01-2012, 08:25 PM   #1
eleu2166
Drives: '07 Civic Type R
KW V3s don't fit Whiteline COM C top hats
Hey guys,
Having KW v3s installed right now, and was just made aware that the Whiteline top hats apparently don't fit the KW v3s properly and need modification. So if anyone else is going with this combo, make sure your mechanic is aware and doesn't just bolt them straight on (will apparently cause grinding issues without modifications).
eleu2166 is offline   Reply With Quote
Old 11-01-2012, 09:09 PM   #2
Nardi330
Nardi330's Avatar
Drives: 86
can you advice what issue and modification is needed?
same as the issue identified on this thread? http://www.ft86club.com/forums/showt...ight=whiteline
Nardi330 is offline   Reply With Quote
Old 11-01-2012, 10:12 PM   #3
Paragon
Guest
Posts: n/a
that sucks to hear dude, was looking forward to having a ride in them on the weekend, did they say they can get it sorted out?
I have heard good things about the Vorshlag plates for the KWs?
Old 11-01-2012, 11:35 PM   #4
armythug
armythug's Avatar
Drives: Pegasus White 86GTS
KW V3s sound like one of the best out there but I dont see why they didnt come with top hats.
Pegasus White 6MT got it. :happy0180:
armythug is offline   Reply With Quote
Old 11-01-2012, 11:46 PM   #5
Nardi330
Nardi330's Avatar
Drives: 86
it is more of an issue of the Whiteline top mount rather than KW.
if you look at the link i posted above, according to RCE the washer should be fitted to avoid issue.
Vorshlag seems good but they are not cheap...
Old 11-02-2012, 12:08 AM   #6
86drift
86drift's Avatar
Drives: Toyota 86 GT
I can confirm Tein Street Advance work fine with the Whiteline strut tops.
The Whiteline tops look like the factory ones, so I would have thought you'd have the same problem with the factory tops.
86drift is offline   Reply With Quote
Old 11-02-2012, 12:18 AM   #7
eleu2166
Yeah, same issue.
Old 11-02-2012, 12:21 AM   #8
Nardi330
Nardi330's Avatar
Drives: 86
Originally Posted by eleu2166 View Post
Yeah, same issue.
so have you fixed the problem with the washers?
Old 11-02-2012, 12:53 AM   #9
eleu2166
Yeah, I'll ask for more details when I pick up the car, it's at MRT right now who have been working closely with Whiteline on their development car so they knew what the problem was right away.
Will keep you guys posted.
The Following 2 Users Say Thank You to eleu2166 For This Useful Post:
Nardi330 (11-02-2012), Surok (11-06-2012)
Old 11-02-2012, 01:01 AM   #10
D1cker
Drives: B9 S4/ND2
I put the washers in on my car (posted the other thread) and it still flexed like that but it didn't seem to bind at all.
D1cker is offline   Reply With Quote
Old 11-05-2012, 06:16 PM   #11
Nardi330
Nardi330's Avatar
Drives: 86
how did you go? any update?
thanks
Old 11-05-2012, 06:28 PM   #12
ModBargains.com
ModBargains.com's Avatar
It's because KW's are European style coilovers... You'll usually see European coilovers without top hats, but you'll see JDM companies use top hats in most applications.
Well whoever told you to buy whiteline, that's the problem as well, for not knowing. Vorshlag's are the best of the best, and for a new car, why wouldn't you consider anything other than the best?
ModBargains.com is offline   Reply With Quote
Old 11-05-2012, 06:46 PM   #13
eleu2166
thanks
Picked up the car end of day Friday, 30 minutes into driving a knocking sound in the front left wheel starts developing. So didn't end up driving the car too much over the weekend.
Brought the car back in yesterday and apparently I got a faulty set of Whiteline Com C hats (not related to the spacers required by the hats though). They replaced them with new hats along with the required modifications again and I'm currently waiting to pick up the car again this afternoon.
Through this experience I definitely recommend getting something other than the Whiteline top hats. I'll be looking into getting the Vorshlags in the near future.
The Following User Says Thank You to eleu2166 For This Useful Post:
sierra (12-17-2012)
Old 11-05-2012, 06:57 PM   #14
86drift
86drift's Avatar
I recommended KMac strut tops. Great quality the best adjustment range.
JRP- New Whiteline Suspension for BRZ/FR-S Stav CANADA 0 10-23-2012 06:38 PM
Whiteline SEMA flyer JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 10-21-2012 11:00 PM
Whiteline Performance 86drift Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 10-14-2012 06:07 AM
