Old 11-01-2012, 11:25 AM   #197
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Originally Posted by Dipstik-sportech View Post
Did I not say days ago that its just a powdercoated sprintex kit?
If the unit is right, this looks like the right calcs for it:
So it won't be a dyno queen in numbers, but naturally I'm dying to see the torque curve.
TomR
ABQautoxer is offline
The Following User Says Thank You to ABQautoxer For This Useful Post:
ill86 (11-07-2012)
Old 11-01-2012, 11:35 AM   #198
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
looks to be about right. sprintex claims 84% thermal efficiency though which i find very hard to believe. considering not even turbos are that high, Vortech claim 78% for there Centrifugals. (read that on their site somewhere.) in reality i dont think they take power consumption and friction loss into account. (emailed to confirm) if that is the case i would say its more like 65-70% efficient, inline with most other srewtype blowers. power figures could be lower than 268 and most likely that is Crank hp as well. my guess is 250 is more the number your would be looking at. ~210whp.
FreshFRS is offline
Old 11-01-2012, 11:45 AM   #199
ABQautoxer
ABQautoxer's Avatar
I think thats about right actually (on the high side). Lysholm style typically are higher than roots that are around 65%.
TomR
Old 11-01-2012, 11:56 AM   #200
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I expect a wee bit more than 210whp. Before going turbo, I made 280whp on the k20a2 with an Eaton model 62 blower. That 4 banger has similar stock power levels. This was with stock fuel pump, larger injectors (550cc) and an 11psi pulley. Also, this was with NO COOLING. I think it will become the norm for most of these SC kits to have potential past 250whp properly set up and tuned.
Jeff86 is offline
Old 11-01-2012, 12:00 PM   #201
ABQautoxer
ABQautoxer's Avatar
Any idea of the VE of the K20 vs the FA20? I was thinking more like 225-235whp. But with that in mind, the big thing I see is turbo dynos around the same power don't really spool and make 200wtq until 4500rpm which is really late. If this can make 200wtq closer to 3000rpm, it will actually be far more usable/fun for a street car IMO, let alone autox.
TomR
Old 11-01-2012, 12:14 PM   #202
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
11psi though. most likely this isn't going to run that high of boost. 6-8psi probably. though the high compression will help produce much more power from the lower boost. 250whp should be possible no doubt. but using engine calcs on the like that one on the sprintex site to to calculate crank HP not Whp. so if its producing 268 bhp thats only maybe 225whp. lysholm are not more efficient than centrifugal or turbos just saying. lsyholm says 64% http://www.lysholm.us/pdf/diagram_lys1200ax.pdf so sprintex is way off.
the only PD supercharger that hits above 70% is Eaton's TVS
FreshFRS is offline
Old 11-01-2012, 12:19 PM   #203
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
I'm thinkin the K flows better for sure but it has slightly lower compression. That's what makes the stock power levels so similar. All of this is pretty much educated speculation, but I figure we're going to be in the ballpark of what I was able to do on the K with a blower.
Jeff86 is offline
Old 11-01-2012, 12:23 PM   #204
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
the k20 is almost on par with the Fc20 out of the s2k with higher compression it could make nearly the same power as the FC20
FreshFRS is offline
Old 11-01-2012, 12:28 PM   #205
ABQautoxer
ABQautoxer's Avatar
Yeah I figured the VE of any honda was going to be better than the FA20 but being a new motor but I don't fully understand much of the limits of the FA20.
TomR
Old 11-01-2012, 12:32 PM   #206
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
VE isnt all of it. come down to airflow. 12.5:1 offers great VE but the head doesn't flow like a honda design so it compromises power output.
FreshFRS is offline
Old 11-01-2012, 12:40 PM   #207
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Yeah that's true on the 11psi, but that kit shipped with a 5psi pulley lol. One of the first things people are going to do is switch pulleys out. These guys and others have a range of replacement pulleys for various SCs:
http://www.pulleyboys.com/store/home.php
One of the awesome things about seeing this kit when it was on the Bullet car was the amount of wrap the belt had around the pulley. Belt slip becomes a real problem on higher boost because you actually reduce the size of the pulley to spin the blower faster. This thing looks great for that. I do believe I remember a guy who got past 300whp on a twin screw with cooling, but I have no idea what the specs were on that SC.
Jeff86 is offline
Old 11-01-2012, 12:43 PM   #208
gmookher
eating a gt3 is no small task
gmookher is offline
Old 11-01-2012, 12:50 PM   #209
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Didn't see that. No biggie, there's a link now.
Draco-REX is offline
Old 11-01-2012, 01:19 PM   #210
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
11psi may be too high for our motor, definitely without cooling. pump gas and 11psi might be possible with a really good intercooler. the lower compression allows for more boost.
FreshFRS is offline
***Recaro / Racetech / OMP / STATUS / Defi / Apexi / HKS / Innovate / AEM / Cobb***** Touge Factory Interior Parts (Incl. Lighting) 9 11-29-2012 02:13 PM
lost screw for sensor intake Mr.Jay Engine, Exhaust, Transmission 5 10-21-2012 09:26 PM
Lowest Prices on all Gauges and Electronics! Defi|STRI|AEM|INNOVATE+More Rev Works Audio/Visual, Electronics, Infotainment, NAV 28 10-09-2012 05:04 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Missing rubber piece for intake screw ngabdala Engine, Exhaust, Transmission 1 08-31-2012 06:10 AM
